Question about Marshall MG100HDFX 100-Watt Amplifier Head
Power out blown
He powerout on my amp is blown, the tech unplugged it so I can still use it with headphones, is this a part I can replace or does it need rewiring?
    Sergeant:
  • 336 Answers
I'm not sure if I follow this question but, let me try.
The "power out" is blown? Do you mean this unit has no sound but, works with headphones or do you mean the "power out" socket has no output? What exactly did the tech unplug? Was it the output jack socket or the dead speaker, does the speaker work? I need more information and a clear explanation to help with this problem, please.
Speakers blow in 2 ways leaving an open circuit or a short circuit.
Posted on Mar 29, 2014
  • Dustin traynor
    Dustin traynor Mar 30, 2014
    he unplugged something to do with how the amp puts out power so I could still use it with headphones. he said something about it needing a new wiring harness for the power out to work, he said that he could buy the part or wire it himself, about $100 either why
  • Joe Patch
    Joe Patch Mar 30, 2014
    This sounds like he unplugged the amp so that you could still use the preamp section without it. I think there are very few components that he could replace or rebuild. Most components cannot be rewired. The power out socket could have melted or cracked and rewiring could bypass that. I just think something doesn't sound right but sounds like you are on the right track.
    New Friend:
Output trasformer is common too replace. Best OT is made by Mercury Magnetics, Weber.......
Posted on Mar 28, 2014
What is a power amp chip?
The power amplifier is the UPC1188H It will be attached to the heat sink with thermal grease on the back side of it.
Before you change it, Make sure to clean the contacts in the headphone and speaker plug as there are several interupts that may be dirty or corroded and may be preventing your music signal from getting through.
If the headphones work fine- that amp chip is driving them, the fault if the main speaker does not work will be one of those interupts. Contact cleaner should take care of the issue on the headphone jack- just spray the contacts down from the open side of the chassis and plug and unplug a number of times to clean up the contacts. Do the same for the external speaker jack
Apr 03, 2012 | Fender ® Frontman 15R Electric Guitar...
My frontman 15r has power but no sound
Check to make sure the problem is not with the headphone jack or the external speaker jack as these are in the circuit between the power amp chip and the built in speaker.
You can also trace through the circuit with a music source on the amp input and with simple headphones check the signal path through the circuit until the music disappears. To do this, take a headphone and set it up with 2 test leads on the ends- attach one to ground.
Now your TL072 op amps have 2 outputs, pin1 and pin 7. The inputs for pin 1 are pins 2 and 3, and the inputs for the amp section outputing on pin 7 are pin 5 and pin 6. If you get sound at pin 1 or pin 7, you move forward to the next TL072. Check for output. Then move to the power amp chip on the heat sink. Pin 1 should be the output and will be wired to the headphone jack first. The external speaker jack second and the built in speaker third. The input for that power amplifier chip is pin 7 or pin 8 depending how it is wired.
If the amp chip is blown, make sure to put an adequate amount of thermal grease on the back side of the IC in contact with the heat sink so it can operate as cool as possible.
Apr 03, 2012 | Fender Music
I have a Fender Frontman 15R. It doesn't work at all. No sound. I read reviews about it and none say that it does this. Is it worth fixing and what might be the common problem? Thanks, Aileen
The power amp chip has probably blown. It is a TDA2050 cost about $3. They don't even use thermal grease on these to help conduction to heat sink. Make sure you do use thermal grease when replacing. Also be careful of pluggin anything OTHER than headphones in the headphone jack. It can result in blowing the amp chip.
Jul 10, 2011 | Electric Eyeware Fender Frontman 15r 15...
I got a Marshall MG100HDFX for free from a friend stating it was blown. I asked how this happened and he said that one of his friends plugged in another speaker or amp into the second speaker input in the...
The power amp section has blown parts. You will likely find they use a chip like the TDA7293 as the power amp output and it will be blown, shorted causing the fuse to blow. These cost $6 from Digikey.com. Find a competent tech to replace it and use heat sink compound. Verify the part before ordering one. They come with leads bent either way so make sure you get the one with a matching suffix letter. When firing up after repair, put a 60 watt light bulb in series with the hot power lead to act as a current limiter... saves blowing fuses if there is another problem.
Jun 21, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
My amp isn't producing any sound. It works when headphones are in but that's it. Please help
The headphones socket is on the preamp stage - it works so the problem must be after the pre-amp.
Do you get any sound at all from the speakers (hiss or perhaps a click) when you turn it on?
If yes it is an amplifier problem.
Here are some possible causes
  • A wire has come off the loudspeaker - easy to fix
  • Speaker protection fuse has blown - small glass fuse mounted on main amplifier chassis - replace with correct rated and type of fuse (note some of these are 'slow' blow type - important that you get the right one)
  • faulty component in the main amplifier stage - requires attention from qualified repairer
  • Loudspeaker burnt out - this can be tested by connecting another speaker across the terminals of the built in speaker.
  • The headphone jack socket automatically disconnects the loudspeaker when phones are plugged in - it could be that the contact in the headphone jack socket is bent and not re-making contact when the headphones are unplugged.
Feb 26, 2011 | Orange Crush 15r 15w Reverb Guitar...
No output power
It is likely the amps have been blown. Take for repair as further use may cause further damage.
Test the mixer by plugging headphones into the main L and R outputs. Note you will hear only one side of the headphone being these are mono outputs. The level will be low, but will check that the rest of the mixer is working.
ALSO please read my tip on here regarding a hazard of speaker polarity.
Oct 10, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Marshall mg10cd amp has no volume
Common causes:
Broken input jack.
Blown power amp chip due to overdriving.
Smashed pots due to tipping over or transportation damage.
Blown power supply due to bad power at a venue.
In some cases, grounding the headphone jack can blow amp.
Feb 11, 2010 | Marshall MG10CD 10 Watt Combo Amplifier
Line 6 spider 210 volume problem
The bypass switch in the headphone jack is likely broken. NEVER unplug the headphones while the amp is on.
There are certain small amps that have a possibilty of popping the power amp due to a feedback arrangement. Likewise, never use the headphone jack for ANYTHING other than headphones.
Dec 20, 2009 | Music
No output
There are some possibilities. One, your speaker may be blown or disconnected. Make sure the wiring is still connected to the speaker and if you have one, try measuring the resistance(impedance) of the speaker with a volt ohm meter.Do this unplugged from current and disconnect one of the wires from the speaker or you will get a reading from the output stage. Two if there is a heaphone or line out jack it may have become faulty. If you have sound with the headphones plugged in your amp is still producing sound. Some jacks are designed to interrupt the signal to the speakers allowing you to practice without bothering anyone. If your amp has that feature and you still have sound with the headphones and your speaker tests OK then your problem is the jack. Hope this helps.
Jul 20, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
My son's guitar amp Epiphone guitar amplifier model ep-800, does not work after someone plugged a bass guitar on high settings. He tried it the next day, only to find out it didn't work. Could the bass...
it could have blown the speaker, a regular guitar amp is not meant to handle a bass, you should be able to look into the back of the amp and see if any of the speaker is damaged, or there may be a blown fuse inside the amp, if you check for this please MAKE SURE TO UNPLUG THE AMP FROM THE POWER SOURCE FIRST, and if needed replace the fuse with the exact same type
Mar 21, 2009 | Music
Marshall MG100HDFX 100-Watt Amplifier Head Logo
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Bruce Grant
Bruce Grant
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
