Akai pt5499hd just shut down
Was just watchin and pop went off ,light on frt works with remote or from power button ,,no sound lamp flicks with each button pushed ,no surge was noticed ,,any ideas,need tv to survive ,,
If you are electrically inclined, there is a power deflector board that may need to be replaced. This deals with the high voltage part of the TV, so I am not responsible. The part number we had to but and replace was BP94-01289A or about $130.
Posted on Nov 10, 2007
  • tmc0001 Nov 24, 2010
    if you still have this tv i am willing to buy some parts from you...if you decided you didnt want to fix it..
  • notodd72 Feb 05, 2011
    I have one that did the same. I can see the ceramic resistor that burnt on the high voltage board... can this be fixed or do you want to buy some parts
Akai rear projection tv suddenly stopped working.
This set with Akai is actually made by Samsung (they own and use the Akai name).
If lamp light etc and you have heard a cracking sound it may be the color wheel.
You can remove the lamp and look where it faces--look and the wheel can be seen----is it shattered or missing plastic pieces?
The wheel commonly fails in this fashion and is turning at over 12,000 rpm. The set will detect if the wheel is stopped or moving too slow and just what you describe will happen.
Wheel is widely available and You Tube has video instructions for replacing them by model number.
Questions?
Mar 28, 2012 | Akai PT5492S 54" Rear Projection...
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Heard a pop, tv went off, then doesnt come back on
Your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The sound is it starting up, shutting down, over and over.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 23, 2010 | Hitachi 50VF820 Projection TV
Akai PT5499hd that has suddenly lost color alignment
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 23, 2009 | Akai PTH5498 54" Rear Projection...
Tv plays for a few minutes then shuts down. the red light blinks.
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
Feb 14, 2009 | Sony KDF42E2000 42" HDTV
Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
Apr 10, 2008 | Akai PT5598HD 55" Rear Projection...
Akai PT5598HDX/SMS won't turn on
Just a thaught, I could be wrong, maybe a problem with the power button on the remote ? It might shut the TV off, and when you do keep pressing the remote button, the red light on the TV will keep flashing like that also. Ive seen this prob on a few other blogs, so seems to be pretty common. I know I like to keep the remote pointed at the TV all the time, maybe try pointing it away for a while, just to see.
Dec 30, 2007 | Akai PT5598HD 55" Rear Projection...
Televison & Video Logo
297 people viewed this question
Top Televison & Video Experts
