Question about Dacor Ovens
Broil LED light stays on
The broil light in the control panel is on and won't go off. It's a duller light than the one when the broiler is operating. The oven is still working.
    Prodigy:
    An expert who has answered 500 questions.
  • Dacor Expert
  • 650 Answers
It is possible that the lamp is being powered through a ground loop in the stove or a contact in the control, is not disengaging. The lamp is possibly a neon bulb and I have had this happen . It is usually not a big concern and difficult to track downif it is a ground loop.
Posted on Mar 29, 2014
SOURCE: Broil turns ON when pressing BAKE button on RBS275PD Whirlppol oven
Our Whirlpool oven just started doing the same thing!!!! The Delay Start Time (setting it for one minute ahead) and then Start works just fine.  But we fried the tops of three loaves of homemade bread!!!!
Is Whirlpool just a bad brand for ovens?
Posted on Feb 17, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE mod.JDS27G0P2BG Oven Wont start
You have a bad electronic control board.
No repair.
It must be replaced.
Posted on Feb 21, 2009
  • 22 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Posted on Apr 25, 2009
EllaWatson25
  • 725 Answers
SOURCE: Jenn-Air range SVE47600W control panel is
We have this part in stock and can send it out to you first thing Monday morning, if you like. We will include installation instructions for you. You can call us from 7AM until 9PM CST Monday through Saturday. We look forward to working with you!!
Posted on Oct 19, 2009
  • 8 Answers
SOURCE: The upper oven works fine. The lower oven won't
Make sure you hit the reset switch first... on top of the lower over... behind the panel...they trip easy and "kill" the oven.
Posted on Dec 11, 2009
Broiler will not work on a whirlpool range rf367lxsyo
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
Apr 17, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Broiler turns to pre heatworks oven doesnt heat when temp
the broil element
Apr 15, 2014 | Kenmore Ovens
Will the oven work without the broiler attached
You could use the oven without the broiler. It is customary that the oven will use the broil element to even out the heat in the oven for better baking but you could use if. it just may not bake evenly. There could be two things that is causing the broil element to stay energized. the control is not shutting down or there is a short to ground in the broil element. Have the broil element tested, it could just need replacing. If it is in the control that is a bigger problem.
Mar 19, 2014 | Ovens
Broiler wont light
the broil element
Mar 17, 2014 | Kenmore Ovens
Broiler element doesn't heat
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on
the broil element
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Feb 09, 2014 | Thermador SEC301 Electric Single Oven
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
My broiler doesn't work in my JennAir S136 range and I think the problem is the selector switch. How can I confirm this?
To do that you could check if the correct power is going to broil element.That can by TURNING OFF CIRCUIT BREAKER, remove door by opening to appx 30 degree position where is shold stay open,pull off door,remove broil element and attach a volt meter set to measure at least 240 volts ac and attach the meter leads to the wires on broil element, restore power set controls to broil and check for 240 vac at element. If 240 vac at element it's the element thats defective, if 240vac not present the selector switch is the problem, espically if bake works
Good luck,i hope this helps ya diagnose your oven
Gene
Jul 31, 2011 | Ovens
Frigidaire GLEB30S8CSB- the broiler doesn't work, all other functions are normal. What do I need to look at? Many thanks...
Unplug the oven.
Remove the oven racks.
Remove the bake element.
Be careful and not let the wires fall back into the holes when you remove them from the element.
Use a volt/ohm meter set for ohms or continuity to check the broil element terminals.
No reading is a bad element. If no reading replace the element.
If the element is good the control panel will have to be opened to check for power from the electronic control to the element.
Re-attach the broil element.
Access the control module for testing.
At this point you will be working with live high voltage.
Turn the power back on.
If you are not comfortable with that please call a service technician.
If you want to do it,locate the broil out put wire and the neutral wire on the control. Set the control for broil,place your meter leads on broil and "N".
No reading is a bad control module.
A good voltage reading will be a bad wire to the broil element.
Mar 11, 2010 | Frigidaire GLEB30S8A Electric Single Oven
Frigidaire FES367ASE Slide in range
Someone mis-wired the new control. Turn off the power to the range. Open the control console,switch the bake and broil wires on the oven control.
Sep 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
Roper drop in range broiler will not light
YOU HAVE A SHORT ON THE BROIL CIRCUIT PROBABLY ON THE ELEMENT IT IS ELECTRIC CORRECT?
Jan 07, 2009 | Ovens
Ovens Logo
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
