Question about Cables To Go TruLink?¿ Wireless USB Superbooster Extender Kit 29597
How to fix loosen usb extender
Connecting usb cable for using my dongle. but something going wrong... doesn't show up on screen.
  • Cables To Go Master
  • 3,320 Answers
Try a different cable. Also max extension for usb is 18 feet-6 meters.
Posted on Mar 28, 2014
Hooked hdmi dongle to projector. Used kindle fire hdx. Picture works fine but no sound from projector speakers. No sound from kindle speakers. Need to use kindle headphone jack for sound.
follow this steps and fix it. God bless you
Check the system requirements on the Bluetooth dongle. If your system does not fit all the requirements, the device is not going to work. The requirements for the Bluetooth dongle are printed in the user manual and packaging. You may compare this to what is running on the computer by clicking "Start," "Control Panel" and "System." This displays the hardware running on the computer.
    • 2
Disconnect the Bluetooth dongle, restart the computer, then plug it back into a USB port. If you power on the computer with the dongle already instead, the system may not detect the equipment. Restarting the computer and performing this action helps correct the problem.
    • 3
Remove the Bluetooth dongle from the USB port and plug it into a different connection. Some USB ports fail to detect certain computer hardware. Changing the connection port fixes this.
    • 4
Install the driver on the provided driver installation CD. Without the driver, the computer is unable to detect and use the dongle. Insert the driver installation CD into the disc drive of the computer, then follow the on-screen steps to install the driver onto the system.
Oct 29, 2013 | Brookstone HDMI Pocket Projector
Tip
How to Fix a Bluetooth Dongle in a computer
<p>Bluetooth devices connected to a computer system via a wireless signal, so that the desktop of annoying cables and wires to strip. Even if your computer does not have a built-in Bluetooth receiver, you can create a Bluetooth dongle, the function adds the system to connect. If the dongle is not working to resolve the situation. <br /> <p><br /> <p>1. Check the system requirements for the Bluetooth dongle. If the system does not fit all the requirements, the device will not work. The requirements for the Bluetooth dongle can be printed in the manual and packaging. You can compare that with what is running on your computer by clicking "Start" "Control Panel" and "System". This gives the computer hardware. <br /> <p><br /> <p>2. Unplug the Bluetooth dongle, restart the computer, plug it into a USB port. If you leave power on the computer with the dongle already instead, the system can not detect the devices. Restart the computer and perform this action helps to correct the problem. <br /> <p><br /> <p>3. Remove the dongle from the USB port and plug it into another compound. Some USB ports do not meet certain computer hardware detection. Changing the connection port fixes this. <br /> <p><br /> <p>4. Install the driver on the included CD driver installation. Without the driver, the computer can not detect and use the dongle. Insert the installation CD driver on your computer and follow the steps on screen to install the driver on the system. <br />
on Jun 26, 2011 | Computers & Internet
Can I use a 4G plug in connect USB with my Nexus 7?
(Using a WIFI Hotspot is definitely recommended. Connecting your 4G USB dongle to the Nexus 7 will drain the battery quickly since the USB is using the Nexus's battery to power on. This is what I use) but here's how to get your 4g usb dongle to work
Your device must be rooted, and you would need a USB OTG cable/adapter. Here's an example of an OTG USB cable -6c4749a3-0b72-4ebc-8cb6-60f7bfb77d23.jpgThis app should work on any nexus 7 and it is very simple just install the app and enter your apn of your operator connect your dongles via otg cable and it will work the app available on google play store called ppp widget here is the link it is for rooted device
PPP Widget
Mar 13, 2013 | Google Nexus 7
My vga port doesn't work right
Your VGA connector has a broken solder joint on the video board or the mother board. This isn't an easy fix.
Suggest you look for a VGA to USB dongle or adapter instead. Install the driver, and you should be good to go. You'll just have to take your dongle along whenever you need a VGA connection.
May 13, 2017 | Gateway NV55C03u Laptop
If you try and do a systems reset with a ganerick controller will it work
Providing the generic controller is connected via a usb cable and doesn't use a wireless dongle for normal use, then yes.
Dec 28, 2011 | Sony Playstation 3 (PS3) Console
Uwhat does USB mass storage mean on my camera screen and what do I need to do to get rid of it so I can use the camera
If you are seeing "Mass storage" on your camera screen, it states that the camera is connected to the computer via usb cable in "Mass Storage" mode, if it shows up even without any connection, there must be something wrong with the usb connector on your camera or it must be a internal hardware or firmware failure. You can try re-connecting the camera to the computer and disconnect it after few minutes, in most cases, this helps. If it doesn't seem to be helpful, you better visit a service center or a camera repair shop to get it fixed, otherwise you don't have much choices from your end. Servicing and updating firmware are mostly done at Service Center, it would be hard to find that kind of services somewhere else.
Hope this help.
Good Luck.
Thanks for using FixYa.
Apr 22, 2011 | Computers & Internet
My iphone is staying on the apple screen what is wrong with it ?
If it's under guarantee= go back to where you bought it
wouldn't really know what's wrong with it but try restoring it first
Connect it to your pc with the usb cable
see what happens
if nothing changes try restoring it through iTunes
if it is not recognised immediately: hold power and home button for about 10sec at the same time
your screen should show the cable and a kind of disk
then click restore in iTunes
if this doesn't help= visit an apple store
Apr 09, 2011 | Apple iPhone Smartphone
I have hp mini 210 laptop. I connect usb dongle of optical mouse to laptop. It installed automatically & successfully. It showing in device manager (Human interface device) but still optical mouse is...
Welcome to FixYa!
Here's a quick checklist to resolve your wireless mouse connection.
Solution 1.
1. If the underside of the mouse has an on/off switch, make sure to set the switch to the "On" position.
2. Make sure that the battery of the wireless mouse is placed correctly and is not drained.
3. After checking the first two steps, the optical lens on the underside of your wireless mouse should be flashing once in a while. If not, there is something wrong with the battery, the wireless mouse switch, or the wireless mouse itself is defective.
4. Connect the USB dongle in the USB port and let it install automatically.
Solution 2.
5. Connect the USB dongle in another USB port and let it install automatically.
Solution 3.
6. Restart the computer with the wireless mouse turned on and the USB dongle inserted in the computer.
Solution 4.
7. Download and install the drivers from here http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&dlc=en&softwareitem=ob-47909-1
I hope that this will help.
Thank you for using FixYa and keep me posted!
Jas247
Mar 15, 2011 | HP Wireless Optical Mouse
I can not get my wireless adapter to work on my laptop
First you need to connect the wireless router to your desktop computer through an RJ45 Cable and setup a new wireless network. to do this you go to control panal you'll find (Wireless Network Setup icon) click on it and go through the process, when you get to "network key" select automatically assign a network key then select setup my network manually and next, then finish. once you do that, now you have a wireless network. connect the wireless usb dongle to the laptop and download necessary drivers for it once it shows on the little icons on the bottom right of the screen right click on it and it should have an option to enable the it. if not, then the dongle has the wrong driver installed or its faulty. once its enabled, go to my network places and choose wireless network and click search for wireless networks, you should find your Router's network, select it and click connect and that should be all.
let me know if you need more help and try to give me error messages and steps you did before, so i can help you. good luck !!!
Dec 29, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Xbox live connection
three is the network
connect and install three usb modem
connect xbox to pc with ethernet cable
then start right click my network places and go to properties in network connections right click 3 usb modem then properties then advanced, tick the box allow other network users' then okay
now connect 3 3g device turn on xbox and BINGO !
Dec 15, 2007 | Microsoft Xbox 360 Console
Cables To Go TruLink?¿ Wireless USB Superbooster Extender Kit  29597 Logo
44 people viewed this question
Top Cables To Go Computers & Internet Experts
David Payne
David Payne
Are you a Cables To Go Computer and Internet Expert? Answer questions, earn points and help others
