Question about Motorola Mobility H270 Bluetooth Headset
Sport bluetooth headset zw88
Blue light wont turn off
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How to configure headset Bluetooth (zw88) in compaq window 7
If this is the Zonoki W88, you can download the PC Drivers from http://www.zonoki.cc/download.php?download_ID=7 the website is in chinese so you couldn't find it through google. it will install some new bluetooth software and it contains all the drivers required for the device to work, i just contacted the manufacturer directly for the drivers, hope this helps.
Kind Regards,
Oliver.M
Dec 09, 2010 | Computers & Internet
I am trying to conecct it to my samsung behold but everytime i click the search button it tells me there is no bluetooth in the area. what ever its only inches away from it , I have turned the blue tooth...
you must make sure your headset is in pairing mode.
simply turn the headset off and wait a few seconds
now, hold down the power button
the device will turn on but continue to hold the button. When the light turns solid or begins to flash a different sequence (typically 15 sec will do it)
now your device is in pairing mode and can be found by any device in the area that sports the bluetooth hardware.
the default code is 0000
GOOD LUCK AND PLEASE RATE THIS POST!! :D
Mar 29, 2010 | Plantronics Explorer 220 Bluetooth Headset...
MY I776 WONT FIND MY BLUETOOTH 220 WHAT CAN I DO
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above. Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Jan 20, 2010 | Plantronics Explorer 220 Bluetooth Headset...
My blue tooth wont turn back on, will sun exposure
exposure to high temps will kill a bluetooth headset so will cold temps. Did you try recharging it? if you did and it still wont turn on then im afraid its cooked.
Aug 09, 2009 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
My Lg Decoy wont sync with my Motorolla bluetooth
Jun 05, 2009 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
HBM 750 BLUE LIGHT STAY ON
I have the same model, and if you turn it on and the light stays on, usually after a flash and about 10 seconds, your headset isn't paired with your phone. You need to re-pair it with your cell phone, the code is 0000. That should work.
Jun 29, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Dont know how to work my blue tooth to my phone
You have to get the phone to recognise the bluetooth headset first. The manual should tell you how to do this. Normally you have to go into the bluetooth menu on the phone and get the phone to detect the headset, and then type in the pin code, normally 0000.
Jan 11, 2008 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H270 Bluetooth Headset Logo
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
