Question about Canon D320 imageCLASS Digital Copier
Image distort when copying and horizontal lines
When I use my copier as a simple copier it distorts the images it has copied. I am also getting horizontal lines on the paper and sometimes full sheets that are so dark that they are not legible even though I have not changed any exposure settings.
  • 73 Answers
Getting caught? Loose paper shred inside feeder?
Posted on Mar 29, 2014
  • 134 Answers
SOURCE: BLACK LINE ACROSS THE COPY CANON IMAGE 2200
Most likely your drum unit is worn out. If it reaches the yield of 50k or more, it starts to develop grooves in the drum and toner gets stuck in the groove and is applied to your pages. If you have a service company, they can change it for you. We sell the drum for $220.
Posted on Jun 30, 2008
MXM450
  • 62 Answers
SOURCE: Cannon PC1061 making dark copies
OR you can do it yourself.
your problems seems to be Dirty Mirrors.
Your copiear has 6 mirrors that need to be clean up. 5 of them are kinda easy access. the other needs to be clean thru something thiner than your fingers. (you can see the mirror but no way you can reach it).
Now dont worry (not yet) about that 6th mirror since THEORICALLY it doesnt get dirty.
So try first to clean up the other mirrors. and see what happens.
They are located below the platen glass (remove it) and be careful with the lenses (do not touch them). clean everything that seems to reflect light Or images.
If nothing changes you may want to try out with a new cartdrige. Your drum may be done.
Posted on Jan 26, 2009
  • 100 Answers
SOURCE: printer doesn't put image on paper
The laser shutter is bad or stuck. The new one is redesigned. The shutter could be removed but that would break saftey laws. If its under warranty still have a repair center do it.
Posted on Jun 25, 2009
canontech
  • 1219 Answers
SOURCE: canon image class copier
Internal Components 2
Subject:
Prevention of blank image (modifying the shape of the laser shutter and applying grease to the laser shutter arm)
Detail:
<Symptom>
Since the laser shutter [1] is not opened when the toner cartridge is inserted into the machine, a blank image is output in
some cases.
[1] Laser shutter
[2] Laser shutter arm
<Cause>
When the toner cartridge is inserted, the laser shutter arm [2] pushes down on the laser shutter [1]. In case that the arm has
a scratch on its sliding surface, however, it is caught in the area [3] where the arm comes into contact with the shutter,
preventing the shutter from being opened.
Service Bulletin LBP-FAX/LBP-MFP
HARDWARE
Issued by Canon Europa N.V.
MF6500-014 Rev. 3
(2/4)
[A] View of the closed laser shutter [1] Laser shutter
[B] View of the opened laser shutter [2] Laser shutter arm
[3] Area where the arm is caught
<Factory measures>
a. Modifying the shape of the laser shutter
Modify the shape of the laser shutter so as to prevent the shutter from being caught when the laser shutter arm pushes it
(A turnback is added to the edge of the area that contacts the laser shutter arm).
P-3 Laser shutter [A] Old type
[B] New type
b. Applying grease to the laser shutter arm
To decrease the sliding resistance of the contacting surface (P-2 [3]) of the laser shutter arm and laser shutter, apply grease
to the laser shutter arm.
P-4 Laser shutter arm [1] Grease application area
MF6500-014 Rev. 3
(3/4)
c. Changing the shape of the laser shutter arm and applying grease to it.
To decrease the sliding resistance of the contacting surface of the laser shutter arm and laser shutter, change the shape of
the laser shutter arm. Additionally, apply grease to the arm.
P-5 Laser shutter arm [1] View of the rib in the new position
[A] Old type [2] View of the new shape of rib
[B] New type [3] View of the arm from which the rib is removed
d. Discontinuing application of grease to the laser shutter arm.
It was confirmed that the new shape of the laser shutter and laser shutter arm do not need lubrication by grease for normal
operation. From this, application of grease is discontinued.
Service Work:
When the foregoing symptom occurs, replace the laser shutter with the new type. In addition, remove the laser shutter arm
and apply a rice-grain sized amount of grease (PERMALUB G No. 2); about 30mg) evenly to the area [1] shown in P-4.
As for a machine having one of the serial numbers listed in “Affected Machines” below as “machines for which the shape
change of the laser shutter is carried out”, only application of grease is required: there is no need to replace the laser
shutter arm because the new type shutter has already been mounted onto them.
When replacing with the new type of laser shutter arm, there is no need to apply grease to it.
Service Parts:
No. Part No. Part Name Q’ty Stock Compatibility
Available
from Fig. No.
O FC6-7328-000 SHUTTER, LASER 1 > 0 1 N FC6-7328-020 SHUTTER, LASER 0 > 1 DC NY In stock 102
2 ON CK-055 1-020 LUBE, PERMALUB G NO. 2 0 > 1 F In stock -
3 ON FFCC66--77333311--000200 AARRMM,, SSHHUUTTTTEERR,, LLAASSEERR 10 >> 01 DC YN In stock 102
Affected Machines:
- Machines for which the shape change of the laser shutter is carried out
LaserBase MF6530 EU1 SNF50048 and later
LaserBase MF6550 EU1 SNG50009 and later
i-SENSYS MF6530 EU1 BAC02001 and later
i-SENSYS MF6550 EU1 DAC02001 and later
LaserBase MF6540PL EU1 SNP50288 and later
LaserBase MF6560PL EU1 SNQ50001 and later
LaserBase MF6580PL EU1 SNR21266 and later
i-SENSYS MF6540PL EU1 EAC02001 and later
i-SENSYS MF6560PL EU1 FAC02001 and later
i-SENSYS MF6580PL EU1 GAC02001 and later
LaserBase MF6530 EU2 SNX50504 and later
LaserBase MF6550 EU2 SPB50568 and later
LaserBase MF6540PL EU2 SPC50196 and later
LaserBase MF6560PL EU2 SPD50012 and later
LaserBase MF6580PL EU2 SPF50288 and later
LaserBase MF6550 EU3 SPG50312 and later
MF6500-014 Rev. 3
(4/4)
LaserBase MF6560PL EU3 SPH50444 and later
LaserBase MF6580PL EU3 SPJ50384 and later
i-SENSYS MF6530 EU2 HAC02001 and later
i-SENSYS MF6550 EU2 NAC02001 and later
i-SENSYS MF6540PL EU2 PAC02001 and later
i-SENSYS MF6560PL EU2 QAC02001 and later
i-SENSYS MF6580PL EU2 SAC02001 and later
i-SENSYS MF6550 EU3 VAC02001 and later
i-SENSYS MF6560PL EU3 WAC02001 and later
i-SENSYS MF6580PL EU3 XAC02001 and later
- Machines for which both the shape change of the laser shutter and application of grease to the laser shutter arm is carried out
i-SENSYS MF6530 EU1 BAC02945 and later
i-SENSYS MF6550 EU1 DAC02865 and later
i-SENSYS MF6540PL EU1 EAC04003 and later
i-SENSYS MF6560PL EU1 FAC03073 and later
i-SENSYS MF6580PL EU1 GAC02833 and later
i-SENSYS MF6530 EU2 HAC02049 and later
i-SENSYS MF6550 EU2 NAC03737 and later
i-SENSYS MF6540PL EU2 PAC02633 and later
i-SENSYS MF6560PL EU2 QAC03593 and later
i-SENSYS MF6580PL EU2 SAC02105 and later
i-SENSYS MF6550 EU3 VAC03185 and later
i-SENSYS MF6560PL EU3 WAC02665 and later
i-SENSYS MF6580PL EU3 XAC03025 and later
- Machines for which the following are carried out: change of the laser shutter shape, applicatin of grease to the laser
shutter arm, and change of the laser shutter arm shape
- Machines for which the following is carried out: discontinuance of application of grease to the laser shutter arm
i-SENSYS MF6530 EU1 BAC02946 and later
i-SENSYS MF6550 EU1 DAC03161 and later
i-SENSYS MF6530 EU2 HAC02121 and later
Posted on Jan 19, 2010
canontech
  • 1219 Answers
SOURCE: canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
Posted on Jul 02, 2010
3 Horizontal lines distorting picture
When you say "distort the picture", are you referring to dark image? double picture
Jan 20, 2013 | Samsung Touch of Color LN52A650 52 in. LCD...
Dell 2300 MP Verticle lines distorted image
light engine or bulb is gettingbad ok how many hours on bulb fans clean ect thx nick
Feb 11, 2008 | Dell 2300MP Multimedia Projector
Screen stretched out horizontally and distorting picture. None of the settings buttons appear to solve this. I can shift the image vertically or horizontally; but not squeeze it horizontally.
There are adjustments in the size of the items on a screen under the screen properties, settings. If you right click on the desktop screen and then properties you can get there. There is at least one size which causes a distortion of images being displayed. This may be your problem.
Feb 28, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Ghost lines horizontally (looks dirty) when making multiple copie
Check the cleaning blade of the OPC drum,the image transfer unit.
Aug 17, 2009 | Canon Office Equipment & Supplies
Scanner working wrong
Distorted images with lines present from scanned pics arises when the power supply is already below the rated output voltage or regulated power supply is defective. try fixing the power supply section but check if it still have a correct output voltage, or replace the power supply with a new one if the power supply of your scanner is a plug in type, or try to plug the scanner somewhere else in your place... hope this help :-)
May 24, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
Copy quality is poor. Replace toner, drum and transformer?
when you say the quality of the text is poor I am assuming that your are describing the line print
FIX
IF FUZZY remove corona wire and clean with q tip diped in alcohol
If IMAGE OFFSET check fuser rollers emove pad and ad fuser oil
IF copies lite remove print cartridge and shake back and forth to get toner distributed
also examine photoreceptor sounds the shutter is not closing and causing image distortment
Jan 05, 2009 | Sharp AL 1631 Copier
No Color image - B&W image is distorted
it could actually be the cable box itself or there could be corossion on the cable connection outside
Dec 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Distortation of engineering drawing in Ms Excel
I am assuming that the reason you are using Excel is because of the gridlines. An "engineering drawing" done in Excel would break when rotated especially the angular lines. The reason is Excel does not have the necessary engine to display (render) such drawings. By Excel alone, there is no way out of this problem.
However, there is a workaround. After making the drawing, before rotating it, do a Print Preview. Open an image manipulation program, even a simple one such as PaintShop Pro. Capture the image on the Print Preview. Open another Excel sheet, copy and paste the image from the image manipulation program to the Excel sheet.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 16, 2008 | Dell Dimension 3000 PC Desktop
Distorted image
Sounds like you may have a faulty CCD Sensor or the wiring came loose. My Camera did the samethimg. Email carecenter@cits.canon.com and explain to them the problem.
I
Aug 06, 2008 | Canon PowerShot A75 Digital Camera
Distorted Image
if it records the distortion then i suspect the guides are out of adjustment or your capstand roller is pushing the tape to high on the guides. need to have a profession serviced.
Feb 07, 2008 | Samsung SC-D23 Mini DV Digital Camcorder
52 people viewed this question
old marine
old marine
