Question about Element Electronics Televison & Video
I had a new sky + HD box fitted to my Elonex TV today. Now neither of my HDMI channels, which were both OK immediately before the new box was fitted, are working, even when we fit the old Sky box back
Now watching on old Sky box through Scart connection. Sky box nor PS4 will operate on HD.
3 Suggested Answers
  • 197 Answers
SOURCE: lh300 sky box works with scart but wont work with
on your tv, have you selected the correct mode on your source button? eg, AV1, AV2 , PC, and HDMI
Posted on Oct 04, 2009
SOURCE: tv flashes when changing channel on sky hd box
Hi I have the same problem I got my TV replaced just today got brand new even better model. and guess the problem is still there.it's not individual,it must be in the whole series. if you have a solution mail at hajjid@yahoo.co.uk
Posted on Nov 12, 2009
Elonex xv-s telvision no remote control cant find sourse to connect playstion without it.sky box is picked up automatically when switched on. it on scart connection
37" Elonex Widescreen HD LCD Television (Black) - Aria ...
www.aria.co.uk/.../Televisions/.../37%22+ELX+Widescreen+HD+LCD+T...
Buy 37" Elonex Widescreen HD LCD Television (Black) - HDMI, 1366x768, 1200:1, 8ms Product Name: 37" LCD TV Model No: LT37V1 Main. ... 49~61KHz; FrontControls: Power, Source, Menu, Channel Up, Channel Down, Volume Up, ... Have you tried it with a HDMI connection as I can't seem to get mine to work with my ...Missing: playstion
[PDF]Operator's Manual - SunBriteTV
https://www.sunbritetv.com/media/pdf/...R/3230HD-Op-Manual.pdf
6) Do not install near any heat sources such as radiators, heat registers, stoves, ....Water-Resistant. Wireless Remote. Control. Model 3230HD. TV Installation .... If youcannot achieve that ... to both your DVD player and Composite's S-Video connector ....Connect an HDMI cable to the HDMI output of your Playstation 3.Missing: elonex
Jan 12, 2016 | Televison & Video
Hi i have a elonex 37 hd lcd tv and have just brought a bluray dvd it is not working on the hdmi lead
I have same problem with Elonex 37". Sadly I think it is because the HDMi specification was amended and newer products (such as your blu-ray ) simply do not connect. My blu ray did until I downloaded newer firmware then nothing. Same with my (new) Freesat HD box - nothing. But an old media player still works over the HDMi. I am checking if there are any solutions but I doubt it. Use the YPbPr connector - your blu ray probably has this and the TV does.
Jan 03, 2011 | Televison & Video
I have skyhd connected to Lght-805sh via optical connection but when i turn sky over from a hd channel to normal channel there is no sound
Not sure what you mean by "optical connection" but you need to connect your SkyHD box to your TV using both HDMI and SCART cables. Your Sky HD box will then send the signal via the HDMI cable for the HD channels and the SCART cable for the SD channels.
Hope this helps
BElectric
Nov 06, 2010 | LG Televison & Video
Ive had sky hd fitted today and cant get sound on tv hd settings but can on normal sd
Hi it is entirely possible that the sky decoder has not been setup to output sound to HDMI. I assume you are using HDMI lead and this lead goes from decoder to TV.
Aug 13, 2010 | Televison & Video
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Got sky installed today only thing getting on screen is "no video signal"
Sounds like the "channel" you are trying to watch on is not the one it's plugged into, or a faulty lead.
check the connection from the sky box to the tv, and select the av or hdmi channel that it is plugged into on the tv.
check the lead by swapping it for a known good one, for example from a dvd or ps3, but unplug from the dvd/ps3 and plug into the sky box(make sure that all the units are powered off when swapping leads) and try on the channel you normally watch/use the dvd/ps3.
If you suspect the sky is at fault, press menu on the sky remote and then flick through all the av/hdmi channels until you find the menu, then try to reinstall/retune the sky box.
If that don't work phone sky......................
Dec 30, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
I have just had a skyhd box fitted and every time i switch my technika tv off and then switch it back on i am getting a blank purple screen .it is as if the tv is not reconising the hdmi input cable .the...
I have the same problem, i just bought a new Samsung 37" and am getting the "Purple Screen" on occasion when i switch from Blu-Ray back to Sky HD. I didnt have this issue with my older Samsung. Upon looking into this i have discovered that it is to do with the HDMI Handshake between the TV and Sky Box. One solution i have read is to buy a HDMI splitter that is HDCP compliant (ALL SHOULD BE IN THIS COUNTRY) what happens then is that Sky does the handshake with the splitter and all is ok. I cant confirm that this works as i have not had chance to try it, but it all adds up and makes sense. Hope this helps
Dec 01, 2009 | Televison & Video
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
I am about to receive an LG32LF4700 Freesat/HD TV If I disconnect the SKY Box and connect the TV direct to the Dish cable will I receive Freesat HD channels. Also can I connect an extra bedroom TV into the...
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Tv flashes when changing channel on sky hd box
Mar 26, 2009 | Hisense LHD3204US 32 in. LCD HDTV
Televison & Video Logo
16 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
