Question about Dryers
De08 us1 replace the drive belt on a DE08
5 Suggested Answers
SOURCE: I own a FP dryer model DE08-US1, and it is making
I suspect your drive belt is slipping or a worn bearing, you need to have this checked by a Qualified serviceman. Get a firm "Quote" before proceeding.
Posted on Feb 01, 2010
hunter19_46m
  • 7482 Answers
SOURCE: my fisher and paykel model
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Dec 31, 2010
  • 3074 Answers
SOURCE: My fisher 7 pPaykel dryer is making a loud whining
check your drum rollers/glides, and idler arm assemblage:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Posted on Feb 25, 2011
heatman101
  • 43501 Answers
SOURCE: Fisher Paykel Dryer Model DE08-US1. Dryer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jul 24, 2011
Model de08-us1
-The seal is shrink so every gap is over size.
-The only thing will eliminate this problem, replace new seal.
Good Luck
Mai
Dec 19, 2013 | Fisher and Paykel DEGX1 Electric Dryer
I own a FP dryer model number DE08-US1, serial number VF740275A. Recently the dryer has been automatically starting when I turn the drying dial to any of the drying options (Automatic cottons, automatic...
I really hope the problem is the start button is defective, it is stuck on. You would need to get a new one. Bad news is, that is a little bit more rare than the timer itself being messed up . Those are quite expensive.
Be blessed.
Sep 01, 2013 | Fisher and Paykel DEGX1 Electric Dryer
Fisher Paykel Dryer Model DE08-US1. Dryer won't start. When pushing the start button, there is a "humm" from the electric motor - like it's trying to start. Very sudden problem. ...
heatman101
Jul 18, 2011 | Fisher and Paykel DEGX1 Electric Dryer
I own a FP dryer model DE08-US1, and it is making a high-pitched squeking noise and smells like burning rubber--please help.
Jan 31, 2010 | Dryers
Belt over pullies correctly
they should be on a tensioner that automatically tightens check the spring on the tensioner if it is weak replace it they usually last the life of most dryers however you have a commercial one so Lord only knows how many hours a day it runs
Dec 19, 2009 | Fisher and Paykel DE08 Gas Dryer
Dryer wont turn on
turn your breaker off the on
Dec 31, 2007 | Fisher and Paykel DE08 Gas Dryer
This is electric dyer. Wont Start.
the clank and thud may have been the bracket with the wheel on it hthat keeps the belt tight. when you shut the door and push the start button what happens?
Nov 03, 2007 | Fisher and Paykel DE08 Gas Dryer
Dryers Logo
23 people viewed this question
Top Dryers Experts
