Question about Denon AVR-1513
Sound difference the volume difference between tv volume and stereo volume is miles apart.
TV audio output vastly different for satellite feed versus DVD feed. Why?
It is possible there are separate sound level functions for the DVD player, the tv and the satellite box, try the different remotes for each by unlocking the volume control on the satellite remote until you get them close or use the device specific remote volume controls. I would also try and use HDMI if available for the DVD instead of composite. If the volume controls are different it will show on the tv, might also go through all audio settings for each device. Some devices are pre-amped or send out strong sound signals while others are line level outputs designed to be amped by the output device, in this case your tv I believe. The HDMI vs stereo audio that goes with composite may be the cause or it could be in the settings of the device. Worst case is to remember to drop volume before you switch back so you don't ruin speakers.
Jan 25, 2015 | Televison & Video
The volume has went off on my tv. its a samsung le26b450c4w
First verify that the mute is disengaged (toggle the mute button). Second, check the sound configuration to make sure the internal speakers are on, or check the sound output to make sure it is going to the inputs of an external audio amplifier (stereo receiver) and that the external amplifier is working. Try a different input source - perhaps the problem is your cable feed or DVD player.
If the internal speakers are on, the volume is up, and you still don't get any sound from a known-good source (TV channel, DVD player, etc.), then try running the sound to a stereo system as described above.
If that works, you may have a shorted speaker amplifier (depending on the set's design, this may blow a fuse supplying power to both left and right amplifiers or a speaker protection circuit will keep the speakers disconnected). These aren't usually hard to repair, but if you find a blown fuse, fix the amplifier before replacing the fuse or you'll just waste another fuse.
Jan 09, 2012 | Samsung Televison & Video
I have a Harmon Kardon HK 3370 Stereo Receiver and a Samsung LCD LE40C530F1W. When I connect the stereo Aux jack to the LCD Audio jacks ( red and white rf cables ) I get no sound out via the receiver.
Obviously make sure your stereo mode selector is set to AUX and the volume on the stereo is turned up at least a little when you test it.
If you still have no luck then try increasing the volume on the TV as well. You may have it set so that the level of the audio signal leaving the rear output connectors on the TV varies with the TV volume. That way if your TV volume was turned down or muted when you tested it, then you would not hear anything coming through your stereo.
There should be a setting in the AUDIO OPTIONS menu of your TV where you can switch between a VARIABLE AUDIO OUTPUT and a FIXED AUDIO OUTPUT level.
With the FIXED audio output level, you control the volume of the TV audio coming through the stereo speakers with the stereo remote only.
Otherwise it should work.
Good luck.
Jul 16, 2011 | Harman Kardon HK 3370 Receiver
Can not get sound from tv to play through sterio reciever
One simple way to accomplish this is to run RCA audio cables from the red and white (left and right) AUDIO OUT jacks on the back of your TV, and plug those into the red and white (left and right) AUX INPUT connectors on the back of your stereo.
Then just select AUX on the input mode selector of your stereo and you will hear the TV audio through the stereo speakers.
Make sure your TV volume is turned up about halfway way and then adjust the volume on the stereo to your liking.
In the AUDIO OPTIONS of your TV menu you can usually select whether you want the TV speaker to be OFF or ON. That way you can just control the stereo volume with your stereo remote to hear the TV audio.
Or you can select VARIABLE OUTPUT LEVEL for the rear audio output connectors on the TV, and then you can control the volume with the TV remote and just leave the stereo volume set at one volume all the time.
There are many other ways to hook up sound through your stereo, that is just one cheap and simple one.
Please comment back here to this page if you have any details to add, have any questions, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
May 30, 2011 | Televison & Video
I cannot get sound from the tv to my surround sound system using line out on the tv
Make sure your tv volume is turned up loud enough to hear through your stereo.
Or if your tv's REAR AUDIO OUTPUT LEVEL is set to FIXED, then make sure your stereo's volume is turned up enough too.
Just some simple tips, but everybody forgets once in a while.
Good luck.
Jan 28, 2011 | Televison & Video
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
Volume on jvc home stereo receiver cuts off at a certain level
I had the same problem and found that when I moved the speakers apart further...It works as well as it always did before my 8 speakers were introduced..I think the sound was interfering with itself.. Try it !!
Jan 18, 2009 | Audio Players & Recorders
Sound is ridiculously low
if it is a stereo tv, there should be rca jacks on the back of the tv [red,white yellow] try connecting the rca outputs to a stereo system and see if the volume is any different.there might be a loose connection to the tv speakers inside.if you have a cable box hooked up to your tv, check the connections in back. you can also try bypassing the cable box by connecting the cable wire directly into the tv to see if it's the tv. if it is the cable box try unplugging it for a minute then hook it up again.i had the same problem with my cable box. hooking it up to a stereo system sounds like a pain, but at least you will have sound.
good luck
wg
Jan 30, 2008 | Toshiba 32AF44 32" TV
No Audio Out to Stereo Reciever
First have you went in menu and check audio to see if you are on the variable audio or external output? Check to see if this makes a different with audio jack hookedup correctly of course!
Sep 11, 2007 | Hitachi 51F510 51" Rear Projection...
RCA Audio Out not working?
You don't say whether you're successfully getting sound out of your stereo or not. I'll assume for the moment you are. Still getting sound out the TV is perfectly normal - RCA plugs have no mechanism for automatically disconnecting the built in speakers (in this respect, they're different from a headphone socket). Solution should simply be to press the mute button on the TV remote - although this will silence the TV speakers, you wouldn't normally expect it to affect the RCA output (failing that, just turn the TV volume control right down). A.
Apr 21, 2007 | Akai LCT2701TD Television
Denon AVR-1513 Logo
35 people viewed this question
Top Denon Televison & Video Experts
Jonathon summesfield
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
