Question about C3RS730 LCD (C3RS730LCD) 2way 4Channel Vehicle Security Syste
On a k9 Mundial-2 the remotes will not open or lock the doors. The batterys are good and the fuses are good what should I check?
Please don't tell me to check the batterys and fuses I have already done that. I need a fix.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 159 Answers
Check the antena
Posted on May 11, 2014
Back hatch won~t open with remote or inside door locks will open manually nothing stuck or jammed?
Found this wiring diagram for lift gate, if that is what we're talking about? Not only check the fuses, check fuse circuit for voltage. Use a testlite.
Apr 21, 2016 | 2008 Pontiac Torrent
Doors wont lock or unlock, trunk wont open and remote wont do any good, fuses ok.
Will the switch on the door lock or unlock the doors, if so check the battery in your remote, it may be dead. Remove the key remote from your keychain and there is a slot in the end of the remote that will open it up so you can gain access to your battery. Pay close attention to the way the battery is installed before removing it. Replace the battery and try the door locks again. If they work, then you have solved the problem. If not, you have an electrical problem that you will have to trace down. From the information you have given, this is all I can tell you without seeing the car for myself.
I wish you luck, I hope this helps you find the problem.
Oct 15, 2014 | 2002 Ford Crown Victoria
Battery Keeps dying, Car thinks doors are still open when closed .
Please check all door close sensors for each door.
Apr 15, 2013 | 2005 Lexus ES330
2007 toyota avalon keyremote won't open or lock my doors
1) Check the battery, or replace the battery in the keyless remote transmitter 2) If battery is replace and still a no go, see if the power locks would open and close with the door lock/unlock switch in your car, and if they do, then your remote transmitter needs to be reporgram agian. If not then the power switch is damaged, or fuse blown. If transmitter needs reprogramming, please take it to your nearest dealship and they can do that for you, either free of charge or for a small fee.
Jan 30, 2011 | 2007 Toyota Avalon
My K9 alarm is silent. I am not hearing the noise when I open the doors are close them. How can I activate this feature again?
Is the LED indicator illuminated steady (not flashing)? If it is, than the system is in valet mode. In order the turn off valet mode, you need to press and release the valet button once. The LED should turn off and you will be able to operate the security system.
Jan 23, 2011 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
Only one of my my k-9 mundial keyless work the other seems fine but wont activate.
Try to reprogram the remotes to the alarm. Have your vehicle key and both remotes ready. The way to do this is as follows:
1. Turn ignition key to run position.
2. Within ten seconds push the valet button 5 times.
3. The siren will give a chirp, indicating that you are in programming mode.
4. Press the large button on the first remote. A chirp will be given as confirmation.
5. Press the large button on the second remote. A chirp will be given as confirmation.
6. Turn off ignition and remove key. Alarm will give long chirp indicating exiting program.
7. Try remotes. Both should be working.
For the next 48 hours, every time the vehicle is starting the siren will chirp indicating that remotes have been programmed. After 48 hours this feature will turn itself off. Also keep an eye on the alarm light as it will also blink the number of times as remotes are programmed every time the ignition is turn on.
Hope this information helps. Please rate. Thank you.
Mar 04, 2010 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
Car does not start lights flash 3 times
can you be a little more specific. Are you talking about a remote starter???
Feb 05, 2010 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
Trying to program a new remote to my car alarm ''excaliber'' k9 remote
turn key to on position push valet 5 times then hit lock on the remote
Dec 26, 2009 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
C3RS730 LCD (C3RS730LCD) 2way 4Channel Vehicle Security Syste Logo
69 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
