Question about LG 50 50PW350 50 3D Plasma TV
50PW350 won't turn on
Was clicking recently and now won't go on.
  • LG Master
  • 3,320 Answers
There are no user serviceable parts on these flat panel tvs.
Use your warranty if available. This is why buying the extended warranty on expensive electronics is a good policy.
Find a nearby electronics repair shop and get it checked over.
Posted on Mar 28, 2014
Lg plasma turning on then off
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 28, 2016 | LG Electronics 50PW350 50" 3D 720p Plasma...
Where is the fuse for lg 50pw350
It can be located at its main power regulator board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 07, 2014 | LG 50 50PW350 50 3D Plasma TV
Is there a fuse for lg 50pw350
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time; especially to Plasma TVs.
50PW350 won't go on
Are you comfortable working with the high voltage innards of a plasma TV, including the use of a Multimeter, Soldering iron or gun, and electrical safety? If so, you will have to inspect the insides and look first at basic items such as the fuses, but continue diagnostics from there to all components, using care not to electrocute yourself. If you are not comfortable with such a thing, then professional repair or replacement of the unit is recommended. LCD televisions do not have such high voltage driver issues and do not suffer from burn in like plasma screens do, plus use substantially less electricity.
In either case, the symptoms you describe tend to come from dirty line power, so the acquisition of a UPS (Uninterruptible Power Supply) that will perform Automatic Voltage Regulation is highly recommended to scrub the A/C current and swap to battery if things get to a level that would potentially damage the TV. This kind of investment can increase the life of A/V equipment by twice or more.
Mar 28, 2014 | LG 50 50PW350 50 3D Plasma TV
2004 chrysler pacific will start sometimes but sometimes won't
I would suspect the fuel pump is the problem, it may be sticking at times and this causes a no start. The pump is located inside the fuel tank and it is electric.
Mar 28, 2017 | 2004 Chrysler Pacifica
My laptop Hp G60 won't turn on the charger light
Maybe you have disconnected the small cable which connects the power button to the motherboard. Or your charging unit at the back of your laptop is faulty, take the cover off and click the button without it on maybe a alternative. Only other solution would be have you had a powercut recently?
regards,
jon
Apr 21, 2012 | HP Computers & Internet
Maytag gemini electric ignition won't shut off
Your valve switches are defective. Sometime they will do that if you recently had a boil over and they have got wet. Try turning the breaker off for 24 hours to see if the fixes the problem.http://www.on-timeappliance.com/ovenrepair.html
Mar 27, 2012 | Maytag Gemini 30" Self-Cleaning...
Car won't start. New battery installed recently. Only clicks when trying to start.
one single click any time you turn the key usually indicates a bad solenoid on the starter. A new starter will typical get you going.
A series of rapid clicks when you try to start usually indicates a weak battery. There could also be a bad connection at the terminals on the battery or even a poor connection at the starter.
If you get a single click and everything goes dead for a couple of seconds than you definitely have a bad connection at the battery.
Let me know what you find or if you have any questions.
Dec 28, 2011 | 2007 Chevrolet Tahoe
Mercury sable 2004
Depends on the sound that it makes when you turn the key over.
Clicking noise...usually the starter
If it sounds like its going to start, but doesnt, most likely the battery.
If you have replaced the battery recently, then its the alternator.
Sometimes there can be oil build up over the spark plugs so it doesnt get the spark to start.
Hope you get it fixed!!
Jul 01, 2008 | 2004 Mercury Sable
My Indesit Washing machine doesn't seem to start?
Most likely water has short-circuited your controls; you need a specialist here.
Apr 09, 2007 | Indesit W 123 Front Load Washer
LG 50 50PW350 50 3D Plasma TV Logo
41 people viewed this question
Computer Repairing
Computer Repairing
