Question about Weller Portasol Pro Cordless Butane Soldering Iron Kit
Psi100k need manual
I have a psi 100k it will only light with the tips off and when it does the flame is too large and not torch like no matter how low I turn the gas down
3 Suggested Answers
MalKontent68
  • 748 Answers
SOURCE: my Weller PSI100K Portasol soldering gun will not
It is supposed to produce heat there, it's the place where catalytic combustion takes place. If the tip doesn't heat up enough, it means that either the tip is not screwed properly into the housing, or there's not enough gas pressure. The catalytic mesh should be orange in color when heated properly.
Too low gas pressure may be a result of many things, like a malfunctioning valve (regulator and/or on/off),or clogging of the ceramic pressure reductor due to poor quality gas used, with high heavy fraction content.
Posted on Jul 15, 2010
pncroft
  • 5 Answers
SOURCE: Weller PSI-100K doesn't ignite. I
I have the same soldering iron and have found for this problem, the replaceable tip has worn out.
All you need to do is buy a replaceable tip of your choice. The tips are a consumable part that wears out.
Posted on Aug 21, 2012
Torch doesn't have correct flame
Without knowing the specific torch tip you're working with and what you're welding/soldering the only thing any one can suggest is cleaning the tip. You can get welding tip cleaning files any where that sells welding supplies.
Dec 23, 2013 | BernzOmatic Welding Tools
Hi there, despite brand new torch, brand new regulators and gas tanks, I cannot get a decent hot flame on my oxyacetylene torch, and what flame I can get, goes out within seconds of heating a...
Hi:
If your flame goes out check the following:a) check your acetylene and oxygen pressure, for this kind of job acetylene should be at 4 psi and oxygen at 10.b) Check you're using the right type of nozzle for the job and this nozzle is clean.
Apr 04, 2011 | Smith 23-1001C OXY/ACETYLENE LITTLE TORCH...
I'm unable to get blue flame on orca torch, it makes a crackling noise when I light it and has yellowish gunk in the tip, Can you help?
Is this torch powered by acetylen and if so then the yellow gunk you are seeing is unstable acetyleen which is caused by a torch that is releasing the gas faster then it can be handled in normal atmospher whic would be why you can not get a blue flame, I would say that the tip is to large for the tanks you have the system attached to. I would ask your dealer to suggest the tip size that the torch set you are using would be compatiable with the tank size you have attached. I would not try to use the set until I get it sorted out as unstable acetyleen is very explosive. Hope This Helps Don
Dec 17, 2009 | Computers & Internet
Brand new Weller Mcm Magna Lite butane torch does not light
If this is an itty ***** torch, The fuel is very sensitive . Too much screws up the air fuel ratio so try turning it way down and after the tip has heated up, you can increase your flame. Good Luck, Ned
Aug 27, 2009 | Weller Mcm Magna Lite Butane Table To
Torch is used for jewelry work and is a acetylene air torch. the torch keeps going out when lite. also would like to know how to adjust the air flow on the tips and what it should be. thanks
Usually, the blow-out problem is caused by excessive fuel flow at first--too much pressure or valve is opened too far. Once you have a bushy acetylene flame, turn up the air source to bring the flame down to a fuzzy point near the tip end. Brazing and silver soldering work better with just a little less air. My experience is with an oxy-acetylene torch, but results are similar.
Jul 23, 2009 | Welding Tools
Weller Portasol Pro Cordless Butane Soldering Iron Kit Logo
114 people viewed this question
Top Weller Welding Tools Experts
Lawrence Oravetz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
