Question about Ascend FS12 Sit In Angler Kayak - Camo
The inside were the chair locks to the kayak the plastic has ripped
  • Chester Gayheart
    Chester Gayheart Mar 31, 2014
    The kayak is made were the seat has a slot to slide in. When I purchased the kayak putting the seat in the slots took 2 people and I think that either the boat was make too wide .
Can a valve on an inflatable kayak be replaced?
Almost certainly, if not with a spare part from the kayak manufacturer or dealer, then with the aid of modern adhesives or plastic welding techniques a similar valve could be grafted in. If all else fails a suitable schrader type could be fitted.
In the days when car and truck inner tubes were popular a range of schrader valves was available moulded into a large circular patch intended to be either vulcanised into position or cold welded.
Sep 05, 2014 | Boating
Want to buy ascend kayak chair
called a 'kayak-seat' they are available online for about $100-$150 for a good one.
Jun 25, 2014 | Ascend Boating
How do I drain my Future Beach spirit 120dlx kayak
I recommend that you will post your question under the correct category (kayaks) and maybe add more details to it, so it will be easier for Experts to understand the question and answer it.
You can also contact the site directly: futurebeach.com/index.php/contacts/
Oct 01, 2012 | Garden
Rip in kayak
try underwater epoxy
Jul 15, 2009 | Sevylor XK2 - SVX200DS Kayak
Dent in hull of kayak
umm....plastic or composite? If it's plastic, sit it out in the sun or carefully heat the dent with a heat gun and gently push it back out. Happens all the time.
If it's a composite or a rigid plastic kayak, you have a nice repair job ahead of you that won't fit into this space comfortably.
Jul 12, 2009 | Ocean Boating
Thule car bag rip...needs repair
Probably a fiberglass repair kit, available at most hardware stores. Let it cure longer than required prior to sanding. Then paint as required.
Jul 02, 2009 | Da Kine Car Rack Pad Set Surfboard Bag...
Hole in my Kayak.
Plastic weld it or use plastic epoxy.
Apr 04, 2009 | Wilderness Systems Tarpon 140 Kayak
Which kayak to buy
Plastic and fiberglass are the two materials the majority of kayak manufacturers are using today. Plastic kayaks are lower priced, have the largest selection of models and are known for being tough. The down side of a plastic hull is that it doesn't hold an exact shape, it's softer (therefore slower). It's close to weighing the same as fiberglass but you can't perform field repairs on it. Fiberglass is approximately $1000 dollars more for the equivalent-length plastic boat, but the hull is much stiffer, faster through the water and you can repair it. The down side to fiberglass is that it's more expensive, and if you drop it off the top of your car, you can crack it
Dec 01, 2008 | Wilderness Systems Pungo 140 Kayak
Ascend FS12 Sit In Angler Kayak - Camo Logo
80 people viewed this question
Top Ascend Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you an Ascend Boating Expert? Answer questions, earn points and help others
