Question about JVC Remote Control RM-STHD5J p/n:RMSTHD5J
Program Emerson Tv
Is there a code to program my JVC RM-STHD5J to control my Emerson TV
  • 13 Answers
SOURCE: jvc remote control
"i already paid for the tv so why pay for something that should be readely available to me in the first place I should have access to all the features on the tv ".. WRONG!!!!!!!!!You should have a warranty for this TV but it's old , anyway. First,receive a reference image (let's say CNN).Second:press "Sleep Timer" key and set the value to "0". Then press "Display" and "Video Status" keys at the same time. Third: use "Vol +/-" and " Channel +/-" to select "2.DEF(D)".Go to "D03: V.SIZE" and modify step by step the value for best fitting. There is also switch " SW401" on the main board for centering the image . Finally, press "EXIT" key till you exit the "Service Menu". Don't try to modify anything else!!!!!!!!!!!!!!!!!
Posted on Nov 20, 2007
  • 579 Answers
SOURCE: Opening the case of a JVC Remote Control
Not having seen that particular one, remote cases usually have a couple screws under the battery to lock the case together and then a number of plastic tabs around the perimiter that hold the joint closed. find the screws (sometimes they hide them under labels) - I don't know what it is about screws that manufacturers don't like to show. Either think they are not cosmetic or don't want us take-it-apart maniacs to get in. Anyway, get the screws loose then (this is the hard part) carefully pry open the case joint, feeling where and how the tabs snap out and then be careful not to have everything inside go flying when the last one lets loose. Almost impossible to not leave little gouge marks in the joint.
Hope Ya Fis It!
Posted on Jan 08, 2008
chrisbowden
SOURCE: Need instructions on programming
JVC offers the manual through their website:
See this link:
http://books.jvcservice.com/booklist.asp?Model=XV-N50BKJ
That's for the DVD player XV-N50BK. Check your model number before going with that manual. If that's not your model number, look on the left side of the page where the link is at and you will see a link for getting user manuals. Just enter in your model number and it will give you a PDF that you can download, save, print... whatever.
Posted on Dec 21, 2008
  • 10 Answers
SOURCE: remote control code for jvc tv
HERE IS SOME CODES FOR THAT TV 557 558 559 560
Posted on Jan 11, 2009
SOURCE: How I can program ViewSat remote to control JVC TV Volume
You need to hold down TV until all the lights on top cycle through. Then TV button should stay lit up. Press the channel up button do this with the TV on until the TV shuts off then press ok.And you should be good to go.
Posted on Apr 06, 2009
Program a JVC remote to operate a SONY CD/DVD Player (DVP-NC85H)
Becuase this model IS a DVD player, the remote controller will not allow another of the same type. This remote can be programmed to control a TV, Cable Box, DBS tuner, and VCR. It will not control VHS or another DVD player
Sep 18, 2014 | JVC Remote Control RM-STHD5J p/n:RMSTHD5J
Jvc hd-56fn97 tv but need codes for universal remote jvc rm-svd701u
try but this may not work and if programs at all be missing key features.
Nov 29, 2012 | JVC HD-56FN97 56" Television
How to program JVC Remote RM-SXV067A Remote to TV
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jun 20, 2012 | JVC RM-A5 Remote Control
CODE FOR CHUNGHOP REMOTE FOR JVC TV
Hello
Setup codes for JVC TV with Chunghop RM-962 universal remote control are:
0077 / 0119 / 0178 / 0179
OK.
Jul 14, 2011 | Universal Remote Control Remote Control
I have a jvc television and bought a universal remote. i dont know the code for the remote. do you know the code?
These are the steps on how to program your Universal Remote Control to your JVC TV even without the list of code.
1. Manually turn ON your TV.
2. Press and "HOLD" CODE SEARCH
3. Press and release the TV button you want to set up
4. Release CODE SEARCH.
5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the TV turns off, press and release ENTER.
7. With the TV on, press any other button. If the TV responds, no further programming is required. If the TV does not respond, repeat steps 1-6.
Jun 14, 2010 | JVC RM-C18G-1H Remote Control
Problem to program my remote control
Try using the guide to help you with this problemm if you dont have one, try going to a local store that sells this product.
Aug 24, 2008 | JVC RM-C18G-1H Remote Control
Need updated codes for RCA RCR860 remote control
I have a Phillips TV and need the code for that. I have the manual but it only lists RCA, Sony, JVC, Panasonic, Toshiba, and Sharp.
Jan 22, 2008 | Motorola Mobility DRC800 Universal Remote...
Sony Rm-v202 remote the tv/video doesn't work
I need the code for operating an emerson television
Nov 19, 2007 | Sony RMT-V202 Remote Control
JVC Remote Control RM-STHD5J p/n:RMSTHD5J Logo
13 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
