Question about ViewSonic PJD7820HD DLP projector - 3D
No hdmi signal at viewsonic PJD7820hd from xbox one
The projector doesn`t find a hdmi signal from the xbox one. I tested the xbox one on my hdmi port from my other TV, and everything works, what is the problem with the signal to the projector? I used the same cable, the microsoft support told me after 1 hour of tests that the reason of the problem is the projector. Other hdmi signals from a tv reciver work fine on the projector. What can i do?
SOURCE: Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Posted on Mar 18, 2008
  • 9 Answers
SOURCE: all buttons on tv stopped working only turns ON no ...
There is a button lock in the menu of the television. Using your remote access the menu screen and unlock the buttons.
Posted on Feb 19, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Settings on ViewSonic PJ513D Ceiling Mounting
The user's guide says for ceiling mounting,
"Set Front Ceiling in the System Setup: Basic > Projector Position menu after you turn the projector on."
The user's guide is on the CD included with the projector as a pdf file. You can also download the user's guide here:
http://www.viewsonic.com/assets/006/5619.pdf
If you find this solution gives you what you needed, please take a moment to rate it. Thanks for asking here!
Posted on Feb 22, 2009
  • 34 Answers
SOURCE: No sound when using HDMI cable but I do have sound if using DVI
Is your computer configured to send sound through the HDMI cable as its output device? This might be a setting within your sound card properties.
Posted on May 27, 2009
SOURCE: Remote code
I had the same problem with a Viewsonic N3735W LCD TV and Comcast Customer DVR 3 Device remote. I contacted Viewsonic and they gave me 11454 which works.
Posted on Jul 29, 2009
I got a viewsonic pjd5111 projector used . it power on for aleaast 30 sec and shut down immediately temp light red and lamp light green . i hv tried everything .help
Check if there is a cooling fan. Is it rotating?
It is also possible that the filter is dusty and needs to be cleaned/replaced.
(all projectors have a cooling fan and a filter to prevent dust from reaching the lamp. A faulty fan or a reduced air flow may cause an overheat problem)
Aug 16, 2016 | ViewSonic Office Equipment & Supplies
VGA-HDMI connection fail on Acer projector using adapter
You don't say whether or not the "adapter" is simply a gender-changer, or if it actually converts the digital signal from the HDMI port to an analog one for the VGA port. Some monitors have both analog and digital input capability and can automatically adapt to the the digital signal, even if applied to the VGA (analog) port. Other devices are not so smart and need an actual digital-to-analog converter style adapter.
Jul 06, 2016 | Acer XD1170D Projector
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
HDMI
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
DVI
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
S-Video
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
I want to connect my Philips HTS3357 Home Cinema System to my Panasonic PT-AE900E LCD Projector, How do I go about putting it altogether so it works with my xbox360/PS3
Generally speaking, if your Home Cinema system is able to pass-thru video as well as audio, you'll want to take the HDMI cable from the XBOX video out, into the Home Cinema system's input (any HDMI input should be fine), and then run the HDMI video out to your projector. Any other devices you want to be able to project as well (DVD/BluRay, PC, Cable, Satellite, etc.) would also be plugged into the Home Cinema system as "in" devices, like the XBOX.
When you want to display one of those devices, you would select that "in" port's input name in the Home Cinema system (for example, if the XBOX is connected to the HDMI in that is labeled "aux", you will switch the cinema system to Aux Input, and the projector should immediately begin getting the signal from the theatre system. To switch to another device, you simply change the Input channel on the Home Cinema.
The audio also, providing the device (the XBOX) can carry it on the HDMI cable, will also be delivered to the Home Cinema. Some devices cannot carry sound on HDMI (though many can). For those, you will need to run an HDMI cable for the video, and also an optical cable or other type of audio-only cable, for its audio. You do not need to run an audio cable to the projector though, as the projector is only for video. The Home Cinema will take care of the sound itself.
Mar 28, 2014 | Philips HTS3357/05 Theater System
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
Denon AVR-4806 HDMI problem
Check which port you have the HDMI cable connected to, then go into the menu on the TV, look for it on screen and Enable it .
Good luck
Nov 16, 2013 | Denon AVR-4800 Receiver
No video via hdmi from blu ray
Have you attempted swapping out the HDMI cable for a different one? I recently had a similar problem and I determined that the HDMI cable was faulty. Now everything works fine.
Jul 26, 2012 | Televison & Video
What kind of wire do I need to connect my samsung laptop to panasonic viera hd 3d plasma tv?
Most TVs will have HDMI and RCA component and composite jacks. Some TVs will also have a VGA port. Your laptop will have a VGA port. (If the laptop is fairly new, it may also have an HDMI port.)
Not all TVs will support an HDMI signal from a computer, so the VGA signal is often better. However, that limits you to SD (anything with HDCP will fail.)
Very few TVs ship with the HDMI or component cables. However, there are some vendors who do package the HDMI cable with their TV. Without knowing which exact model of TV and laptop, I can only make a few suggestions. I know that the TCP42ST30 (Plasma 42") doesn't have a VGA port.
Look at your laptop for any external monitor port. VGA ports are generally blue female ports with 15 holes (D-Sub). If your TV has a matching VGA port, get a standard VGA monitor cable.
If you have the VGA port on the laptop but not on the TV, you can try a converting from VGA to HDMI. (You may need a DVI to VGA adapter and either a DVI to HDMI cable or a DVI to HDMI adapter.) Note: this gives an analog signal (RGB format) to the TV. You'll also need to make sure that your VGA port is active (in the BIOS for some computers) and then set your computer to send the signal to the external monitor. It is best to turn off both the computer and the TV before connecting the two. Then turn on the TV and set it to the correct input before turning on the computer. (In Windows 7, I set the video signal for the external monitor by right clicking on the desktop and selecting Graphics Properties. Set the signal to the external monitor and click Apply. Then click OK (in the external monitor's screen).)
If this doesn't work, you need a VGA to component video converter. (Not a VGA to component video cable - those are for projectors that read the RGB signal.) See http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html .
Some laptops come with an HDMI, mini-HDMI or a DisplayPort option. For the latter two, you will need the appropriate cable with that end and the HDMI connector on the other. Then connect the TV and the computer as described above. (Note: my TVs accept a computer signal at the HDMI port labeled HDMI/DVI. However, you need to make sure that your TV understands this signal. It isn't the same format as that from a set-top box. My laptop has VGA and HDMI out; the desktops have VGA, DVI and HDMI (on one).)
If you add a comment with the model of your TV and laptop, I'll be glad to give you more specific options to connect the TV and the computer.
I hope this helps.
(A DVI port is a digital video out option with ~21 pins and is usually white.)
Feb 03, 2012 | Panasonic VIERA Televison & Video
My mac book and epson projector doesn't show the signal
To my knowledge there are no video drivers to output video on a Mac USB port in the Mac OS system. There are however, devices that connect to the USB port that will give video out on Conventional (VGA, DVI, HDMI, etc) connectors.e.g. http://www.newertech.com/products/viddu2dvia.phpMost projectors connect via VGA - what Projector are you using?
Jan 19, 2012 | Apple MacBook Pro Notebook
ViewSonic PJD7820HD DLP projector - 3D Logo
262 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
