Question about Honeywell UV100RM1 True UV Coil Treatment System
Socket melted with bulb in it
Socket for the UV bulb melted with bulb in it. What was the cause? They no longer make this one were there problems with it?
    Scholar:
  • 63 Answers
This was caused by heat retention and bad product design for the use you put it to. Unless you are comfortable working with the high voltage innards and acquiring and replacing the socket with something that you can get to work, this device is potentially a fire hazard now and should be replaced or otherwise repaired if possible.
Posted on Mar 28, 2014
Where can i get a replacement lamp uv-145 2.5w
Sealand Replacement Bulb for Green Killing Machine - Petco
www.petco.com/.../Sealand-Replacement-Bulb-for-Green-Killing-...
PetcoWater flows in direct contact with UV lamp, making it extremely efficient. The zigzag flow are designed for maximum sterilizing time. Totally self-contained replacement bulb assembly for AA 9Watt UV Sterilizer Kit. .... 2.8" L x 2.5" W x 16.5" H
UV light sources - Norland Products
https://www.norlandprod.com/lightsourc.html
The Norland collection of long-wave, ultraviolet light sources have been carefully ...LED UV Curing System emits a consistent and repeatable 2.5 W/cm squared ... lack of liquid light guides and replacement lamps brings to the forefront of UV ...
[PDF]MultiPole LED UV Curing System - Electro-Lite
Dec 10, 2015 | Honeywell Air Purifiers
How do i remove the uv bulb
Place your finger in the door recess on the right-hand side of the sanitizer and pull open the door.
Remove the drip tray.
Remove the protective screen by gently lifting it up and pulling it forward.
To remove the UV light bulb, pull it out of the lamp holder.
Install the UV light bulb by snapping it into the lamp holder.
Align the pegs on the protective screen with the slots in the reflective surface of the sanitizer on either side of the UV light bulb.
Insert and gently push down the screen to secure it in the sanitizer.
Reattach the drip tray.
Dec 13, 2014 | Air Purifiers
Replace UV light Ecobox unit
Take the filters off and there should be a small tray that you pull out. The bulbs are in the tray
May 20, 2013 | Air Purifiers
Unit stopped working ,checked fuse,is still good,what should be done next? i am a lic.electrician so i have tools and testers just need a bit of help .... thank you ,mike
Open up the back of the machine and look inside for any corroded, broken, loose, or missing wires. One of the issues with the Fresh Airs was the corrosion of the screws and ends of the wires. There is a replacement kit of non-corroding components which can be ordered from Vollara (new name for EcoQuest 800-989-2299).
Also, make sure all components are inserted firmly and correctly. The RCI cell (honeycomb/UV light) must be seated in both ends and turned firmly, like installing a fluorescent light bulb. Other models of the Fresh Air have a separate UV light, ballast, and copper or white slanted screen. The UV/starter must be inserted correctly.
The 4" white ceramic/screen plate must be inserted into the tracks, top and bottom.
The cord must be inserted firmly into the socket in the back of the machine.
The little switch should be pressed so the "I" end is depressed and the "0" end is up.
If none of these seems to be the issue, the possible problem is with the computerized components, and only the company can deal with those! Call the above number, and they'll give you your options. Use #16618 if they request a referral number.
Jan 18, 2011 | Ecoquest Fresh Air Air Purifier
Order New RCI cell Put it in it come and goes
The reason for flashing or surging or a change of settings is usually a loose component.
1. Make sure all components are inserted firmly and correctly. The RCI cell (honeycomb/UV light) must be seated in both ends and turned firmly, like installing a fluorescent light bulb.
2. The 4" white ceramic/screen plate must be inserted into the tracks, top and bottom. The contact fingers must be pressing firmly on the screen part of the plate.
3. The cord must be inserted firmly into the socket in the back of the machine.
If this does not solve the problem, then the computerized system may be malfunctioning. This is something the company will need to address. Call Vollara (new name for EcoQuest) 800-989-2299 and ask for repairs. They
Jan 13, 2011 | Ecoquest Fresh Air Air Purifier
Fresh Air Display on and NO POWER
possibly a bad control finger control board. had a problem just like that and that repaired it.
Mar 27, 2010 | Ecoquest Fresh Air Living Air Purifier
Same prob here too.
If I cannot find the replacemnt part for the motor,we cannot remove the housing over the fan, looks like planned obsolesence to us! I will have 2 UV bulb replacements I just ordered from Brookstone for 20 each, will sell these to whomever would like them. KMWS
Aug 08, 2009 | Brookstone Pure-Ion UV Air Purifier
Ecoquest FreshAir - UV Flickering
UV bulbs, or rather the RCI cell needs to be changed every three years in the FreshAir, or when the "Replace RCI cell" appears, whichever comes first. The UV bulb loses its intensity over this period of time.
Eric
Download PDF Manual
Feb 17, 2008 | Ecoquest Fresh Air Air Purifier
Honeywell UV100RM1 True UV Coil Treatment System Logo
51 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
