Question about Canon EOS-50E 35mm SLR Camera
Mirror lock up
When I first turn on my EOS 50E the mirror locks up when I try to take first picture. The battery indicator flashes and shows empty but when I press shutter again it releases the mirror and the battery (New) shows full charge.
    Novelist:
  • Canon Expert
  • 357 Answers
Turn it off the green rectangle setting and see if it still does this (for example, turn the mode dial to P instead). If it stops doing that, then the flash up shaft in the top cover is bent. If it still does, then either the phase switch on the bottom of the mirror box needs to be cleaned, the shaft the phase switch gear is on is broken (common) or the shutter has a problem.
Posted on May 14, 2014
3 Suggested Answers
SOURCE: Shutter Lockups on Canon EOS 30 SLR Film camera
Detach the lens and try
Or Shoot at infinite focus, If the camera works then the problem is with your reflex mirror
Posted on Apr 02, 2008
SOURCE: Canon EOS 3 bc flashing even with new batteries.
I have the same problem andycapp9. Did you get it sorted? Love to know. Cheers.
Posted on Dec 12, 2011
Canon t3i will not fire
Have you got the camera set for mirror lock up. Check and disable if appropriate. When mirror lock is selected the first press of the shutter button moves the mirror up the second press fires the shutter
Mar 23, 2017 | Canon EOS 600D Rebel T3i Digital Camera
Hi when I use the creative settings I push the shutter realese button the camera clicks but does not tak the picture until I realesa the button and press it again. Is ths a setting I need to change or is...
No fault of the camera it's has been programed in custom function #9 for mirror lock up. In mirror kock up mode first click of the shutter button locks up the mirror the second takes the shot and lowers the mirror. Mirror lock up is most often used while tripod mounted for extreme close ups or macro photography and also where a large telephoto lens is used. Mirror lock up is for reducing camera vibration during exposure. You can go into your custom function menu scroll to #9 and turn this off and all will return to normal.
Dec 22, 2010 | Canon EOS Rebel XSi Digital Camera
Canon lens locks when taking a picture.
Mirror lockup is probably enabled. You can disable it by going into Menu and then Custom Functions. Select Mirror lockup and disable it.
Jul 14, 2010 | Canon EOS Rebel XSi Digital Camera
SLR MIRROR NOT MOVING MUCH
mirror box mechanism ,where a lever which moves mirror,may be broken
Feb 28, 2010 | Canon Rebel XT / EOS 350D Digital Camera
The back cover of my Canon EOS 50E camera is not locking due to the broken plastic lock please help rajadhyaksha_yatindra@rediffmail.com
hey.. i jst got the exact same problem fixed at a local store fr 200 bucks.. in mangalore.. its pretty basic.. show it to some desi-style people
Dec 28, 2009 | Canon EOS-50E 35mm SLR Camera
Canon Rebel XT Does NOT Take Pictures (AF & Exposure seem OK)
I have the SAME problem. I wrote to Canon and they told me to shut off the camera, take the battery out and wait 20 MINUTES! I can't WAIT that long, especially when I'm WORKING! I rely on this camera to work! Its annoying! Then they said if that doesn't work, to SEND IT IN and if its under warranty, they'll fix it for free.. if its NOT, then I have to pay for it. BUt the "technical team" will make the decision.
Feb 21, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS300D Mirror Problem
Never, never touch the inside of the camera with your finger! Beside all other bad things this will void your warranty if discovered.
Your camera is either defective and needs service, or you have selected the "Mirror lock up" feature which is intended for cleaning the sensor (with special tool)
Jan 02, 2008 | Canon Digital Rebel / EOS-300D Digital...
Mirror Locked in Up Position
When you say you put in a new roll of film, did the camera advance the film with the mirror locked up? Have you tried triggering the shutter few times to release the mirror? If that doesn't work, open the back of the camera. Turn the film take up spool in one direction...that should release the mirror down. Turn it also in the opposite direction. If that doesn't work, reach inside the lens mount opening and pull the mirror (very very gently) down. Don't force it down if it doesn't want to go. Sometimes that releases the mechanism that freezes from sitting idle for too long. It is always a good idea to take the camera out and triger few frames every couple of months to keep things lubricated. Let me know if that fixes it. AJ.
Sep 03, 2007 | Nikon N70 35mm SLR Camera
Canon EOS-50E 35mm SLR Camera Logo
46 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
