Question about ViewSonic Office Equipment & Supplies
Green screen on VGA with Viewsonic PJD5122
The projector has 3 VGA ports and the problem persists with every port. Multiple VGA cables have been tried, and multiple VGA-out devices, and it's all the same. The projector's demo screen is a colorful image on a white background, and looks fine when the projector boots up.
    Scholar:
  • 63 Answers
VGA is separated analog signals in Red, Blue, and Green. Under normal cases, you'd be able to change the cable, source, or input port and resolve the issue. Unfortunately, if the green tint persists with all input ports on the projector (The two blue ones are Input, the black one is output. There is a potential that attaching input to the black output port could have caused the damage), different sources, and different cables, then it's likely a problem with the projector hardware itself and would require warranty service or otherwise repair or replacement of the projector. If you have an alternate way the projector can be attached, then try that (Such as SVideo), otherwise there may not be any good solution in this case short of checking the guts of the system.
Posted on Mar 28, 2014
dodgecharger
  • 254 Answers
SOURCE: projector is not able to project red from the vga cable
I assume connecting a monitor/lcd panel display doesn't exhibit the missing red? To narrow this down, try using the cable with either a different projector or monitor/flat panel display. In short, does the problem follow the cable to these other devices? If so, then even though there are no pins bent over, the cable is probably bad. Cables can develop an internal connection break, even without showing any external evidence. This will usually occur at a connector end, and is often the result of overflexing, bending or other straining of the cable near the connector. Can you borrow another cable from a friend? A couple of other possibilities: 1. A broken solder connection at the VGA jack inside the projector. This can occur, again, if the connection is stressed (flexed, jammed, pulled on etc.). 2. The circuitry just beyond the VGA jack, which processes the video information could have a defect, not passing the Red info. The latter problem is one for a capable technician, and depending on expertise, you might be able to repair a broken solder connection.
Posted on Feb 15, 2007
SOURCE: Color bleeding - blue colors always on the screen
just came across this same prob on my projector. Any ideas?
Posted on Dec 13, 2007
SOURCE: Dell 3200 Projector color green instead of yellow on VGA not on S-Video
I changed the setting for color heat and got the right colors on the screen. The color is now perfect!!!
Posted on May 09, 2008
Marrie
  • 563 Answers
SOURCE: ELMO Projector image not working
Hi schmidtkm
All the sympoms mentioned above is that of a faulty Mainboard that will have to be either repaired or replaced.
Trust me on this one , I work on Projectors every single day of my life.
Posted on May 13, 2008
projdoc
  • 2237 Answers
SOURCE: Bought 3 MP3300 projectors for presentation projects
you can replace the colorwheel yourself, but unfortunately dell does not sell parts. you need to send the projectors in for repair. and like the other guy said, never buy lamps from e-bay.
Posted on Jul 08, 2009
How do i connect to cable tv to receive pictures from that source?
connect the video output from the cable settop box/decoder to the video input on the projector. also connect the sound signals as well
Jun 06, 2011 | ViewSonic PJD5122 3D Projector
How do I connect the Acer netbook to the TV?
The only option is using the VGA port on the Aspire One to hook it up to the TV.
Your TV must have a VGA in port for your to be able to hook your computer to your TV. All you need is a regular VGA cord.
Mar 26, 2011 | Acer Aspire One Netbook 8.9" Notebook
What cable or adapter do I need to connect my projector to a MacBook video out port?
You will need a Mini-DVI to VGA adapter. Apple sells this item through their online store.
http://store.apple.com/us/product/M9320G/A?mco=MTY3ODQ5OTY
You will also need a male to male VGA cable to attach the adapter to the projector.
You can find modestly priced cables at monoprice or other retailers. example: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10201&cs_id=1020102&p_id=2898&seq=1&format=2
Plug the cable into your projector and then plug the adapter into your MacBook. The MacBook will automatically resize your picture to the appropriate resolution for the projector.
Enjoy!
Feb 27, 2011 | ViewSonic PJ503D DLP Projector
I have an Acer One netbook and tried to connect it to a projector but the normal looking lead from the projector did not seem to fit. The lead has those two wee screws at the side, and no place for them...
The Acer One netbook has a mini-VGA port on its left side. Page 10 of Acer's QuickGuide shows the port as item 3 External display (VGA) port. But unfortunately, the description shown for it is incorrect.
From your description, your projector's lead likely has a mini-VGA connector on the end as pictured. The connector can simply be plugged into the mini-VGA port but there are no holes beside the port for screws so it would just be a friction fit which should be sufficiently secure for most puposes. The connector and port are mini-DB 15 male and female respectively and can only fit one-way. The port has the wide side of the D on top so you would have to turn the pictured connector over to be able to plug it into the port. Windows XP should be able to detect the projector via plug-and-play installing any display drivers if required. Page 8 of Acer's UserGuide describes Hotkey + Display toggle which switches display output between the display screen, external monitor (if connected) and both. Pressing + with the projector plugged in will bring up a window in the middle of the screen allowing the selection of internal display, external display, both, or a 800x600 VGA projector. If the display is on the projector, unplugging the cable should automatically revert display back to the internal screen. For VGA see http://en.wikipedia.org/wiki/VGA_connector splines.jpg
Jan 26, 2011 | Acer Aspire One Netbook 8.9" Notebook
The projector shows slides as purple but computer has the right colours?
Check your cable...you are missing one of the primary colors. you could have a bent/broken pin on either the projector port or the cable or laptop port. this would be the VGA connection.
Jun 06, 2010 | ViewSonic PJ501 Multimedia Projector
What cable(s) do I need to connect a dell 3300mp projector to my Macbook Pro?
HI.... ........YO U NEED A ADAPTER WHICH IS CALLED MINI-DIV TO VGA ADAPTER....THIS ADAPTER WILL HAVE TWO PORTS ONE PORT IS CALLED MINI-DIV PORT ANOTHER PORT IS CALLED VGA FEMALE PORT (WIDER THAN DIV PORT)..NOW PLUG THIS DIV PORT TO YOUR MACBOOK AND THE OTHER ONE IN YOUR PROJECTOR ...YOU MAY ALSO NEED A VGA CABLE..
May 27, 2010 | Dell 3300MP Multimedia Projector
The color on my screen is tinted green
That means the connection or vga port is not receiving connection...either diconnect the cables and turn of ur computer then connect and restart......make sure the cables are completly inserted...If the problem persist then u should try getting a new vga cable....If that does not work........Test the vga port from ur hard drive with another monitor to see if the problem is from ur hard drive.
Mar 09, 2010 | E-Machines eMachines Monitor E15T4
Can't get projector and computer to connect! no image
CHECK THE VGA PORT OF THE VGA SPLITTER IT WILL BE OK IF U CONNECT A MONITER FROM THE OUTPUT END AND SEE IF THE PORT IS OK THEN LATER U CAN GO FOR CHECKING PC AND CABLES.
Apr 08, 2008 | Office Equipment & Supplies
I have found that the S-Video port has the correct colors, but the VGA port has green inplace of yellow. I believe the VGA port on the projector is the problem. I don't know how to replace the VGA port or if it can be replaced. Thanks D. James, tweezers.
Mar 29, 2008 | Dell 3200MP Multimedia Projector
133 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
