Question about Frigidaire Dishwashers
Error code dc comes on. washer won't start. can't find reference to dc error code
SOURCE: error code "loc" on GLTF2940ES0 washer
turn the selector knob so the machine comes on then press the "options" and "select" bottons at the same time for 3 seconds.
Posted on Nov 24, 2007
FAV6800AWDIY
  • 526 Answers
SOURCE: Neptune FAV6800AW Top Load Washer: My Neptune washer is showing error code dc..Once i...
See this post Clutch Fix if you want to DIY I will help you.
Post back if you have questions……..Rich
Posted on May 23, 2010
FAV6800AWDIY
  • 526 Answers
SOURCE: My Neptune washer is showing error code dc..Once i...
See if my Clutch Fix post will get you started if your machine model type is a FAV6800A or FAV9800A.
Service Manual for reference. Sears Parts Direct for reference.
Your TDS is working or the machine would shake itself apart.
If you decide to DIY I will help you thru the process. If you decide to have it repaired show the Clutch Fix post to the repair tech it will help him help you back into service......Rich
Posted on May 24, 2010
blueextc3221
  • 15935 Answers
SOURCE: maytag washer has error code of dc
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#$
Posted on Sep 27, 2010
appliance765
  • 83 Answers
SOURCE: error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Posted on Mar 10, 2013
What does samsung washer error code dc mean?
Product: Home Appliances > Washers & Dryers > Washers > WF218ANW
dc = Unbalanced load prevented the washer from spinning.
What Do the Information Codes Mean on the Front Load Washing Machine
Jan 03, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
My Neptune washer is showing error code dc..once it starts the spinning cycle the machine will stop.
May 20, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune FAV6800AW Top Load Washer: machine starts to spin, stops, starts againe, over...
From what you are describing I feel your FAV6800A or FAV9800A has a Clutch malfunction see this post to get started on a DIY repair Clutch Fix.
The classic failure is the machine tries to spin up the wash basket starts banging from side to side then errors out with an unbalance error of dC or uC. Is that your failure scenario?
See if the post I link you to will help. Post back if you have any questions……..Rich
Some other handy links; The Service Manual for reference. Sears Parts Direct for reference.
May 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Getting dc error code in rinse cycle, 13 min.
See my Clutch Fix post. Anyone with basic mechanical skill sets can save there $1000 machine for low cost maintenance or Clutch pulley replacement.......Rich
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
May 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer does not finish cycle..it stops at spin and it displays a 'dc' code...what is this
dC code from the Service Manual = Distribute Clothes: The load is unbalanced, preventing high speed spin. Redistribute clothes.
Your wash tub is banging around during the spin cycle correct?
You can redistribute the wash basket load until the cows come home the issue will only continue to get worse. Maybe start throwing uC error codes to the console display for continuous unbalance error code.
Your FAV6800A or FAV9800A has a Clutch malfunction. It can be corrected if you are handy see this DIY fix Clutch Fix. post.
If you decide to dive in I will help you through the fix………Rich
Feb 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl makes grinding sound and stops at 33 minutes in normal mode and at 24 minutes in quick wash mode
Hello djlampl,
With the lowest spin cycle setting I enter spin cycle in Quick Wash around the 21 minute mark. But first question is do you hear the grinding noise with the tumblers rotating during the wash/agitate cycle?
If you start a spin only cycle do you hear the grinding noise?
Does the washer error code out with an error code to the display? Codes such as dC, uC, Lr?, I assume the machine type is a FAV6800AW is that correct?
Any additional info will help in troubleshooting…..Rich
Assuming the machine type is a FAV6800A/FAV9800A here are some handy links;
Nov 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Machine shuts off and gives DC error
A DC code indicates an out of balance load, and the need to Distribute Clothes (DC). It will not allow a high speed spin when this condition is present. Remove power to unit for 3 minutes and reconnect. If trouble persists, call in a pro as several components could cause a DC code without an unbalanced condition.
Nov 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
