Question about Motorola Talkabout T5500 (7 Channels) 2-Way Radio
Replacement belt clip w/identifying marks large P,small t in a box thats on the spring loaded clip, with the following numerals and letters on the unit IPH4ASC
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 41 Answers
Hi Christopher, I've found A genuine replacement belt clip for $6.95 Ill put the link bellow.
Motorola T5500 T5500R Belt Clip Talkabout T5500R
Posted on Apr 10, 2014
How do I line up the marks for the cam pulley for the Mazda Rustler 1.6 carb to set the correct timming
that little arrow that is cast into the back plate at 12 oclock behind the cam gear should be lined up with a mark between the teeth when the piston is at TDC the crank shaft mark is in line with the keyway in the shaft and will line up with a make ( pointer )in the case behind the bottom gear
to make it easy there should be a small notch in the slinger behind the gear
it is an intereference engine so make sure that the tappet adjustments are let right of so that when turning the cam or crank , the valves will not move and bend on the pistons
the length of the tension spring should be 2.52 " overall length and if not --replace the spring
replace the tension pulley as well
on the long side of the belt opposite the tension pulley apply a load of 22 lbs ( spring balance pulling on the belt) and a deflection of .44-.51" will indicate the correct tension on the belt
Nov 08, 2015 | Mazda Cars & Trucks
How to set the timming on the car i have
Hi - What year is your car please? Thanks.
Jul 19, 2008 | Toyota Corolla Cars & Trucks
Install ram in toshiba pa3171u-1mpc
Hi Kappaman,
This is an easy upgrade to make, check the bottom panel of your machine, you should have some removeable acess panels, usualy held by a number of small crosshead screws, once these screws have been loosened you should be able to remove the panel. The Ram modules are roughly 2 inchs long and slot into slots on the mainboard there will be small clips that hold the ram in place, push these away from the edges of the ram modules and the ram will flip up. this allows for removal. Look for identifying marks to buy replacements/upgrades. Simply push the new items into the slots at an angle (like the previous ram after pulling the clips) and push down to a flat position. You should hear the spring clips click into place. Hope this helps.
Feb 18, 2013 | Computers & Internet
MDL Corp - Manual Timer 301-0004 (Outdoor Lighting)
Timer brand and model are not identified.
Some timers are rated for incandescent light bulbs, while other timers are rated for CFL incandescent and all types of loads.
Open following links to help identify in-wall timer:
http://waterheatertimer.org/Programmable.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
May 28, 2012 | Home
Cam timming on 2.2 l camry
The only marks you need to be concerned with are on the rear of the cam gears, there are two large dimples, these are the assembly marks, not the timing marks, line them up and then rotate the camshafts to the top dead center position, there should be two small dots that line up with the single dot in between.
The reason for the assembly marks is that the one of the cams has a spring loaded gear, you can identify it because it has a two piece gear, before you remove the cam you have to install a short bolt into one of the holes in the gear so that it won't unwind, the reason you need to use the assembly marks is that the service bolt is not accessible with the cams at top dead center so you assemble it with the marks so that you can then remove the bolt and then rotate the cams to the #1 firing position.
Read more: http://wiki.answers.com/Q/Camshaft_timing_mark_96_Camry_2.2l#ixzz1jE0qBgxz
Jan 12, 2012 | Cars & Trucks
The rubber drive belt on my new Akai ATT021A USB Turntable has come off both spindles, and dissappeared under the platter.Can anyone recommend how it can be refitted. PaulR
Remove mat from platter. Using a small screwdriver remove the cir-clip holding the platter on, careful here mind your eyes it may spring away. Carefully lift the platter of, not too much force, you will see the belt laying underneath. Take the belt and put it around the underside of the platter, you will see where it goes, just on the large inside edge. Put the platter back on but not the cir-clip yet. Move the platter around until you can see the motor spindle. Using a small screwdriver and your finger put the belt onto the motor spindle. Make sure it is not twisted. Test the player if the turntable spins OK replace the cir-clip, this can be tricky but get it located first then lift the back up to clear the spindle bearing. There you go.
Jan 26, 2011 | Audio Players & Recorders
Kia sephia timimg belt replacement
remove drive belts and water pump pulley remove plastic cover and crank pulley line marks on cam with marks on valve cover should be at 12 o clock then there is a notch in crank gear that lines up with *** on the block at about 1 o clock the tensioner is spring loaded 14mm nut loosen this nut use a pry bar to push tensioner back snug nut so pulley wont come back remove belt when installing new belt use paper clibs wit the rods that flip over to hold the belt on the pulleys be sure timing marks on cam are lined up before attaching clips as they will move when belt is removed after belt is installed and tensioner is tight turn engine by hand until cam marks are lined up be sure all marks are lined up if they are reassemble everything and happy motoring
Aug 06, 2009 | 1998 Kia Sephia
Replace timing belt on Kia Sportage
heres a trick i use get two office style paper clips instal belt on one cam put on clip to hold belt get lined up with mark then hold it there while you line up other gear install belt and clip now you can put the belt on and know both cam gears are in time
Aug 03, 2009 | 1999 Kia Sportage
Garmin Forerunner 50 Battery Replacement
Thanks MarcS_Ca - I've supplemented what you offer with some photographs at
http://gnjmch.com/public/tips/GarminF50.Battery.html
Aug 30, 2008 | Garmin Forerunner 50
Putting belt on top load amana washer moder #unknown
There is a large pulley directly under the washer drum that runs the transmission. There is a small one connected to the motor shaft, and a third which is attached to a spring-arm and acts as a tensioner.
Pay attention to the direction the tensioner moves. The back of the belt should go against the inside of the tensioner when it is released.
The easiest way I've found to get the belt back on is to thread it around the small pulley, and tensioner, then start it on one side of the large pulley, and rotate the large pulley to allow the belt to thread onto it.
Hope this helps.
Aug 13, 2008 | Amana NAV5805A Top Load Washer
Motorola Talkabout T5500 (7 Channels) 2-Way Radio Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
