Black and decker js700
There is a speed and angle ratio that must be observed . Depending on the density of the material and the thickness. The shoe plate can be raised or lowered to assist with the forenamed floating condition. Proper blade selection and sharpness is essential.
With thick materials pushing the blades design, speed and force must be regulated through patience to provide the accuracy you demand. The complete blade system is another part of your investment . Understanding what and when can overcome fast if problems arise. Assuming all of this is in your tool box. I always have been taught. Only adapt when all reason is exhausted.
The last part I have had happen is vibration and tool integrity. Maintaining a tight fastener system all over the tool by lubrication is paramount from use or lack of it. Preventive measures spot stuff from happening when you are making the million dollar cut. But we all know that. Daily or startup practice. Just like stretching before playing, a great coach takes the time to do it for their selves too.
There are six JS700 models. Here is a place for parts should that arise Black Decker Jigsaw Replacement Parts Repair your Black Decker Jigsaw... . Furthermore, here is some words for those who are new at the application. Take a look. How to Use Jigsaw basic. This next look in video instruction is thorough and shows intermediate techniques with some experienced foundation. How to Use Jigsaw produced by skill. The Woodworker Journal places the top six picks side by side in the last video offered Top Shelf Jigsaw Review . There is one called a "Mafell" which has a so called perfect orbiting system, which some make it, the straight cut King.
I took the time to do this on the first day of summer. There is lots more to discuss. I think you have the most versatile easy to learn tool in your shop. I am almost sure you think so too. Keep humming. Fare. Well.
SOURCE: blade wander
a jigsaw is for cutting wavy lines if u want a straight cut use a rip saw with fine blade but you still can use a jigsaw must have sharp blade there is a blade u can get now from screwfix with a triangle spine on the back off the blade to prevent it twisting works fine (also do not push hard on the powertool let the blade do the cutting less likely to wander hope this is of help
SOURCE: will not cut straight lines
Tension the blade so it's correct tension.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Changing the blade in a bosch pst 65 pae corded jigsaw
Pull up the knob on the front at the top of the machine and push the yellow bit forward. Theoretically you should turn the knob anticlockwise three turns but it doesn't seem to make any difference on my one. Then take hold of the blade, ease it forward and turn through 90 degrees. You should then be able to pull it out. Replacement is, as they say in all the best manuals, a simple reversal of the procedure. When you are turning the knob clockwise this time it's supposed to click in place but my one doesn't do this and still seems to work.
Best of luck
Gavin
SOURCE: How do i remove the blade on a black and decker
either on the left or right side of the blade holder there will be a little lever to pull that will release the blade, pull on the blade at the same time you pull on this release
SOURCE: My bosch jigsaw keeps saing sideways!!!
Most Bosch jigsaws have a handle on the top of the main handle that you need to pull up and rotate counterclockwise to allow the screw to accept the blade. Insert the blade and rotate 90 degrees into position then tighten the handle and press back down into place. In the beginning it may seem like you are going to break the handle pulling it up but rest assured it will get easier as it gets used.
