Question about Maytag Neptune MAH5500B Front Load Washer
How much water should this washer use on light soil setting
  • Rocky Wright
    Rocky Wright Apr 17, 2014
    depends on how mant clothes you put in it,the mor clothes the more water.a wate level switch sets the watre amount to a set levle.
  • 164 Answers
According to maytag the washer will use a total of 15 gallons for all cycles
Posted on Mar 29, 2014
    New Friend:
  • 32 Answers
Almost 4 gallons
  • Joseph Kaczor Mar 29, 2014
    Approx. 20 gallons for complete wash
  • Edward Boyce
    Edward Boyce Mar 29, 2014
    Thanks for the info
What are requirements for hot and cold water intake and soiled water outtake?
I know for certain the soiled water drain needs to be at least 3ft (1M) off the floor. The water lines are typically set about 2 ft (.8M) for the hoses. It might also be ease of access for the water to be set that high too. I would check building codes on it or ask someone who does that kind of work. But I'm very sure about the drain height.
Jan 23, 2014 | Kenmore 20022 3.4 cu. ft. Top-Load Washer
Cycle selector on normal mode. cannot operate water tempertures orsoil level light indicators on a infinityfaf
Ron kundrat,
So I understand that you are unable to operate the water temperatures and soil levels on your infinity washer, while on the normal cycle.
I suggest to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle.
If you are unable to change the water temperature and soil level settings, while in the normal cycle, I suggest to contact your local authorized technician. They will be be able to come out and diagnose the washer and see why you are unable to change the settings.
-Best Regards-
Jan 13, 2014 | Frigidaire Washing Machines
My clothes are coming out dirty with lint build up from the washing machine- kelvinator smart drive 053, have undone and cleaned centre- is there a trap underneath anywhere that may be full or blocked?
9 WASH PERFORMANCE INFORMATION
9.1 Creasing
Creasing can be caused by over loading the washer or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet clothes to sit in the washer or laundry basket.
9.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash water. Cold water below 68oF / 20 oC does not wash effectively. Select the wash temperature according to soil type. For example, blood and mud are better washed in cold water, while sweat and oil based soil wash better in warmer water. Loads made up of articles of varying sizes will wash better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than soft water.
9.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading the washer can increase the likelihood of linting. Insufficient detergent for the load can increase linting as there will not be enough detergent to hold the lint in suspension. Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the fabrics attracting lint.
9.4 Detergent Residue
Over loading the washer can result in detergent residue being caught in the creases of the fabrics.
If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times may not let the detergent dissolve properly. In these cases pre-dissolve the detergent. Overdosing of detergent can also cause residue when foam breaks down and will show as white specs on the clothing. Poor quality detergents can result in residue.
9.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is recommended that the machine is periodically filled with hot water, plus 1-2 cups of dishwasher powder and left to soak.
9.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that the machine be periodically filled with hot water, plus detergent and left to soak.
9.7 Dye Transfer
Wash and dry non-colorfast clothes separately. Non colorfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
9.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load the machine by wrapping clothes around the agitator.
Sep 18, 2013 | Fisher Washing Machines
How do you clean **** buildup in a top load washer?
9.1 Creasing
9.2 Soiling
than soft water.
9.3 Linting
9.7 Dye Transfer
9.8 Tangling
Dec 03, 2012 | Fisher and Paykel Washing Machines
Fisher Paykell washer left black grease spots on some clothes
9.1 Creasing
9.2 Soiling
than soft water.
9.3 Linting
9.7 Dye Transfer
9.8 Tangling
Sep 21, 2012 | Fisher and Paykel GWL11 Top Load Washer
How do I clean gw711 lint filter
There is no lint filters in these machines,
It is automatically pumped out with the drain water.
9.1 Creasing
cycles have been designed to minimize creasing as they use a lower spin speed. Do not leave wet
9.2 Soiling
than soft water.
9.3
Linting
9.7 Dye Transfer
9.8 Tangling
Jul 09, 2012 | Fisher and Paykel Washing Machines
Water seems to be leaking from the bottom of my Maytag washing machine. Machine set for a large load. Water stopped, I added the detergent and then the soiled laundry. I went to get other laundry I had...
unplug washer. pull washer to you, have someone tilt the washer back and get a flash light and look for water spots on water pump,your drain hose,could be aclanp or just a hose we hope.
Sep 17, 2011 | Washing Machines
Clothes not clean after washing
Were the settings appropriate for the clothing?
The settings on the machine should be set properly for the load. Different fabric types require different wash/rinse temperatures, spin speeds, and wash times. Always follow the instructions printed on the fabric care label. The soil level needs to be set in accordance with the load type. Heavily soiled clothing will not come clean with a light soil level setting.
Was the proper detergent used?
If too much detergent is used, or non-HE detergent is used, the machine will not wash properly. Too many suds present during a wash decreases tumbling action and will not rinse out well. Furthermore, detergent residue built up in the machine over time will deposit extra detergent on clothes and deposit soil back into clothing.
Was the washer overloaded? If the machine is overloaded, the machine will not wash and rinse properly. When the washer is overloaded, the clothes have no room to tumble, and the cleaning performance of the washer is reduced. In addition, when the clothes are packed tightly inside the drum the detergent and water will not distribute evenly throughout the items.
Front loaders require regular maintenance to ensure optimum performance. If this maintenance is not followed, residue can accumulate in the drum resulting in detergent and soil being deposited back into clothing. This can also lead to odor and other issues. Perform the required maintenance regularly (once or twice a month).
Jan 11, 2011 | Asko W6021 Front Load Washer
Elite he5t washer,suds,then f35,no lights over soil level push button. I try start with only water,but the same problem.This will be problem with the sensor?Why I dont have any lights under soil level...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 26, 2010 | Kenmore Elite HE5t Washer
Maytag Neptune MAH5500B Front Load Washer Logo
81 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
