I have a 6 year old GE Profile washer that is not spinning or or agitating. I tried resetting motor and it worked then stopped. GE technician came out and used his computer which showed motor reset.
Water drains but only hear humming.
    Master:
  • Washing Mach... Master
  • 753 Answers
Need a model but sounds like you may need a motor
Posted on Mar 30, 2014
  • 1028 Answers
SOURCE: GE Profile top load washer
that is one of the worst placed for any appliance..storage when not used regularly corrison set in parts tend to stick and rust forms when it usually doesn't suspect break/clutch is binding from sort of build up may try letting it go through complete cycle without a load and normal fill ..a long enough high speed spin may free up and remove some of the buildup simply by friction if that fails may need to call service
Posted on Sep 14, 2008
hiltonjug
  • 612 Answers
SOURCE: ge profile washer WPSR3100W1WW won't agitate
I see this pretty regular. You have a bad transmission. This is very common with the older GE's. To replace the transmission will run around $340 / $400. Not sure about your area. Just be glad you got this much use out of it, you are one of the very few that have. From 1998 till 2007 I owned my on repair company where I did GE's warranty work in my area for them. During that time period. When I found a GE washer under warranty doing what you are describing. GE would warranty the whole machine. They would have me destroy the machine after I would deliver the customer a band new one. GE knows they had a bad transmission and it cost them a lot of money. It was cheaper for them to replace the washer than have me repair it. The transmission list price was $298.00 back then. A word of advice, when you replace it. Buy a Whirlpool, Kenmore, Maytag. These brands hold up the best. I have the least service calls for Whirlpool and Kenmore. Both are made by the same people. Kenmore is made for Sears. Good Luck.
Please rate this solution if helpful. Thanks
Posted on Aug 21, 2009
oldmanewtoys
  • 414 Answers
SOURCE: I have a GE WBSE3120B2WW top loading washer and it
wig wag relay needs replaced
Posted on Mar 08, 2010
heatman101
  • 43501 Answers
SOURCE: GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 12, 2010
KevinWhite
  • 1902 Answers
SOURCE: My GE profile top load
Hello & Welcome to FixYa
The problem is with the pressure switch located inside the control board that has gone bad and needs replacement. Pressure switch(water level switch) controls the water pressure, as it overflowed earlier so it indicates that the pressure switch has gone bad and the water inlet valve seems to be working fine. Please get back to me with its model# if you have any other questions.
Kevin
Posted on Jun 09, 2011
GE washer WPRE6100G0WT not agitating or spinning
Depends on how old the machine is. It might me a transmission problem
Jul 25, 2012 | GE Profile WPRE6100G Top Load Washer
GE profile top loader, agitator and spin start and stop
Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
May 23, 2017 | GE Profile Prodigy WPSE4200A
My GE washer won't spin or agitate
check the motor capacitor if your motor doesn't turn when powered, otherwise the "wig-wag"coil could be faulty,these coils shift your transmission for different cycles
Aug 23, 2009 | GE Profile WPSR3100W
1.5 year old ge profile washing machine will not agitate or spin
Timer seems to have gone bad. Manually move the timer to make the dryer spin. If you get it to spin and drain then it's your timer.
Jul 01, 2009 | GE WDSR2080D Top Load Washer
Washer does not agitate. Will spin and drain.
bad dogs pull off center cap remove bolt carefully lift off dogs are two pieces that catch to agitate they are minimal cost and are easy to replace they wear out especially with heavy loads!!!Best of Luck to You!!
Jun 28, 2009 | GE Profile WPRE6100G Top Load Washer
GE Profile washing machine not finishing cycles
the OL error is for over load.that is when you over load the clothes in the washing machine. If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
May 07, 2009 | GE Profile WPRE6100G Top Load Washer
GE Profile WPRE6100G will not spin
hi thanks for the question. i think the problem is with the lid switch . lifting the lid 10 times wont help if the switch is faulty check the lid switch thanks the appliance doc
Sep 20, 2008 | GE Profile WPRE6100G Top Load Washer
Spin and Agitate problem on GE Profile Prodigy WPSE4200A
This machine uses an electric water pump. I would check to motor. Remove the front panel and operate the machine to see if the motor is working. Check this by listening to the motor and watching the belt. If you hear the motor but the belt does'nt move then there may be a problem with the pulley or motor clutch assy.
As far as not draining or pumping water ? Check the wiring from the pump to the control panel. If these wires are alright then i suspect the pump.
Nov 15, 2007 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
97 people viewed this question
Top Washing Machines Experts
