Question about Canon MP18D II Basic Calculator
Need to clear error or E
Our MP18D11 is frozen it shows an E on screen
I have a sharp ER-A450T it is frozen and I have followed all the trouble shooting things in the manual and nothing seems to work...please help
Hi Renee. The first thing to check with this model is whether it beeps when you press clear (The C button near the number 9 button). If it does not make a beep sound, you are right, it is frozen and the problem is usually either a faulty keyboard or printer (but you usually have an error code or dashes on the display if printer problem). Take it to be repaired.
If it does beep, it is not frozen and it is probably just waiting for you to finish something you started. Try pressing clear (C button near the number 9 button) in each mode and then press subtotal and then cash. So turn key to REG mode, press C SUBTOTAL CASH. Turn key to MGR mode, press C SUBTOTAL CASH and so on for each mode. If it shows an error message, please let me know which one and we can check further
May 09, 2017 | Retail Supplies
What does error code C-0510 mean?
C0510 Upper fusing roller abnormally low temp
replace the thermistor in the fuser
Sep 08, 2014 | Konica Minolta Bizhub 8031 Copier
How do I clear ViewSonic VX 2370 frozen screen?
Did you first unplug the AC power cord to see if this helps clear out the issue? Recommend you call ViewSonic Customer Care for support with this.
Jun 25, 2014 | ViewSonic Computers & Internet
Casio tk7500 locked up
The display problem is common. There is a small modification for it. I'm not sure why it is locking up. A flag clear is almost never needed. It is probably just showing an error that you can't see
Dec 18, 2013 | Computers & Internet
INH. OPEN PR showing on my sharp cash register, model ER-A470. all buttons frozen etc
If all buttons are frozen then you have a hardware fault. The clear button should remove any error from the display so if it doesn't work at all, you need to have the keyboard checked.
If anyone is having problems with programming on a Sharp ER-A470, the manual is here:
http://the-checkout-tech.com/manuals/cashregisters/Sharp7.php
Oct 10, 2012 | Casio Parts Cash Register PC Desktop
How to fix or get rid of service error alot
Is the screen frozen BEFORE or AFTER the screensaver activates? If it's after then try doing a scandisk and defrag of the hard drive to clear up errors. Also make sure to go into MY COMPUTER, right click the C: drive and in PROPERTIES runa clean up to delete the temp files that may be corrupted.
    Sep 10, 2012 | Acer Aspire 5720-4984 Notebook
    My Dell 964 is "frozen".
    normally you will need to let the printer know that you have preformed any maintenance on it by clearing the error count after such an error occurs and is fixed it is normally listed under general or service options on the printer menu but you may need to look through the users manual
    hope this helps
    Robb
    Oct 27, 2010 | Dell Photo 964 All-In-One InkJet Printer
    R09 shows up when I try to take a picture. Cannot access preview screen. Camera seems frozen.
    R09 or R07 etc. is not an error message. In Nikon lingo ERR is the one you need to worry about. The RXX refers to the approximate amount of shots left in the buffer in the camera. Not a ptoblem. You may be trying to take pictures faster than your memory card / camera buffer can handle.
    You can try a fster card like 266, but you may find that the camera is also your limitattion.
    If you make no changes at all, the camera buffer will eventually clear and you can again takes pictures.
    May 11, 2009 | Nikon D70s Digital Camera
    Screen is frozen, just blue background with Windows xp logo,
    Apr 03, 2009 | HP Compaq nc6000 Notebook
    Ipod touch frozen on Itune connection
    Per the first Google result for "reset ipod touch", http://www.mydigitallife.info/2007/10/04/how-to-reset-iphone-and-ipod-touch-hard-reset-or-reboot/ says:
    "Press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done"
    Nov 22, 2008 | Apple iPod touch
    Canon MP18D II Basic Calculator Logo
    old marine
    old marine
