Question about Sewing Machines
Need cut out height, width and depth from Kenmore 665 44 33 452
Kenmore
  • Sewing Machines Master
  • 1,388 Answers
Sorry, what is this for ?
Posted on Apr 22, 2014
Adjust stitch width to narrow for an Elna 654 overlocker
What you are looking for is "cutting" width. The adjustment moves the cutting blades in or out, thus increasing or decreasing the seam width.
Mar 11, 2016 | Elna Sewing Machines
Singer 7462 buttonholer
try adjusting the size, see if it changes the result and go from there, you might also want to ask other experts, sewing machines are not my speciality.
Sep 28, 2008 | Singer 7462 Mechanical Sewing Machine
How do I replace the throat plate on my Imagine serger? It seems to not want to fit and lay back down flat.
  • Set lower blade to widest width setting
  • Place differential feed on N
  • Remove Needles
  • Place back circular hole in plate onto the anchor screw(this should never be loosened)
  • Plate will set down flush
  • Reinstall the front holding screw.
  • Reset width control
  • Check lower blade height, per instruction replacement manual.
Feb 26, 2015 | Baby Lock Imagine
How do I adjust needle depth on my Singer 590 c?
There is an Allen screw on the shaft of the needle bar that you can loosen to be able to adjust the height of the needle. Some machines also have markings as to where the needle height needs to be. If you still have trouble talk to the people at the link below. They may be able to help. good luck Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Nov 23, 2014 | Singer CG-590 Commercial Grade Sewing...
Elna 683 stitch width
the information you need should be in the manual, if you don't have a manual then here is a link for one
http://www.sewingpartsonline.com/instruction-manual-elna-683.aspx
Oct 15, 2013 | Sewing Machines
Moon stitches
Make the stitch width wide and the stitch length very short. It will take a bit of practice with the widths and lengths but you will get it.
Good luck.
Rick
Jan 20, 2009 | Kenmore 15208 Mechanical Sewing Machine
I can't narrow the serged edge width to do a narrow rolled edge
There are 3 things that come to mind for me.  I should say that I have a Bernina 1300DC, so your machine may not have the same parts, but check these things.  First, are you using 3 threads?  If so, is your needle in the narrowest setting, in the right hand hole closest to the body of the serger? Secondly, is your rolled edge lever retracted?  This lever is attached to a wide tooth that holds the width of the seam in place.  It is under the presser foot, between the loopers, and should retracted so that the stitches are allowed to become narrow.  If your machine doesn't have this lever, don't worry, you can also try a third thing.  Adjust your cutting width to a narrow setting.  There should be a knob that moves the upper cutting knife from right to left-- right being a wider seam, leaving more of the fabric intact, and left making a narrower seam that trims off more of the fabric as you sew.
Hope this helps! Elsje
Dec 10, 2008 | White Sewing Speedylock 1600 Mechanical...
Bobbin thread
Impossible to explain how to time a sewing machine you need to be shown. Basically it entails setting the needle depth then making sure the hook passes just above the eye of the needle at a set height as the needle is rising, this ensures the hook catches the upper thread. Also the hook needs to be set a specific distance from the needle. Sounds easy but sometimes it can be very difficult and fiddly job.
Mar 31, 2008 | Janome Mini Compact
Kenmore sewing machine - uneven top stitches
Am about to buy this machine for my wife and the sewing machine cabinet I have chosen has parameters as far as the overall dimensions of the machine. Can you provide me with the width, depth and height of this sewing machine. The cabinet is offered for sale by Sears so it ought to work but still I will feel better with this information. Thank you.
Feb 05, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Only sews a straight stitch
NEEDLE BAR HEIGHT
With the pattern selector dial set at maximum zigzag width and when the point of the rotary hook exactly meets the right side of the needle in ascending travel of the needle bar from its lowest position, at the right needle drop position, the distance between the upper edge of the needle eye and the race of the rotary hook should be 3.3 ± 0.3 mm.
You also need to look at the timing
HOOK TIMING
With the needle bar swung to the right at the maximum zigzag width, the amount of ascending travel of the needle bar from its lower position to the position where the tip of the rotary hook exactly meets the right side of the needle should be 1.7 ± 0.3 mm.
Jan 15, 2008 | Sewing Machines
Sewing Machines Logo
11 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
