Question about Maytag Dryers
Maytag performa dryer just quit
Dryer just quit in middle of cycle
  • 159 Answers
Open panel on Dryer, check belt has not broke or slipped off
Posted on Mar 29, 2014
2 Suggested Answers
  • 4 Answers
SOURCE: dryer quit middle of drying
if proper voltage to appliance then faulty thermal cutout. Part number LA1053.
just to confirm remove the two white wires from thermal cutoff and jumper them together, be sure no wires are touching any part of base when doing this.. If fires up then install the LA1053.. check vent usually this causes this part to fail...
Posted on Oct 17, 2012
Our maytag performa top load washer PAV2200 stopped in the middle of wash cycle and we heard a loud pop and then smelled burning rubber. My husband has pulled the belt off the bottom and its still in one...
Check the drain hose from the drum to the pump assembly. Alternativly look for the large capacitor that should be mounted to the internal framwork of the machine, see if has popped. They can make quite a bang when they go,
Jun 20, 2010 | Maytag Performa PAV2200
My Maytag Performa dryer is taking 2 and sometimes 3 cycles to dry clothes. Suggestions as to why?
Most of the time the dryer blower wheel part number 53-0106 gets loose and and cause this problem. I fixed one just the other day.
Feb 24, 2010 | Maytag Performa PAV2200
Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
Jan 18, 2010 | Maytag Performa PAV2200
Dryer was working, quit in middle of cycle. Will
It's rather unusual for any internal failure to cause the dryer to just stop in cycle. Check the circuit breaker that supplies the dryer. It should be a double-pole breaker of at least 30 amps. Turn the breaker off and back on to ensure it is reset. Internal causes could be the motor, door switch, thermal safety switch, timer, or a broken wire.
Apr 30, 2009 | Maytag PYE2300AY Electric Dryer
Dryer quit middle of drying
Verify 220 volts to the terminal block where the cord attaches.
Check the door switch for continuity.
Check the thermal fuse on the right hand side of the heating element just below where the heater wires connect.
You may need a flashlight to see this fuse.
It most likely is the thermal fuse.
If so correct any vent blockage or you will blow another fuse.
The fuse comes in a kit including the hi-limit switch.
Replace them both.
Feb 27, 2009 | Maytag Dryers
Maytag performa dryer quit in the middle of a load
probably the thermal fuse i just fixed mine it did the same thing it was about twenty bucks for the kit and it is located right under the wires that feed the heating element
Dec 15, 2008 | Maytag Performa PAV2200
Maytag performa gas dryer no longer produces heat.
needs a new timer switch sometimes cheaper to buy another dryer (used)
Dec 02, 2008 | Maytag Performa PAV2200
Maytag performa dryer vent got clogged and quit working
maytag performa dryer quit in middle of drying.
Dec 01, 2008 | Maytag Performa PAV2200
Dryer will not turn on
i've had my maytag dryer since 2002. it just stopped in the middle of a cycle. i think it's the motor. isn't maytag guaranteed for life???
Dec 22, 2007 | Maytag Dryers
Dryers Logo
120 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
