Question about Radio Communications
My urchin boom wireless speaker will not charge or come on
JBL Charge 2 stopped wifi connecting to pc
Problem connecting Windows 8.1 pc to JBL Charge bluetooth speaker ...
answers.microsoft.com/.../windows/.../windows8...connecting-windows...
When I try to connect the pc through Bluetooth to the above wireless speaker ... 2) What is the model of the JBL Charge Bluetooth speaker? ..... I am already able to play music from my iPhone 5 on this speaker via Bluetooth with no problems.
Cannot connect JBL Charge Bluetooth - Networking, Internet ...
en.community.dell.com/support.../network...wireless/f/.../t/19525571
Dell
Sep 22, 2013 - 16 posts - ‎11 authors
23 Replies; 16 Subscribers; Postedover 2 years ago ... I'm trying to connect my JBL Charge Speaker bluetooth with my Dell Studio 15 laptop to listen .... I am having the same problem, did you find a fix for this? ... not support audio output, then you need to add a Bluetooth adapter which includes a CD driver.
JBL Charge 2 ' Portable Bluetooth Speaker with USB Charger
www.jbl.com > Wireless > Portable Bluetooth Speakers
JBL
Rating: 4.3 - ‎110 reviews
Most popular JBL Charge 2 wireless portable speaker can charge any devices via USB... You can easily connect Charge 2 to any Bluetooth-enabled device by giving the portable's ..... Charge with proper charger or a USB port form computer.
Jan 28, 2016 | JBL Audio Players & Recorders
Ue boom connected to pc but is not playing music... if i get lucky i get muffled sounds play back, how do i fix this
Q: What should I do if the audio is distorted or drops out on my UE BOOM?
A: Audio distorted or dropping out when streaming to UE BOOM
If you're having trouble with audio distortion or drop-outs on your UE BOOM, try these suggestions:
  • Move the audio source closer - it might be out of the range of your speaker.
  • Move away from other sources of wireless signal - you could be experiencing interference.
  • Make sure your speaker has enough battery power (connect it to a power source with the supplied adapter).
  • Adjust the volume on both the audio source and your speaker.
  • Restart both your speaker and the audio source.
  • Re-pair your device with your speaker (see, "How do I pair additional Bluetooth® devices with my speaker?").
  • If you're using two UE BOOM speakers (for Double Up), try disconnecting and streaming to one speaker only.
NOTE: If you're streaming audio content from the internet, the issue could be with the internet connection and not your speaker.
Dec 26, 2014 | Microsoft Computers & Internet
When I plug it in its green when I unplug it the thing will not do anything
Chris
Charge with boom closed. If previously paired with your phone and bluetooth is enabled. It should auto connect when boom is opened. Pairing on this model is tricky for some.
Mark
Motorola Support
Nov 19, 2013 | Motorola Mobility H700 Wireless Headset
Boom audio, blown fuse
Fill the air with sound from this Boom!™ Audio Boom Bagger Kit. This complete audio kit provides the latest in Harley-Davidson® audio components. When installed, the increased power of the amplifier provides the speakers with a clean signal, and a custom equalization is available to further optimize the performance of the Boom!™ Audio speaker system.
  • 4-Speaker Ultra Boom!™ Bagger Kit
  • Ensure maximum output of your audio system with the recommended High Output Charging System P/N 29900028
  • Dealer Digital Technician software update is required
  • Dealer installation is recommended
  • Kit includes Boom!™ Audio 6.5" fairing speakers, Boom!™ Audio 4-channel fairing-mounted amplifier, amplifier mount and wiring harness
  • Speakers feature two-year warranty
  • Stop by a participating dealer to interact with a unique audio display that lets you simulate how your bike will sound with Boom!™ Audio upgrades. Contact your local dealer for details
From: http://www.harley-davidson.com/store/boom!-audio-boom-bagger-amp---speaker-kit-pa-08-76000411--1
Jun 11, 2012 | Harley Davidson Motorcycles
For some reason, My Motorola H700 quit going into pairing mode? No matter what I do I can't get it to go into pairing mode. I have a Motorola Droid, and have had it connected to it before, but now it...
I have had this problem as well. Just to recap the problem. When you push the talk button and it turns purple, then you flip the speaker boom the unit starts flashing blue and will not pair. If this is the case then you should try unclipping the ear piece on the unit. Then repeat the pairing feature on the unit only this time hold the unit open with additional force. Not so much that you break the speaker boom, but enough to help the unit make a connection when it is flipped open. The problem with these units is that sensor inside does not always make a good connection especially after time and use. This should resolve your problem.
Curtis
Jun 04, 2010 | Motorola Mobility H700 Wireless Headset
The right speaker gives of a strange sound sounds like something is scratching something then it goes boom boom boom what's worng with it
The coil of the right speaker is already defective. Try using other speaker to verify the effect. If it's alright
then, just replace it.
Nov 06, 2009 | Logitech X-230 Computer Speakers
It wont turn on
With the boom closed, insert a plugged in charger and make sure the unit is fully charged. The light will turn from amber to GREEN when it is fully charged. Unplug the charger and open the boom. It is now "on".
Aug 23, 2009 | Motorola Mobility H700 Wireless Headset
No sound on a Sharp 37" Aquos TV
Try the main resets in the back by the a/v in and out jacks. If this does not work, call Sharp Customer Service and tell them that you already did the resets. There is a known problem with a heat dissipation pad and they will send a repair tech to replace the pad for free, even if you are out of warranty.
Jul 08, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Purple light
The purple (majenta) light usually means it is in pairing mode. Is it possible that the button is stuck pressed in??
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Jun 09, 2008 | Motorola Mobility H700 Wireless Headset
Radio Communications Logo
23 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
