Question about Compaq Deskpro EN 6500+ Model 6400 CDS PC Desktop
I have a cq40 144tu laptop and i can not install xp on this;it gives a blue screen error.How to solve this?
    President:
  • 688 Answers
Your laptop has a version of an OP System called FreeDOS
If you want to put XP you may have to Format your drive and install widows as the main operating system
Posted on Jun 15, 2009
Laptop shutting down on its own and said problem event name blue screen
The 'Blue screen error is a common Windows OS error.
You can find the reason of blue screen....read more
To solve this error in your laptop.see......Fix this problem
Aug 29, 2012 | Microsoft Windows XP Professional for PC
When i try to install windows xp, then all files are extracting rightly but when start up is loading suddenly blue screen appers. so plz help me to solve this problem. give me suggestion.
Hi jenishrabadi, Have you tried using different source software for your windows xp installation.
There should be an error code when you receive the blue screen. post the code here, it may seem like 1) either corrupt software or 2 ) Faulty hardware. Most likely memory.
without further performing any more diagnostics (as we do not know what the actual error is) and making the assumption it is faulty hardware, if you have more then one memory cards in your notebook, try and take one memory card, then try the setup/install. if this fails .. put the memory card back in, and remove the 2nd memory card and try again.
good luck ... hope this helps ...
Oct 07, 2010 | Compaq Presario Notebook
I have compaq cq 40,i need to install windows xp in it,but while installing blue screen occurs and it give error.
this might be hardware compatibility problems some new devices do not except windows xp but what was the reason you are reinstalling windows did you have problems before through my exp with computers ram could also be going bad but your best bet is try it again and when you get the blue screen of death it gives you a error code something like this 1000008e or there may be multiple codes google them and there you should find your answer
Sep 02, 2010 | Computers & Internet
Installing winxp
You must put your CD installer to the CD reader of your PC and Click Install , Confirm and Confirm.
Feb 15, 2010 | Computers & Internet
I hav a laptop cq60-104tu. i want to install xp on it but it gives an error message. what should i do???
Go to the bios and change the SATA into ATA before installing window xp. You will find this option under hard disk type.
Sep 25, 2009 | Computers & Internet
Installation Of Xp Give Blue Screen Error.How Can I Install Xp On My Notebook(CQ60-104tu
Did u format Windows installation drive...
If not then try running fixmbr command....
OR...else
Format entire harddrive and delete all partitions...
Then try to run XP installation by Boot From CD option and this shud work for you.....
If not then give detailed info on the error messages shown to u
->also check data cables inserted properly or not,
-> ensure that hard disk is primary and rest devices is secondary
Sep 03, 2009 | Compaq Presario Notebook
Blue Screen error when formatting my laptop.
try to change the xp cd with other xp cd
i ecountered this problem a long time ago
Jul 09, 2009 | Computers & Internet
Laptop starts and after a while of using a blue error box falshes on the screen and turns off comp I can't even read the blue box its sooo quick!
That is called the BSOD (Blue Screen of Death).
try a chkdsk:
Chkdsk
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Type Chkdsk C: /R at the prompt.
Or try a XP repair:
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 24, 2009 | Sony VAIO VGN-T1XP/L Notebook
I want to install windows xp on my acer 4230
Hi shaikh_shaha
Can you get it to boot using any of the options it gives other than boot normally? If the blue screen is caused by hardware then installing xp will still present the problem. If the blue screen is an operating system crash then using the recovery disk or doing a repair install will solve the boot problem.
If you still rather install xp then you need to go into BIOS and set 1st boot device as CD. To go into BIOS you will need to press F10 or F2 (usually) as displayed on the splash screen when you power on
Does this help?
May 02, 2009 | Acer Extensa 4620 Notebook
Xp installation
1st format u r c: drive carefully by xp cd....with fat 32 file system.
and then try to install it again,,,
sure u r problem will be solved man..
hey .
hope it is solved.......
Was this solution helpful? Show your Appreciation by rating it:
pls vote for me man..
best regards & best of luck..
Nov 05, 2007 | Computers & Internet
Compaq Deskpro EN 6500+ Model 6400 CDS PC Desktop Logo
118 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
