Question about Gateway M Computers & Internet
Screen will not turn on but fan does
The power light charging light and wifi light come on as well
    Problem Solver:
  • 9 Answers
Try hooking up an external monitor, if you can. Be sure to close your laptop so it will recognize the external monitor as the main.
Posted on Mar 29, 2014
New Samsung Galaxy Note 10.0 battery life and charging time
Sounds normal to me!!
The further away from wifi router you are the more power is needed by the wifi card.... etc etc so the 8 hours is in perfect conditions with the screen brightness at minimum and no apps running!! It's safe to say that, whatever battery life is quoted for any device you should only expect to acheive half that in the real world.
The screen is prob responsible for 80% of the battery's power drain. Turn the brightness down. Stay in same room as router. close down un-used apps that demand cpu and network (wifi card) time.
Shut it down completely when charging don't just let slip into standby. Also don't charge it on a cold or hot place such as a window sil. To high or low tempretures will increase charge time and will damage the battery lowering it's capacity.
May 30, 2013 | Samsung Galaxy Note 10.1
Toshiba satellite L305-s5955 power turns Problem with the PC Laptops Toshiba satellite L305-s5955 power turns on, fan turns on. screen stays black. Will not power off with button. Power supply working....
Hello Kristi,
I'm not sure if this will work, but worth a try. It appears that your power up settings have got messed up somehow.
Put it all back together, batteries and charger. It will try to boot after a fashion. Just give it a couple of minutes to try and do what it should. If it still hasn't come on properly, press and keep pressed the on/off button until the laptop turns off (about 5 seconds). Leave it a couple of minutes then try and turn it on again normally.
After this, I'd need to be able to look at what's happening to help any more.
Sep 12, 2011 | Computers & Internet
I was using it and turned it off and i came and turn it on and hp logo didnt appear on the screen it was only the lights and blank background please help me.is my sisters laptop and i took it without...
well. be sure the power is plugged in
then pull the battery out of the laptop
press the power button down
look at the little lights indicating power on .. battery charging and hard drive activity
if the power light comes on..
then the screen is the problem
if the hard drive comes on after say 10 seconds
it is definitely the screen
put the battery back in.. be sure it is in solid
put the power pack in the wall
if the battery charge light comes on
then the power is to the laptop and battery connections are good
so the laptop may have overheated...
wait five minutes
try to power it on again
if the fan does not power on...
it has a bad fan...
quietly set it where ya got it from then
Jan 21, 2011 | HP G60-235DX Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
My Dell Latitude D620 Screen is Black and the keyboard dosent work when I turn on the computer. The only LED light that shows is the power light, the wifi or the little cylinder light dosent work. I can...
remove all attached devices like printers or flash drives. remove battery and power on using ac adapter only. if it still wont work, try another good ac adapter. make sure ac adapter light is on. if it still shows the power light on and nothing else, replace motherboard.
May 15, 2010 | Dell Latitude D620 Notebook
Acer 3100 laptop lights on fan on slow but no screen
Remove the battery and disconnect the Ac adapter from the laptop. Press the power button and hold it for 10 seconds.Reconnect only the Ac adapter and power on the laptop.
Post back if the above solution doesnot work , it could be bad video card driver.
Thanks for using fixya
proton
Aug 12, 2009 | Acer Aspire 3100-1405 Notebook
Acer aspire 1640 wont boot up
TRY TAKING YOUR BATTERY OUT FOR 15 MINUTES THEN PUTTING IT BACK IN. IF IT COMES BACK ON, RECALIBRATE YOUR BATTERY BY LETTING THE BATTERY GO DOWN TO 5% THEN PLUG THE POWER CORD IN. YOUR BATTERY MAY NOT BE STRONG ENOUGH TO TURN THE SCREEN ON, EVEN THOUGH YOUR BATTERY METER SHOWS IT HAS A GOOD CHARGE. QUICK CHARGES OR FREQUENTLY UNPLUGGING IT CAUSES THE BATTERY METER TO READ DIFFERENT THAN THE AMOUNT OF CNARGE THE BATTERY IS ACTUALLY HOLDING. RECALIBRATING IT WILL GET THE METER AND THE BATTERY BACK ON THE SAME CYCLE.
Jun 08, 2009 | Acer Aspire 1642WLMi Notebook
Screen not turning on.
hold the power buton for 20s so it will restart
Jan 27, 2008 | Archos 605 WiFi Digital Media Player
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
