Question about Apollo Half Time Convection - Microwave Oven
Oven will not operate when I push start display goes back to clock
Microwave or halftime cooking
How do i set clock
You can get the manual on the link below page 9
http://www.krupsusa.com/NR/rdonlyres/932350FD-628D-4959-879A-AC006C96E9B9/7106/FBC4FBC5.pdf
• When the oven is first plugged in "12:00" appears on the display.
• Press the "Timer" button twice. The display will begin to blink "12:00".
• Adjust the time in steps of one minute by pressing the "+" or "-"
buttons.
• If you hold the button pressed down for more than 6 seconds, the
time will change quicker.
• Press the "Timer" button to enter the time in the system.
If you do not press the "Timer" button, the time will be
entered automatically after 30 seconds.
Feb 20, 2011 | Krups FBC5 1600 Watts Toaster Oven with...
How do you set the clock on the delonghi DO400 toaster oven
  1. Press for 5 seconds the TEMP./SELECT/CLOCK but- ton (7) (the hours flash on the display).
  2. Press the TIME/TOAST COLOR buttons (8) to the desired time (hours). The time set will begin blinking on the display.
  3. Press the TEMP./SELECT/CLOCK but- ton (7) (the minutes flash on the display).
  4. Press the TIME/TOAST COLOR buttons (8) to the desired time (minutes). The time set will begin blinking on the display.
  5. Press the TEMP./SELECT/CLOCK but- ton (7) to confirm. It is pos- sible to press the button at any time during cooking to display the current time (the display shows the time set).
  • If you wish to change the hour on the display once it has been set, press the TEMP./SELECT/CLOCK but- ton (7) before proceeding to set the new time as described above.
  • It is possible to display the current time even after starting a function, by pressing the TEMP./SELECT/CLOCK button (7) (the time is displayed for 2 seconds).
Oct 14, 2010 | DeLonghi DO400 Toaster Oven with...
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    Setting clock on krups toaster oven
    buttons.
    May 28, 2010 | Krups FBC5 1600 Watts Toaster Oven with...
    Microwave goes on but does not heat
    • Magnetron is fried. Resistance between the magnetron terminals should be less than 3 ohms. Resistance from the magnetron terminal to ground should be infinite.
    • Fried HV capacitor. Use your ohm meter to test it.
    • Fried control board. If power is going to the board but not going off to the other components, the board is bad and needs to either be replaced or track down the bad connection (GE/Hotpoints).
    • HV Rectifier is shorted or open. Test forward and reverse bias with a megohmmeter. If continuity in both directions, rectifier is shorted, replace. If no continuity in either direction, rectifier is open, replace.
    • More help on testing specific components inside your microwave oven in this handy chart.
    Aug 14, 2009 | Oster 4877 / 4878 / 6209 Toaster Oven with...
    Does not heat up.
    Mine worked for awhile, then started overheating. I (former appliance repairman) found that the fan needed oiled. While I was checking it with the outside covers removed, I saw that two of the connections on the top heating element were arcing and burning! This accounted for a strange smell.
    Jul 06, 2009 | Toastmaster TUV48 UltraVection 1400 Watts...
    Labels on black and decker toaster oven worn off CT0650C
    Top dial is Bake/Broil knob, it goes left to right. Starts with OFF @ 9 0-clock next is 100 dgre then @12 o-clock 180 Deg. is at top center next is 250 Deg. next 350 located opposite of off. Next @ 4 o-clock is 400 Deg. Next @ 5 o-clock is 450 Deg. and finally at the bottom at the 6 o-clock position is BROIL. The Center Knob is BAKE TIMER . Starts @ off position as 0, next @ 10 o-clock is 10-mins. Next @ 12 o-clock position is 20 mins. Next @ 2 o-clock pos. is 30 mins. Next @ 3 o-clock pos. is 40 mins. Next @ 5 o-clock pos. is 50 mins. Next and finial pos. is 60 mins. The Bottom knob is TOAST @ the 9 o-clock is is 0 next @ 11 o-clock pos. is Light , Next between the 12 & 1 o-clock pos. is MEDIUM and the final pos. @ 3 o-clock is DARK. TOAST.
    Jun 13, 2009 | Black & Decker CTO650 1500 Watts Toaster...
    Toaster oven
    THERE IS A SAFETY MECHANISM ATTACHED TO THE DOOR THAT TURNS OFF THE OVEN WHEN YOU OPEN THE DOOR. INSIDE, BEHIND THE KNOBS THERE IS A SPRING THAT ATTACHES TO A WIRE THAT IS CONNECTED TO THE DOOR. WHEN THE DOOR OPENS THE WIRE RELEASES THE SAFETY MECHANISM AND THE OVEN SHUTS OFF. WHEN CLOSED THE WIRE PUSHES AGAINST THE MECHANISM AND THE OVEN WORKS. I WAS ABLE TO FIGURE OUT HOW TO RECONNECT THIS FEATURE SO THAT THE OVEN WOULD WORK.
    Feb 24, 2008 | Black & Decker TRO210 Toaster Oven with...
    "Err"or message with beeping
    Same message here. Did anyone buy it a costco? I'm hoping they'll take it back. Andrew Victoria BC
    Oct 14, 2007 | Oster 6239 Toaster Oven with Convection...
    Oster microwave/grill
    ha, had the same problem, just call the oster custumer service and they can send you a new one for $5
    1-800-968-9853
    Oct 06, 2007 | Oster 4877 / 4878 / 6209 Toaster Oven with...
    Apollo Half Time Convection - Microwave Oven Logo
    Top Apollo Toaster Ovens Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Are you an Apollo Toaster Oven Expert? Answer questions, earn points and help others
