Question about Micro Innovations Computers & Internet
Broken battery terminal
How do I reconnect the wires to the battery terminals? They where corroded and when I was cleaning them the wires came off
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 108 Answers
You would need to buy an soldering iron + solder. Do some practical on old electronic circuity before to perform the fix. Pay special attention to the Positive (+) and Negative (-) wires. Also apply just the necessary solder and be quick (but precise) since the battery case contains plastic and the battery is sensible to high temperatures.
Posted on Mar 29, 2014
2 Suggested Answers
  • 2976 Answers
SOURCE: V220 Mouse. Which way does battery positive terminal go?
A button cell looks exactly opposite of a regular battery. The small button end is negative.
Posted on Feb 28, 2009
Dodge spirit problems
Can be several things: Loose terminal connections to solenoid, corroded terminals or wires, bad solenoid with burned coil or pitted contacts. Lastly, a too worn out key switch. To find out, test proper (12VDC) voltage at solenoid coil terminal, check for a bad ground too. Then test wiring between key switch and starter. Some power feeds are fed from fusible link harness behind battery box. For the age of the car, there could be some corrosion on terminals or even corroded and broken fusible wires because of nearness of battery acid vapors tend to eat near wiring slowly. My two cents. Amclaussen.
Jul 07, 2014 | 1994 Dodge Spirit
I left the batteries in it, and one of the batteries corroded. how can i take it apart to clean it
One old trick was to use some baking soda on terminals. It will turn terminal black, but you can still use it if terminal is not broken off. If you have soldered in batteries clean an scrape terminal an resolder.
Feb 22, 2014 | Cobra HH-38WXST CB RADIO 40CH 10 WEATHER...
Ihave a 2002 grand am and the cruise will work sometimes and then at other times it wont, also my turn signals wont work sometimes but do work other times! any suggestions? ty Tommy
Loose ground and or a corroded fuse. Check all the fuses related to engine management and if your battery terminals are corroded remove your terminal connectors and wire brush them clean.
Remove all accessible ground connections, wire brush them and apply die-electric grease then reconnect the connection.
Feb 16, 2012 | 2004 Pontiac Grand Am
My vehicle will not start. the engine makes no sound, so what may be the problem and how do i fix it.
if you have coroded battery terminals clean them with water and baking soda and a wire brush then reconnect them and seal them with vasoline then jump start the car also if your terminals are corroded most likely the battery is shot and the alternator will burn up trying to charge a weak battery so replace the battery if bad or you will be replacing the alternator soon as well
Aug 15, 2010 | 1995 Honda Accord
My truck wont start or even attempt to crank but continuos clicking comes from behind the fuse box and clicking stops when brake is pressed. what is the problem???
battery terminals are corroded. loose terminal connection. take off, wire brush terminals ans bat cables. reconnect tightly.
Jan 18, 2010 | 1999 Dodge Ram
Positive terminal keeps getting corroded even after 3 weeks.
Try keeping the terminal far away from any moisture and dirt. In fact isolating it may not be a bad idea. Try getting a battery box for it or sealing off the existing one, just make sure to use a drain tube and vent. Some stores have battery terminal isolators, these are less effective but can help. There is also a battery terminal sealant spray that may be helpful if you cannot get/use a battery box. Clean the terminals thoroughly, spray the terminal sealant, and use the battery box for a three way attack. This is especially use full in harsh climates. These methods can also be used on remote battery terminals that are on some cars.
-Dynami
May 04, 2009 | 1995 Chevrolet Lumina
Have a Vtech 6058 toy laptop need to know how to reset
From your query, I guess the problem lies on the battery terminals or wires connected to the battery terminals. Did the old batteries leaked? If it did, the battery leak must have reached the wires inside your computer and corroded the connections. If you are a DIY person, you may open the bottom of your computer by taking out the phillips screws, around 10 (not so sure). Locate the wires connected to the battery terminals. Reconnect the broken connections (better to solder them if you can). Hope I helped you with your problem. Good day...
Jan 08, 2009 | Vtech Nitro Notebook Kids Laptop Computer
Battery issue.....
look closely if there are wires hanging near the positive terminal of the battery.
you could have miss reconnecting one wire that is connected to your starter or the main cable itself is corroded and is not making a contact. that main cable is the one hooked to the starter.
tnx 4 using fixya,
drcool
Sep 14, 2008 | 2004 Nissan Altima
Computers & Internet Logo
Top Micro Innovations Computers & Internet Experts
micky dee
Joseph Hoffmann
Are you a Micro Innovations Computer and Internet Expert? Answer questions, earn points and help others
