Question about Shurflo Pumps 8005-233-236- Shurflo
Power Problem? power to pump, will not pump. I've got 110V to the pump, nothing happens
  • ronandchi Apr 02, 2014
    Hi Curtis Burt, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
What will happen if inserted the 110v input d-link wireless router power supply to a 220v outlet? does my router busted or just the power supply?
Most likely you have damaged not only the power supply but also the D-Link wireless router unless the power adapter is a multi-voltage power adapter. Check the label on the power adapter and if the input voltage is a fixed 110 volt power supply you are in trouble.
You can try getting a 110v power adapter and connect it into the D-Link and if it works then you are lucky.
Dec 29, 2012 | D-Link DIR-615 Wireless Router
No power at all
Check the capacitors in the power supply, check for any bulged tops. Your problem is most likely power supply related.
May 21, 2012 | Televison & Video
What is most likely the problem when I push power button and I get nothing, no response at all, Power supply or Mobo ?
First of all, I'm assuming that you've connected everything correctly. I would think if absolutely nothing happens, it's probably the power supply. If a motherboard is bad, the power supply will still flip on, you'll hear the fan, and then nothing will happen. So your best bet for fixing this is replacing the power supply. Possibly with one that has a higher wattage.
Jul 29, 2011 | HP Computers & Internet
Hello, This is Gouthami who has recently purchased a Singer confidence 7470 in ebay which was parceled from USA to Australia. I just got it and while I was plugging it on, I saw a spark by which I...
Did you check if it was a 110V machine before you purchased it??
USA appliances are 110V so good chance by plugging it in in Australia's 240V electricity supply without putting a voltage adapter between you've fried it.
Check the plate on the machine beside the power in point - if it says 110V then you are going to have to buy an adapter (try **** Smith) to use this machine in Australia. However, if you saw sparks then good chance you've fried something already in the machine.
There are a very few quality machines that were made with Dual Voltage such as some of the Elna Stellas and they have a switch in the base of the machine to switch. But certainly not all and you can assume that most appliances coming from USA would be made for 110V power supply only.
Apr 29, 2011 | Sewing Machines
My Emachine was in storage for awhile, I brought it home hooked it up Hit the power Button and Nothing happened!
Check the power switch on the power supply. If it has one make sure it is on (1) and not off (0). Also check the red ac-type switch, make sure it is on 110v and not 220v. Good luck!
Dec 29, 2010 | Computers & Internet
What will happen if I plug my 110V tv into a 220V receptacle?
If you want to fry your electronics or appliances that's it's a sure way to accomplish that.
While appliance working ONLY at 220v will just not work or under perform (like a hair drier) when plugging electronic equipment that runds ONLY at 110v then that item will be "fried" as all its electric components will be burnt as it will receive twice the power that it was build to receive. Should that happen the safety switch on the 220v circuit where the item was MISTAKENLY plugged will be triggered (hopefully or there will be risk of fire and serious injuries, even death) and the power will be shut off. That's a major but possible mistake.
If traveling abroad those who come to US will unlikely damage their appliances (like electric razors) as they will receive less power (110v vs 220v) and usually these items are protected against these mistakes by the specifications of their own design. The opposite is not true of course as just mentioned above.
So do not play around with dangerous items please! ;) On a positive note though: Nowadays most appliances have dual power and should work whether plugged in a 110v, 60Hz (most common in US) or 220v 50Hz (most common in Europe). So nothing really happens... it just works as long as you have the proper adapters to plug the appliance to the different receptacles.
Note: One of the differences is that (without going into the math of it all), an appliance working at 110v will draw x2 times the power than it draws when working on 220v so if an appliance was drawing 3A at 110v it will only draw 1.5A when working at 220v.
Best.
Jul 05, 2010 | Televison & Video
Power supply malfunction
http://i38.tinypic.com/2mqw58l.jpg
Here's a picture of mine that caught on fire last night.
Aug 04, 2008 | JBL Venue SUB12 Subwoofer
Kenmore electric dryer won't start
The first thing I would check would be the door switch. Dryers operate on 220 volts. Many brands split the 220v into 110v for controls and motor and 110v to the heater. There are also safety systems on many brands that won't allow the heater to come on if the fan motor is not running and blowing air throught he element to prevent overheating and dryer fires. If the door switch is ok, check the belt. If the belt is ok, it could be a problem with the motor start switch. The motor start swith is complicated fix and should be done by a professional. ALWAYS BE SURE TO DICONNECT THE POWER BEFORE ATTEMPTING ANY REPAIRS.
Mar 24, 2008 | Estate TEDX640JQ Electric Dryer
Power outlet
Here is the specification sheet for that machine. Look at the power section.
http://www.patriotgroup.com/colorcopiers/af6513specs.html
Oct 22, 2007 | Ricoh 6513 Copier
Shurflo Pumps 8005-233-236- Shurflo Logo
Top Shurflo Pumps Plumbing Experts
Donni Steen
Tom Chichester
Are you a Shurflo Pumps Plumbing Expert? Answer questions, earn points and help others
