Question about Pool & Spa
Powered up spa for the season and heated water. next day went to go in and it was not running.checked breaker and gfci they were ok checked fuse in spa pak and it is blown and dont know why. any help
Blown 20 amp fuse in balboa spa pak
    New Friend:
    An expert who has answered 20 or more questions within one hour.
  • 45 Answers
Let's cut to the bottom line and replace the motor... maybe... or not.
When I was awarded my "Master Spa Technician" certification, this subject of how to diagnose a bad fuse was the final exam question, because it separates the "men from the boys" so to say.
"The Cover Guy" gave you a really good answer, for basic beginning testing. I will take it further... and I will also explain why he told you to call a professional... very good advice by the way.
66O 263 O984 ask for John... that's me. A professional.
But since this is a fix it yourself kinda place, and I assume you want to, ummm, fix it yourself... sit down, and drink a cup of coffee or tea with me and let's chat about your spa for a minute.
Here is a more in-depth line of logic.
Step one: Most electricians can't fix a bad fuse problem by the way so do not waste your time and money with them. Now that that is out of the way, don't stereotype... in 15 years I have met 2 that were capable.
Fuses blow... but not unless there is a spike in the current flowing through them. Because they are sealed they do not corrode, and have no moving parts so they do not wear out... so while Cover Guy's answer is correct, changing the fuse will make it run again, but it may not solve your problem, and most likely will merely buy you time.
This said, it is possible that you had a weak fuse from the factory and changing the fuse WILL solve your problem... but that is so rare that it is nearly unheard of.
Fuses can also blow when the spa experiences an electrical surge from the power lines, and there is absolutely nothing wrong with your spa... so, again, changing the fuse may APPEAR to solve your problem... but not really.
Fuses will blow if the main power lines coming into the spa are too small for the spa, the rule of thumb being no smaller than 6 gauge and no longer than 75' of 6 gauge. 8 gauge does it all the time... and electricians LOVE running spas on 8 gauge wire. In fact rewiring their jobs keeps a good friend of mine in business. So, verify that you have 6 gauge wire delivering the electricity to your spa.
When a fuse blows, you need to ensure that you replace it with the right fuse for your application. Many times people think that they can just stick any old fuse in there and things will work fine, but you cannot do this with a spa. They require a special type of fuse which most hardware stores do not carry.
I cannot tell you how many times in the 15 years I have been repairing and rebuilding spas, that someone called me because they replaced the fuse and it is still blowing, only to go and find out that they are using the wrong fuses because the hardware store guy said "This will work."
Again, the right fuse will not solve a defective electrical component, but it will ensure that you do not compound your actual problem by hiding it behind defective fuses.
Next, if you are not really capable of fixing this yourself, then be humble enough to be honest with yourself and talk to a spa technician, because we are a specialist in this particular field. Electricians, while brilliant at most other electrical things, know very little about how to fix a spa... but they mean well. I qualify to say that considering my pre-spas life was an industrial electrical background.
Anyway, this is why "Cover Guy" said call the pro. Your spa technician will know the specifics of the brand of computer you have, or will know who to call to discuss your specific model with, since there are literally more than 1,000 different spa computers out there. Each different computer may be designed to use the fuses in different ways. Electricians don't have a clue who to call even if they wanted to.
All of that said, let's assume that you are still reading and still are confident that you CAN do this... and you actually can with my help.
Start by changing the fuse.
So, assuming you just changed the fuse with the RIGHT replacement, and it blows again.......
First turn off the breaker. Did I mention turning off the breaker?
If you get shocked because you ignored the above, it is on you.
Now, open your spa cabinet and begin to physically inspect ALL wires and plugs at both ends of the wires to ensure there are no scorch marks, no signs of melted brass in the plugs, nothing is broken, no rodents have chewed on things revealing the bare copper, nothing is in a puddle of water, etc. in other words, everything looks perfectly fine from end to end.
Next, IN THE VERY CENTER, take the cover off of the shaft in the rear of the pump motor and using a flat screw driver, turn the shaft. If it does not turn, or is hard to turn, you have your problem. Take the pipe off of the front and ensure that there is nothing in the hole that is preventing the pump from turning. If you can get the pump loose and turning easily once again, replace the fuse, put everything back together and turn the breaker back on, and hope for the best. If that does not fix it, or you cannot make the motor turn, replace or rebuild the motor... and while you are at it rebuild the pump.
Do the above with every pump.
Next, assuming that was not the problem, and it usually is, then unplug everything else but the heater, and try it again.
If you need assistance beyond this, feel free to call me. For that matter, even if this DID fix your problem call me. I like hearing that I helped. :)
Posted on Nov 10, 2015
  • Liz Schieck
    Liz Schieck Oct 29, 2016
    John you are not in Guelph On..any person you could recommend around here?..thanks liz
    An expert who has written 3 tips or uploaded 2 video tips.
  • 64 Answers
Fuses go from time to time and just need to be replaced. You can also blow fuses with a short in the plugin that is associated with the fuse. A ceased pump will cause a fuse to blow. The best way to deal with a fuse that continues to blow is to isolate what plugin is causing the fuse to blow.
An easy test is to start with all plugins unplugged and then plug each one in until you blow the fuse. Once you find which plugin is the issue you can leave it unplugged and follow it back to the equipment it runs, perhaps the light, ozonator, pump, radio etc.. Then repair the issue or replace it and you should be good to go.
Hot Tub Power Pak Repair We wrote a post on power pak repair you can find here for additional info. As always when it comes to the power side of things it is always best practice to seek the help of professionals.
Posted on Sep 17, 2015
    New Friend:
    Problem Solver:
  • 8 Answers
Overload!! Was it cold out, what does the fuse go to
Posted on Mar 28, 2014
Testimonial: "not sure its on the green panel inside balboa spa pak its a 20 amp time delay fuse"
My 30amp 2 pole gfci circuit breaker keeps tripping right after i reset it. It's connected to my endless pool and has never trip before. Is it a bad gfci ?
Replace GFCI and see if the breaker is bad.
Otherwise, my guess is that you have a short in the pool or pool heating element.
If you have AFCI (arc fault), then a loose wire connection anywhere along the line will trip breaker
Troubleshoot resources:
Water Heater Timers Save Money
Aug 03, 2015 | Electrical Supplies
What to do if lights and system does not come on
First, check to see if the circuit breaker feeding the spa is turned on. Push the breaker handle firmly to the off position then back on. Next check the GFCI protector(if a gfci circuit breaker isn't used). It could be an integrated part of the cord, a gfci receptacle or located in the control panel. Once you locate it press the test button then the reset button. If these proceedures do not correct the problem, it is time to call in an electrician or spa tech.
Aug 01, 2015 | Pool & Spa
Why does the GFCI breaker keep kicking out on my hot tub
The resistance in the unit may be due to inadequate electrical wiring and over heating of the GFCI, due you have a thermal camera, can you check the temperature before and after the unit trips. Most common cause is Length of run, motor does not use much electricity but heater will trip due to over heating, don't over think problem. Check for proper wire size and make sure the length of run from meter can handle load and demand, this may solve your problem.
Jun 24, 2014 | Spa And Pool Store 73790 Hot Spring,...
2001 cal spa blowing 20 amp fuse in Balboa spa pak
Probably a bad pump motor. Drain and refills are notorious for stuff like that.
Mar 28, 2014 | Dryers
Hot tub breaker trips but only when people are in it?
Because it is a GFCI. Try making sure that the grounds are all good. Maybe go the extra step of putting in grounding rods into the ground and grounding to the unit. These are just guesses.
Nov 17, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Qo260gfi not tripping
Question is not fully clear.
2-pole 240Volt gfci circuit breaker requires the white wire be connected to neutral busbar.
Easy solution for 240Volt spa that comes with gfci:
Replace spa gfci with regular non-gfci breaker.
Install 2-pole GFCI breaker in main panel, and connect wire to spa breaker.
Having 2 breakers is not a problem.
Having 2 GFCI on same circuit is a problem.
Apr 18, 2013 | Pool & Spa
My spa depot hot tub keeps popping the breaker
What type breaker?
GFCI or ordinary heat-rated breaker?
Do NOT use two GFCIs on same circuit.
Spa needs GFCI to protect people while immersed in water.
You might have dangerous short, or leaking element, bad switch, bad wiring, bad electrical connection, or undersized wire and breaker.
If breaker is undersized for load, it can get loose on the busbar and then start arcing, and then tripping. Use nose to smell for burning. Feel breakers to see if they are warm. Move wire to different same-size breaker.
Mar 18, 2013 | Pool & Spa
When i turn on my spa and heater it states on the outside unit "no air flow" and it won't heat up
that is usually an indicator of water flow not the air flow.
What does the hot tub do when you turn the breaker from off to on?
does it run through the purge cycle?
is it kicking out the GFCI?
if it is not tripping the GFCI then you most likely have either too little water flow for the heater to kick in or not enough water flow to activate the heater.
Try taking out your filter and see if that solves the issue.
you may also have a bad temp sensor if the tub just runs and runs but never heats up.
US Parts Center
Feb 08, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Mar 15, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Pool & Spa Logo
929 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
