Question about Bosch 1971 Bmw R60/5 R 60 / 5 Swb Toaster Tank Starter
How to fix rusted choke lever that wont move
Unable to get started I believe because the choke lever is rusted in place. how do I fix or replace choke so I can start bike
    New Friend:
  • 3 Answers
You just have to put some oil on the chain not any oil take some oil on your car and put it an the chain it would work GOOD LUCK
Posted on Jun 06, 2014
How do I adjust a manual choke?
A manual choke utilizes a lever and cable assembly to open and close the choke plate. If your mower has the manual set up check the adjustment by pushing the lever to the stop in one direction. The choke plate should be either all the way open or all the way closed. If not check the cable hold down clamp, there is a retaining screw that holds a small clamp over the cable to hold the cable housing in place. Now if the choke is not adjusted properly then watch to see which way is not going full motion.Then loosen the retaining screw and slide the housing one way or the other to achieve either full open or full close and retighten the retaining screw. Now remove the spark plug and look at the electrode end and see what color the porcelain is, if it is black then it needs to be replaced or cleaned. If it is white then there is not enough fuel and the engine requires more choke to draw more fuel when the engine is cold, remember that after the engine starts and warms up to open the choke so it does not flood the engine - you will see black exhaust qnd the engine will not run smooth,
Aug 30, 2015 | Gcv160 Gas Engine
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
How come weedwacker tries to crank while on choke but when you move lever to 2nd position it tries to crank? but wont
When mine does that I go back and reprime repeating the process. It seems the gas does not feed up fully with the initial priming effort. Once it starts I move the choke lever quickly on way or the other to see if I can keep it running until it gets warmed up. Sometimes I have to adjust the choke setting even after it has run for a while.
Sep 21, 2014 | Craftsman WeedWacker Gas Trimmer 25cc...
Honda hra 215 sxc mower- choke lever will not go far enough to get engine started - must be pushed manually - how to fix?
There should be a hex head screw holding the choke cable in place. Loosen the screw a little an move the choke all the way closed and pull lever on choke to the closed choke position and tighten the screw back. Just make sure it is not pulled so tight that the choke will not open back up. Hope this helps you.
Jun 11, 2012 | Garden
It runs good but can't get it to start in cold weather. What should I do 85 Suzuki gs 550.
Without much other information of what has been done, I would start with the choke system. The choke cable may be detached or far out of adjustment. With a helper see if you can watch the choke cable move the choke lever on the carbs when you move the choke lever to full choke. Cables do break and or stretch. If that is the case then reconnect, replace, or adjust as necessary. If the choke lever and carb choke system is moving correctly then the problem may be in the carburators themselves.
Good Luck
Mar 27, 2011 | Suzuki Gs 550 L Motorcycles
I have an aldi powercraft generator pc3200dv/10 i can start it but it cuts out after a few minutes ,i am finfding it hard to find the fuel valve also it runs for the few minues with choke on but if you...
Hi there, YES manual VERY misleading, starting it all revolves around the Choke, if I remember correctly, place lever on Choke, start then move lever to on position, good luck
Dec 30, 2010 | Electrical Supplies
How to start a kawasaki th48 2 stroke engine
Typically:
1. Press primer button 6-7 times until you see fuel flowing
2. Engage the choke lever to full choke /--/ pull cord 3-5 times until engine begins to start
3. Move choke lever to 1/2 choke and pull cord 2-3 times until engine starts - - allow to warm up (about 30 seconds) and move choke lever to no choke / / /
4. If engine does not start, repeat 1-3
If engine does not start, repost with more detail. Thanks! :)
Sep 25, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a 2001 Grand Am GT! The hood wont open...we have a lever on it! But it feels like it is frozen so it wont open the HOOD! So how will I Manually open the HOOD????????
If you can see the lever then get some rust penatrent and spray it where the lever is.A good penatrent that works real good is P.B.Blaster.Then try to work the lever with a pry bar little by little til it starts to move.The lever is probably just rusted tight.Hope this helps.
Dec 15, 2009 | Pontiac Grand Am Cars & Trucks
Bosch 1971 Bmw R60/5 R 60 / 5 Swb Toaster Tank Starter Logo
50 people viewed this question
Top Bosch Kitchen Appliances - Others Experts
Martin Olney
Martin Olney
Level 1 Expert
Oloyede Monsuru
ray gallant
Are you a Bosch Kitchen Appliances - Other Expert? Answer questions, earn points and help others
