Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
How can I keep my cleaner from unthreading
The cleaner cleans when it stays together. It comes apart (unthreads) at the hose/head connection daily. What can be done to prevent this?
    New Friend:
Get the tape that goes on plumbing fixtures,, wrap aroung threads and tighten,, in addition I found a waterproof tape at home depot and I wrapped the entire outside of the part that comes loose and have had it in my pool now for over 3-4 months and nothing comes loose,, try it as works for me
Posted on Mar 28, 2014
Janome 900 cover hem needle wont stay threaded
The thread pulls out when you begin to stitch? Pull more thread tail through the needle eye. You can also try holding the thread tails in your left hand when beginning the first stitches.
Jan 18, 2018 | Janome Sewing Machines
Why does my needle keep coming unthreaded? It sews 2-5 stitches then my needle cones unthreaded.
check that your needle is in the right way ie. with the flat face facing away from you. Is you tension correct? that is doe the sewing look okay?
Oct 30, 2014 | Simplicity Sewing Machines
Thread comes unthreaded in lower looper
Unthread the needle eye, then thread the lower looper, then rethread the needle eyes. 99% of the time, that's it.
Apr 04, 2014 | Singer 4/3 Thread Overlock Serger Machine,...
My needle keeps coming unthreaded when sewing
normally when you use longer thread tails of 4 to 6 inches and move
the thread tails behind the needle before starting to sew.
Mar 07, 2013 | Singer 7436 - INGENUITY
How to remove pressure hose
either there is a clamp that needs the two ends squeezed together and it will slide down the hose, or you need two wrenches to unthread the hose
May 28, 2012 | Office Equipment & Supplies
My yard machines push lawn mower 21 in cut 4 hp wont stay running unless i keep priming it
Try removing the brass bolt that holds the float bowl on the carburetor and cleaning ALL the tiny holes in it. Use no metal objects on it as it is also the main jet of the carburetor. Carb/Choke Cleaner aerosol spray works well here. Pay close attention to real small holes near the top in the unthreaded portion of the bolt. Remember, no scraping with metal and no metal wires thru it.
May 10, 2011 | Mtd 22" Yard Machine Push Mower
It keep coming unthreaded at the need when i start sewing
You must hold the top thread at the start of every row of stitching, if you dont then the tension will pull the thread backwards.
May 16, 2010 | Sewing Machines
My singer serger isnt sewing..
Did you check to see if one of the needles or loopers are unthreaded, 9 times out of ten one or the other is unthreaded.
Jul 07, 2009 | Singer 14SH654
NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Most machines need to have the thread extend to the back of the machine in order not to come unthreaded.
May 20, 2009 | Brother LS-2125 Mechanical Sewing Machine
Slow and nonexistent water flow.
Start by removing the spray head from the hose. Pull the spray head out and with a channel lock pliers unthread connection between the spray head and hose. BE CAREFUL not to let the hose fall back down into the faucet. With the hose directed down toward the sink test for volume by turning on the faucet. If you get a nice volume the problem is in the spray head. This is usually the case. Put the spray head back on then remove the aerator. It's the screen where the water comes out of the spray head. Clean out the assembly ( 3-4 parts). Reassemble and test.
Good luck, Phil
Dec 11, 2008 | American Standard Bath Faucet Ceramix...
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
180 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
