LG monitor displays "D-SUB POWER SAVING MODE" when it is starting
I replaced the battery in the mother board, still has the same results.
    Scholar:
  • 63 Answers
The message it is displaying indicates that a VGA cable is connected and is not sending signal, or is sending a Monitor Off signal across the VGA cable. The motherboard battery will have no impact on this. If you are using something other than a VGA cable to send the signal to the monitor, then you should ensure that no VGA cable is plugged into the monitor, or the source on the monitor is not using the VGA connector.
Posted on Mar 28, 2014
  • 3940 Answers
SOURCE: No display.
http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm#Using%20the%20OSD
Make sure the proper input is selected
1: D-SUB for Blue VGA cable
2: DVI-D for White DVI cable
The option selected should be indicated on the power save screen.
If changing the input select and rebooting the computer have no effect an no video from the computer is ever displayed, then the monitor is in need of repair.
Posted on Jul 01, 2008
Fix-4U
  • 293 Answers
SOURCE: my LCD monitor is going into power saving mode
Hi...there,
Your monitor enter to power saving mode to prevent further damaged. It's seems you got a busted backlight inverter... Need to replaced a new one or repaired it...
Posted on Oct 13, 2008
SOURCE: LG LCD monitor goes in power saving mode
press fn + F5 buttons, screen will appear
Posted on Dec 21, 2008
SOURCE: New LG 2452T keeps going to digital power saving mode
i had the same problem.
connect the monitor with the analog cable and shut down your pc.
while it is off unplag the analog cable and place the digital one(dvi).
this should fix your problem m8 ;)
Posted on Mar 05, 2009
  • 2841 Answers
SOURCE: after starting, my monitor displays "power saving mode".
Go into the menu and reset the monitor to factory defaults.
Posted on Aug 28, 2009
Acer pc and lg monitor blank screen says power save mode on start up, anyone know how to fix this?
Actually during start-up there is a slight delay before the HDD & OS is detected by the CPU. Normally all monitors slip into power saving mode within 10 secs of inactivity of either mouse or keystroke. This inactivity is read by the monitor which promptly switches to power saving mode. However the moment the HDD LED starts blinking, the monitor wakes up & starts displaying. This power saving mode in most of the flat screens is only associated with movement of mouse or keypad. This does not register till the CPU starts up & thats why the monitor switches over to power saving mode till it starts receiving signal from the CPU.
It is a normal behaveour, so don't get worked up over it, plus you can always hit the Auto set feature on the monitor after booting the PC completely. ( I think the time out for the monitor to enter power saving mode is only 10 secs). Hope this helps.
Oct 08, 2012 | Computers & Internet
Lg 1752s goes into power saving mode when pc is turned on
Hello Alan,
That is actually not power saving mode, the flashing power light indicates the power supply is not starting up correctly and keeps shutting down and trying again. This is a very common symptom of a failure of the capacitors on the power supply board. The L1752s uses the AIP0157 power supply board which is the same board the is used in several LG monitors such as the L196WTQ and L194WT. Here is a link to a repair guide for the L196WTQ that shows what capacitors to look for and replace on the power supply board to bring the unit back to life.
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/
I hope this helps, if so please rate my solution.
BuddyMc
May 15, 2012 | LG L1915S 19" LCD Monitor
Automatically power saving mode ...........................cpu start working..........monitor power saving mode
Hook a spare monitor to the computer, if the same symptoms occur the problem is the Video Graphics Card in the computer, but if the picture is okay, it is clearly the LG Flatron that has the problem, and if possible sub the video cord from the computer to the monitor just to be sure.
Mar 10, 2012 | LG Flatron L1951S 19" LCD Flat Panel...
I have an LG E2350V monitor. When I connect to my desk top PC, it starts to display the pc starting up sequence, then after 20 seconds or so goes into Power Saving mode and it wont get out of it. ...
Hi keepintouch0,
Make sure that the power save settings are not set in the OSD of the monitor , and if they are set to switch off after some time , then you need to change the settings as per your requirement.
Hope this helps ...:) Let me know in case you have any queries.
Aug 01, 2011 | LG Computers & Internet
Have lg monitor flatron e2260 . Have had for about 3 weeks. Starting today, the monitor goes black and states "d-sub power saving mode". The tower stays on. Thx
1. Check the connections and make sure they are still tight. If the monitor isn't getting data signal it can go into power saving mode. Since it was working I would check this first.
2. Look in control panel under POWER OPTIONS and make sure it's not set to turn off after so long.
3. Also check the settings for your screensaver under display settings. That too could put it into poewr saver mode.
It could be a setting on the monitor itself that somehow got changed. Check out the settings to see if anything has changed.
Apr 21, 2011 | LG Computers & Internet
After starting, my monitor displays "power saving mode".
Aug 28, 2009 | LG L1915S 19" LCD Monitor
LG L1832S Monitor not working
LG monitor shows a green light and then goes in power saving mode and a yellow light appears,
Aug 13, 2008 | LG L1915S 19" LCD Monitor
Monitor automatically clicks into power saving mode
I have an LG W2261V, and an old Sharp LL-T19D1-H. The PC runs both just fine, and the PSU has plenty of power. Unfortunately the LG handles power save mode very differently, where the LG would not switch on after entering this mode unless reset (unplugged, PC rebooted, etc). Extremely frustrating, as the old Sharp never had any problems exiting its own power save mode. The LG would enter this mode based on the monitor power settings (in whatever power scheme you are using) in the screensaver tab in display properties. I fixed this by selecting "Never" for "the Turn off monitor" property. I guess this is a warning to those who may wish to buy a new LG monitor, but want to use a power scheme to turn off the monitor.
Oct 01, 2006 | LG Flatron L1951S 19" LCD Flat Panel...
Digital power saving mode
Are you sure someone hasn't changed the power setting in windows. I've seen similar tricks pulled by so called mates. :-) If windows is OK then check the manual for the monitor and if you still can't crack it take it for a ride to the repair shop. It is under warranty after all. BMW
Jun 03, 2006 | LG 1720B 17" LCD Monitor
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
