Question about Dryers
2001 cal spa blowing 20 amp fuse in Balboa spa pak
Powered up spa for the season and heated water. next day went to go in and it was not running.checked breaker and gfci they were ok checked fuse in spa pak and it is blown and dont know why. any help would be appreciated
    Problem Solver:
  • 6 Answers
Probably a bad pump motor. Drain and refills are notorious for stuff like that.
Posted on Apr 04, 2014
Have a Balboa Hydra pool spa model #du-hp-the power comes on power to the fuse and all it does is click when you press the Jets or light like a tick fuse is blown on top 1
Balboa Hydra pak?
The problem you stated is not clear.
Check for proper voltage to the main terminal block. You should get 240, reading across both the line terminals, not one to L1 and the other to ground. Across both hots. If you have only a 120 volt system then make sure you have 120 at the terminal block.
Your comment "I have power at..." is very vague. How do you know you have "Proper" power?
Replace any bad fuses with like.
Good luck
Nov 06, 2014 | Pool & Spa
Cal spa not running
Which fuse is it? Fuses protect the board from getting fried when something goes out on your spa. Which fuse is it? Usually when I hear a fuse has been blown, I start looking at the pump motors, or ozonator etc. You might go through some fuses but unplug all the spa accessories from the pack and re insert one at a time until the one you plug in blows the fuse. That will be one that has the problem. Let me know what you find.
Mar 28, 2014 | Pool & Spa
Hot tub heating
If your hub is in warranty so you can replace it it can be hardware problem.
Sep 28, 2013 | Balboa Water Group Temp Sensor: External...
Water Isnt Getting Hot
Could be that the plumbing got clogged while the system was idle
May 13, 2013 | Sta Rite Pool & Spa
Balboa hot tub m7 wont power on at all
Either the spa is incorrectly wired or one of the fuses is blown in the spa pack. Typically this is due to your electrician wiring the spa incorrectly and blowing the fuse on accident.
Aug 06, 2012 | Jacuzzi Balboa R574 System for 1 2 Speed...
QCA Spa Contol Panel Issues
Flow issues can be frustrating, check each of the following
1. Low GPM.
2. Low Water Level.
3. Blocked Suction Fitting.
4. Blocked Skimmer.
5. Dirty Filter. (Try run system w/o Filter)
6. Too Many Closed Jets.
7. Closed Slice Valve.
8. Heat Related Pump Not Running.
9. Heat Related Pump Not Primed.
10. Malfunctioning Impeller.
11. Incorrect Heat Related Pump.
12. Circ System Misconfigured.
13. Sensor Malfunction.
If none of those help try this. There is a link to s Balboa site for service tech diagnostic help. There are step by step instructions for diagnostics.
Jan 23, 2012 | Pool & Spa
I have a Balboa Instrument Panel for my Spa. Model # M51500 part #54493-200701300092. My question is the main 50 amp breaker keeps tripping not allowing power to the spa. There is no blown fuses that I...
This is most likely a heater issue. The technician needs todisconnect both heater leads to see if the breaker will hold. This will help you determine where theelectrical problem is occurring and why it is tripping.
You can find answers to common spa orbath problems online at http://www.balboadirect.com/support.aspx Hope that helps!
Jun 01, 2011 | Balboa Instruments Duplex Digital Panel 2...
I have a Balboa R574 control and heater on a Jacuzzi Spa. The motor starts and runs fine on low speed, but trips the exterior GFI after about three minutes running on high pump. The pump and motor were...
Understand that this information isbeing provided as-is and without warranty or guarantee. As with allelectrical components and devices, all work should be performed by a licensedspa or pool technician. Serious injury or death can occur if a component isimproperly repaired or installed. This islikely an issue with the GFCI breaker not being able to handle the load or aproblem with the high speed of the pump.
May 23, 2011 | Balboa Instruments Duplex Digital Panel 2...
My balboa spa says sl and isn't heating up
SLP or SL Message
If the SLP or SL Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Sleep Heating Mode.
If the SLP or SL Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
You can find answers to common spa panel messages on the following page:
COMMON SPA PANEL MESSAGES
May 19, 2011 | Balboa Instruments BALBOA 30 kW HEATER W...
Dryers Logo
64 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
