My 2005 Diamo Turista 300 starts and runs great most of the time. After riding for a while if you stop it will idle fine but stall when you open the throttle. Mechanic thinks it might be the valve clearance but I can't find the valve clearance anywhere.
SOURCE: I just purchased the 150cc
I am not familiar with the diamo retro, but if is a four stroke engine the problem described would likely be burned valves. Chances are, simply re-seating the valves by lapping with valve grinding compound would fix the problem. If the engine is a two stroke, the crank seals may be bad, too much oil in the gas? Partially plugged up exhaust port? In either case, 2 or 4 stroke, disconnect the exhaust pipe and see if that fixes the slow speed problem. The exhaust may be partially plugged up. Also be sure the carb mounts are tight. Off the ground, do the wheels turn freely or are the brakes dragging? Is the drive belt (or chain) in good condition?
SOURCE: My diamo tracer 150 GSX
www.martinracingdealer.com/REPAIR%20MANUALS/DIAMO%20MANUALS/Tracer150%20Parts%20Catalog%2010-05.pdf
this is the only thing I could find regarding your bike, I'll look it over and we can go back and forth about it to you can request a chat session for a complete assistance..
SOURCE: I need a wiring diagram
Hi
I am sorry but we have no wiring diagrams available for dwonload for this scooter. The diagrams are contained in the factory repair manual, it is copyrighted and can't be downloaded. I suggest you buy the factory manual, if you are going to do work on this yourself it is as essential as a set of screwdrivers and wrenches. Thanks
SOURCE: I dont know what type
as with any motorcycle you want to use a good oil i personnally use amsoil 20/50 it keep engine clean and lubes better for less friction
SOURCE: I have a 2005 Diamo
open the drain screw on the carb and let some petrol out sounds like there is some water resadue in there
