Depending on what modchip you used, sometimes DVD Playback can be lost, you need to ensure that your modchip supports DVD playback but there is a way around this, now that you have a modded system you can run arbitrary code and .elfs, just google "Free MCBoot for ps2 slim", after its setup download the media player for ps2 burnt it on a cd rom or put it on a pendrive and run it, Hope this helps...
Is it your own copy or is it a standard cd?
Sony are renowned for not playing copies.
Try cleaning your cd and check setup menu making sure cd is turned on for playing
hi you lost decoder driver on you pc . you get free software decoder , and get play any dvd/cd . you download free software decoder and install and ready play. byeeeeee
My understanding is that the DVD player uses a different lens to the CD player. So the DVD lens might need cleaning. A CD lens cleaner would not correct the DVD side.
Before performing any operations, make sure of the following:
? Check the connection with the TV.
? Turn on the TV and select the correct input on the TV to view the pictures or on-screen indications on the TV screen.
? For DVD playback, you can change the Setup menu setting to your preference menu...
Alos, make sure thay the system and disc region code numbers are incompatible:
The following discs cannot be played back: ? DVD-Audio, DVD-ROM, DVD-RAM, DVD-R, DVD-RW, CD-ROM, CD-I, (CD-I Ready), Photo CD, etc. Playing back these discs will generate noise and damage the speakers.
* Note on Region Code DVD players and DVD Video discs have their own Region Code numbers. This system can play back DVD discs recorded with the color system of NTSC and PAL whose Region Code numbers include ?3.?
