Question about Cobra Radio Communications
How to set a cobra 29 back factory
How do u set a radio back to new
    Novelist:
  • Cobra Expert
  • 500 Answers
Make sure d11 isn't cut. and then you need a service monitor or use signal generator and oscillascope, and follow the service manual to align back to factory specs.
Posted on Apr 01, 2014
Dodgem250
  • 68 Answers
SOURCE: Cobra 29 LTD Classic Operations Manual
For the operation manual, go to cobraelec.com or:
http://cobra.com/downloads/manuals/29LTDCLA.PDF
Thanks!
Dodgem
http://dodgem250.angelfire.com
Posted on May 10, 2008
Benimur
  • 6966 Answers
SOURCE: New radio
Assuming no hardware faults, start with the basics, on powering on the radio:
1. RG Gain max clockwise;
2. Ch 9/NOR to Normal;
3. Delta Tune to mid position;
4. CB/PA to CB;
5. Squelch to minimum counter clockwise;
6. Channel selector to desired channel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 30, 2008
Benimur
  • 6966 Answers
SOURCE: scematic
Hi and welcome to FixYa,
Pls click on the schematic diagram for a Cobra 29LTD.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 18, 2008
  • 40 Answers
SOURCE: Replacing The Cobra 29 Nightwatch Illumination Panel
YOU CAN ORDER THAT PART FROM COBRA ELECTRONICS ON THE INTERNET YOU HAVE TO REMOVE THE FACEPLATE AND UN HOOK THE DRIVET INSIDE THE RADIO IT LOOKS LIKE A SMALL RIBBON CABLE THAT GOES TO THE FACEPLATE. SOME TIMES THE DRIVER ITSELF IS THE PROBLEM. MANY SHOPS JUST DO NOT WANT TO FIX THEM BUT I DO.
Posted on Mar 13, 2009
  • 773 Answers
SOURCE: cobra 29 ltd classic antenna calibration ??
Wow. That's not at all a solution to what this guy is asking. And why all the caps??
The one point jm77437 has that is correct is that you do not set the radio, you set the antenna. The rest is blah blah.
Here is how you tune your antenna for you radio. First off it depends on what kind of antenna you have. most fiberglass antennas have a tunable tip to adjust the height of the antenna. Metal whips either have a collar at the base that the whip will either slide up or down in to adjust the height. The other type of metal whip's you have to physically clip to shorten the antenna, you must be careful with this type because once its clipped, that's it. You cannot add what you cut off.
I am going to give this example using a metal whip with an adjustable collar.
First after your radio is hooked up in the vehicle, drive to an open lot. Buildings and other structures can cause extra reflection. turn to channel 1. Flip the meter to CAL. Key the mic without talking. Now turn the CAL knob up until the needle reaches the little upside down triangle all the way to the right marked CAL. Now you have just celebrated your radio for your setup to measure you SWR. Now while still holding the key, flip the meter switch to SWR. The needle will move, and where it stops is your SWR reading. The lower the better. Anything under 1.5 is considered really good. But still, the lower the better.
Make note of what your SWR was on ch 1.
Now flip to channel 40. Repeat the SWR process. You must recalabrate each time you take a reading.
Now like jm77437 said. If your SWR reading is higher on 40 then 1, then your antenna is too long, and you must make it shorter. Loosen the collar and lower the antenna in the collar 1/4 inch at a time. check the swr each time you adjust the antenna.
If your SWR reading is higher on channel 1, then your antenna is too short. You must make your antenna longer. Do this by loossening the collar and pulling the antenna upward in the collar 1/4 inch at a time, again checking the swr each time you adjust the antenna.
What you want to achieve is having the same SWR reading on channel 1 and 40. then you have the best match you are going to get with that antenna.
If your swr is under 1.5 on all channels, you don't need to fuss unless you are a perfectionist. then by all means go ahead.
If your reading is higher then 3, or your ant light comes on, something is really wrong. Make sure your antenna is connected all the way, and the coax is not damaged.
Its important to have an appropriate SWR because if you do not, you are reflecting too much signal back into the radio, and eventually you will burn out your final transistor, and your radio will be toast.
Some tips: make sure you check the swr with the doors and windows shut. Make sure you are in an open lot. Remember to calabrate ecah time you take a reading. If you have had your radio peaked by a radio shop, and they have lowered your dead key, or have done a swing modification, then the meter in your radio will not work when taking an SWR reading and you will have to use an external meter.
Posted on Apr 24, 2009
Why the clock on the cobra 29 lx keep cutting out
jay I am not sure what you mean by the clock cutting out. I enclosed the manual in PDF form look at page 17 and see if this helps. If not ask the question with more detail.
https://www.cobra.com/sites/default/files/manuals/29%20LX.pdf
Oct 05, 2014 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
Cobra 29 cb radio not responding with 1 thru 22 channels.
is it used? if so it may have been hacked for more channels and no one finished the work.If its new send it back to cobra .its under warrenty
Feb 06, 2014 | Cobra 29 LTD CB Radio
Cobra 29 LTD LX LE vr pots
vr1 "s" 9 setting on the tx meter vr2 voltage setting vr3 squelch vr4 amc vr5 p4 display on tx signal meter.
Mar 22, 2013 | Cobra 29 LTD CB Radio
My cobra 29 lx won't go off of channel 1
what else did you do to mess up this radio.
Feb 23, 2013 | Cobra 29 LTD CB Radio
Every time i turn on my cobra 29 wx nw st sound tracker it goes back off
Hi Davis, please post on CB radio forum, this is Radio scanner forum.
Cheers,
Peter
Feb 20, 2013 | Cobra 29 Wx Nw St 40-channel Nightwatch Cb...
Cobra 29 LX LCD tuneing
brand new out of the package don't need tuning. just turn up the power a bit to 3.8 - 4 watts and modulation set at 95% and you will be fine.
Dec 29, 2012 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
When do you know if you have a decent radio
The 29 has a built in SWR meter--check the match to make sure it is below 2 (lower the better).
The radio can be peaked for better than factory audio.
If the squelch is up too high you will not hear people below a certain signal level---in your case set it so you hear who you want to and not jokers.
RF gain lowers signal the radio sees for receive.
The stock mic will work but make your voice somewhat flat sounding---a power mic or having the mod limiter removed will make the radio and your voice louder.
Let me know if questions.
Jun 10, 2012 | Cobra 29 LTD CB Radio
Does a cb have a effect on auto ignition?
The Cobra 29 LTD has no effects from the factory. Commonly if an aftermarket effect has been installed it may act erratically on startup, for example roger beeps on the 29 tend to activate when you turn the unit on.
Aug 11, 2010 | Cobra 29 LTD CB Radio
My cobra 29 i can not set the swr on the antenna,new swr meter
then there may be prob with antenna system or radio has too low of dead key to operate the meter.
Nov 24, 2009 | Radio Communications
Cobra 29 ltd sound tracker cb
you start by replacing every electr cap as most cb radios live in a hostile enviorment, They ALL suffer from dried up electolite. if the set is old ,that will be you first step,if you are up to speed with desoldering with out lifting copper tracks/etc, no reason why you can't have a go...do not shift trim pots or tuning can slugs
with out marking their factory positions as this can end up in a
mess
CHEERS
Jun 26, 2008 | Cobra 29 LTD CB Radio
Radio Communications Logo
161 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
