Question about Hotpoint Dryers
Hotpoint Aquaries dryer no heat
No heat at all only cool air
  • 822 Answers
Element and or thermostats
cheers
Posted on Apr 30, 2014
kjmac
  • 97 Answers
SOURCE: hotpoint CTD00 condenser dryer not heating up
sounds like a thermostat fault, there is two on these machines and although only one will be at fault both should be replaced
Posted on Jul 25, 2008
protek480
  • 1723 Answers
SOURCE: dryer is working but won't heat. Its just blows
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, whcih requires
replacemant.
Posted on Jul 05, 2009
rylee_smith
  • 8619 Answers
SOURCE: my gas whirlpool dryer won't heat. Cool air does
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jul 06, 2009
  • 534 Answers
SOURCE: Model NVLR333EVOWW Not heating up
your element has burnt in half where the sparks are coming from is the end of the element touching the metal. You need the model and serial number go to the nearest appliance parts supplier and get a new element they aren't that hard to replace. Always make sure you disconnect the power source before doing any repairs to the dryer. Good Luck
Dave
Posted on Jul 22, 2009
Richie_asg1
  • 1036 Answers
SOURCE: Hotpoint ctd00G will not heat up
This is most likely the thermostat switch or possibly the heating element itself.
One or the other is likely needing replacement.
If you are competent at electrical repairs, and have a test meter; Unplug and move to allow access.
Undo rear top screws and remove lid.
Heating element is usualy on top. Disconnect leads and check continuity of switches and element.
Replace switches with similar if either are open circuit. Available as spares from online parts centres.
Heating element should read in the low Ohms - around 20 - 35 Ohms if Ok, otherwise replace.
ONLY ATTEMPT REPAIRS IF COMPETENT (I have to say that)
Posted on Sep 23, 2009
Where will I find the heat reset button on my tcm580 condenser dryer
Hello Mandy, I am not sure what you mean by a heat reset button; perhaps explaining what the problem is, I may be able to assist you. Are you referring to the dryer motor's overload reset button? As a safety feature, a dryer has a high-limit thermostat and either a thermal fuse or thermal cut-off fuse.
In the event of poor air flow where there is no proper ventilation to the heating element- the internal temperature of the dryer exceeds its high-limit, the dryer will shut-down; once it cools off, you should be able to run it again.
However, if the thermal fuse (located on the blower housing) or the thermal cut-off fuse (located on the heater housing) goes, the dryer heating element will will not heat up or the dryer will stop running altogether.
Please note, a dryer will have either a thermal fuse OR a thermal cut-off fuse, but not both.
By-the-way, there has been a recall on certain models of HotPoint Creda, and Indesit tumble dryers due to a fire hazard risk; I am sending you the link...If your dryer is manufactured by HotPoint model TCM580, then your dryer maybe affected. Read the info in the link- it'll give you instructions on how to determine if your specific dryer is affected and what to do.
http://www.which.co.uk/news/2015/12/113-hotpoint-indesit-and-creda-tumble-dryer-models-pose-fire-risk-426557
http://www.itv.com/news/2016-04-18/hotpoint-dryer-fire-risk-which-models-are-affected
Feb 15, 2017 | Dryers
Hotpoint dryer model DLL2650BFLWH not heating
If this is an electric dryer, your heating coil has broken and is no longer conducting current and heating.
Oct 27, 2012 | Hotpoint TDL15 Electric Dryer
My Hotpoint gas dryer won't relight after it has
Your gas valve electrical coils have gone bad. They are easy to replace.
Jun 21, 2011 | Hotpoint Dryers
Hotpoint dryer wont get hot
This condition is normally cause by a faulty thermostat...
Sep 22, 2009 | Hotpoint NWXR473EV Dryer
Dave
Jul 22, 2009 | Hotpoint NVL333EY Electric Dryer
The dryer sometimes heats up to dry the clothes and sometimes it is just cool air. The drum still turns
I had this problem on my Hotpoint dryer and it turned out to be the timer.
Jun 16, 2009 | Hotpoint Dryers
No heat, clothes do not dry
the model number that comes up is DLL2650BPL you could have a bad igniter,gas coils or sensor but the only way to tell is by reading them out with a meter the igniter part number is WE4X444 gas coils are part 5303931775 and the sensor is part WE4X448 you can go here to see parts
https://www.repairclinic.com/Shop-For-Parts/a8b95d49280/Model-DLL2650BPL-Hotpoint-Dryer-Parts
if you have heat at the beginning and then no heat it will be the gas coils but one of the coils still could be bad and not work at all but check all parts with meter before you start ordering parts you don't want to change out good parts.
Feb 09, 2018 | Hotpoint Dryers
Dryers Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
