Question about Toshiba Satellite C55-A5242 Intel Celeron 1037U 1.8GHz 15.6" Windows 8
Laptop shuts off when you unplugg it and wont turn on with out the charger
My laptop is literally a month old it was fine yesterday when I was using it unplugged but tonight I unplugged it to move to another room and it completely shut off and wouldn't turn back on unless the power cord is plugged in. I don't understand why it is brand new! Help please!
  • Chanda Topper
    Chanda Topper Mar 28, 2014
    Well problem solved my husband came home and took his laptop batter and put it in my mine my battery is junk already only a month old and the battery had alread died sad..
    Scholar:
  • 63 Answers
The battery can be replaced under warranty. Contact the manufacturer and they will process the replacement, usually cross-shipped for free with good manufacturers.
Posted on Mar 28, 2014
Won't Charge
If it's not a recognized charger it'll stop charging the battery and try to run on the charger alone. If the peak draw of the laptop is higher than the charger output, it'll go right back off.
Try removing the battery and see if it'll boot on the charger alone.
Apr 01, 2014 | ASUS Q200e Touchscreen Notebook
My laptop wont start up but led's do Acer Aspire 8735z
It sounds like your power button could be stuck, or shorted out. Try cleaning your buttons with rubbing alcohol to remove gunk. Stuck keys can cause all sorts of problems.
Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Jan 09, 2014 | Computers & Internet
Flashing orange laptop light on samsung laptop
If your battery is six years old, it has done very well and you have looked after it. I would think that a new charger will fix your problem.
Dec 21, 2013 | Samsung R519-53S Notebook
Dell Xps 15 Laptop Battery Not Charging
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Dell XPS 15 AC Adapter Charger
Nov 01, 2012 | Dell XPS Computers & Internet
My Toshiba c650-18k laptop is just 1 month old i was playing on it and when i went to shut down before shutting down it turned off automatically and when i tried tom turn it on it is not turning on.I tried...
It sounds like your charger is not working. If you can check the voltage out of the charger or if there is an indicator on the charger that would be my first place to look. Only do simple checks as the and it should still be under warranty being only a month or two old. If you have another charger that would fit then try swapping it out to get you going in the short run. You can always warranty old charger. Or if you bought it locally consider returning it to the store.
Jan 09, 2018 | Computers & Internet
Tochiba laptop wont turn on. 4 months old. I brought a new charger charger light on battery light on. Push on off it flashes and turns straight back of/ any suggestions. Need it for presentation...
Not the best time to try and use a laptop you've been having trouble with. Go to toshiba.com to get their phone number or tech support chat because your laptop should still be under warranty.
Sep 27, 2010 | Computers & Internet
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
Toshiba Satellite C55-A5242 Intel Celeron 1037U 1.8GHz 15.6" Windows 8 Logo
81 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
