Question about NorStar Meridian M7310 Phone
When i press open mailbox it says talk busy and will not let me put in my passcode
Need help gettig into my voicemail.keeps displyig talk busy
    Sergeant:
  • 244 Answers
I agree with Dan. Power cycle to clear hung ports.
Posted on Mar 29, 2014
3 Suggested Answers
SOURCE: I locked myself out of my voicemail for Norstar M7310!
Feature 983 is system admin
1. Log into system administration
To Reset a Mailbox Password:
2. Select the softkey under “MBOX”
3. Select the softkey under “Chng”
4. Enter the mailbox number you want to reset the password for
5. The display shows “Reset Password”
6. Select the softkey under “RESET”
7. Press the release key
*The new password will be “0000′, the system will ask the user to change
Posted on Aug 06, 2009
  • 14 Answers
SOURCE: *talk busy Norstar M7310
reset your voicemail, power cycle and see if that clears the problem.
Posted on Nov 20, 2009
How to check voicemail messages
I assume you mean voicemail messages taken by voicemail service on your telephone line, the ones indicated by a flashing "voicemail" indicator on the phone. You may need to contact your service provider as not all systems are the same, but here's how it usually works. From your home phone, dial your own number so that the voicemail answers. Press the "*" button and you'll be prompted to enter your passcode. (The default passcode is usually the last 4 digits of your phone number, and you enter a new one when you go through mailbox setup.) Once you've entered the passcode and are in the voicemail system, voice prompts guide you through how to access messages and make setup changes. To process is usually the same to check your messages when you're away, although some service providers may give you a different access number to call. Again, check with your service provider for all the details if your system is different.
Sep 14, 2011 | Vtech 5.8GHz Analog Cordless Phone
Mailbox passcode is uknown. used admisitrative mailbox to reset the pass code. what is the new pass code?
This depends on the voicemail system. Here are some common default passwords for voicemail.
1234
0000
1111
9999
4321
7777
Hope this helps.
Jan 04, 2011 | Toshiba DKT-2020-SD telephone
Employee forgot his password and need to change the voicemail for new employee. Is there a way to reset the phone. Phone model is a Superset 4025. My phone number to the phone is (563) 690-3230 or email...
Each mailbox password is held in the system programming of the voicemail system. You need the system admin password for voicemail. Dial the access code for voicemail, if from a phone with voicemail then press * to get to the main greeting. At the main greeting dial * then the system admin mailbox number which is 99 for 2 digit ext numbers or 999 for 3 digit ext numbers or 9999 for 4 digit ext numbers then you will be prompted for the system admin passcode(default 1234). Press 2 for add/edit/delete (Never press 1 for new installation or you could delete all current voicemail programming and messages). Press 2 to edit mailbox, you will be prompted for the mailbox to edit, enter the mailbox number. Press # to skip to the passcode reset, enter the new passcode or press * to reset to default(999) then press # for each of the remaining parameters until you are returned to the mailbox menu which prompts for press 1 to add mailbox, 2 to edit mailbox, and 3 to delete mailbox, then hangup.
Dec 07, 2010 | Mitel Superset 4025 Corded Phone...
I have an old MITEL 4025 in my new office. Noone seems to know how to set up the message/ voicemail option. I need step by step directions. Thank You.
You need to know the Voicemail access code... I generally set this up as 77, but other installers will set it with a different number. This will be the same number that others in your office dials to reach Voicemail when they have a message.
Your mailbox will also need to be created in the Voicemail system. When you call into it, it should recognize you and prompt you for a passcode. The Mitel Embedded Voicemail system default passcode is 1111. You will be prompted to set up the mailbox and change the passcode.
If this doesn't help, contact your site administrator or vendor.
Sep 21, 2010 | Mitel 5220 IP Phone
How do I set up voicemail on a mitel 5212 IP Phone
Assuming you have the Embedded Voicemail... dial the Voicemail access number... it should recognize your extension number and prompt for a passcode - the default is 1111. Follow the prompts to set it up.
If the mailbox is already set up from a previous user, have your administrator reset it.
Sep 14, 2010 | Mitel 5212 IP Phone
Change voice mail message from one person to another person
Step 1 Lift the handset for your telephone and listen for the dial tone. Dial the access code you were given by Verizon when you signed up for residential telephone service. Dialing the access code will call the voicemail system. If you do not have an access code, you will need to call Verizon Customer Servicemag-glass_10x10.gif (see link in Resources).
  • Step 2 Identify the telephone number you are setting up voicemail services for. If you are calling from that telephone number, enter the temporary passcode and then press "#." The temporary passcode is the last 4 digits of your residential telephone number. If you are calling from a different phone, press "*" when the system greeting starts to play, then enter the 10-digit telephone number when prompted. After this, you will be asked to input the temporary passcode.
  • Step 3 Choose a new passcode. The passcode must be from 4 to 8 digits in length. It should be easy for you to remember, but difficult for others to guess. Do not use easy to guess numbers, such as 1234 or 1111. Also do not re-enter the same temporary passcode, since it will be easy for anyone to guess.
  • Step 4 Record your name. Simply say your name, without a long complicated message. This recording is used by the voicemail system to identify you whenever you forward a message to another user. It is not used as the standard greeting when a caller is directed to your voicemail to leave a message.
  • Step 5 Record or change your personal greeting. This greeting is played any time someone reaches your voicemail box. Record a friendly greeting to announce that you are unavailable and will return all calls upon your return.
    Decide if you want to set up a different mailbox for each family member. Verizon residential telephone service allows you to set up multiple mailboxes so that everyone can have his own private message center. Callers who reach voicemail will be prompted to press "1" to leave a message for one person, press "2" for the next person, and so on.
  • Step 6 Hang up the telephone. When you have finished setting up the voicemail system on your Verizon residential phone line, hang up the phone to end the call and exit the voicemail system.
  • Nov 08, 2009 | Uniden Cordless Phone
    Not able to access our main voicemail on Vodavi Starplus STS
    To access the System Administrator Mailbox:
    1. Dial into voice mail: From any phone on system dial 150
    2. When the system answers, dial [*] + [#] followed by the System Administrator Mailbox number: (# 0 0 )
    The system will announce: “Mailbox 15-00”, which is the System Administrator Mailbox number.
    3. When requested, enter the System Administrator password. Default = [9]+[#]+[56].
    How to program greetings
    1. Access the System Administrator Mailbox as described above. The System Administrator Mailbox Menu plays.
    2. Press [1] to access system greetings. The system will prompt you for the greeting number
    3. Enter the desired greeting number.
    For example:
    1 = Default Day greeting
    2 = Default Night greeting
    3 = Default Temporary greeting
    4. You will be prompted with the following three choices:
    Press [1] to Review.
    Press [2] to Record. You will be prompted to record the greeting
    When you finish recording, press [#] to save the recording.
    You can then
    Press [*] + [*] + [*] to exit the system completely
    Jul 07, 2009 | Vodavi Starplus SP7314-08 Corded Phone
    Nortel T7316e help
    dial your voicemail, put in your password, after you are in the voicemail, press 8 and listen to the prompts, it will tell you were to record your name for the company directory.
    Jun 26, 2009 | Nortel T7316E 2-Line Corded Phone
    Ip 5220 Mitel
    You'll need to log into the voicemail server or PBX that hosts the VM and reset the passcode for each mailbox you're trying to access. If you have an embedded Mitel VM you can change the passcode by logging into the Admin mailbox then select option 2 to edit mailboxes, pick the mailbox to edit and follow the prompts until you have the option to change passcode
    Jan 29, 2009 | Mitel 5220 IP Phone
    Access voicemail from Nortel T7208
    Have you set up the voicemail before?
    OK, from your set;
    -> dial FEATURE 9 8 1 (this is the code to get you to the voicemail)
    -> then your passcode, if you never set up the voicemail, the temporary password is 0 0 0 0 (four - zero's).
    -> if this is a new installed voicemail, the telephone system will tell you al that you need to initiate the voicemail box.
    Jul 29, 2008 | Nortel Business Series Terminal T7208 -...
    NorStar Meridian M7310 Phone Logo
    54 people viewed this question
    Top NorStar Lands Phones Experts
    Oloyede Monsuru
    Computer Repairing
    Computer Repairing
    Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
