Need a new outlet.
Go from garage to inside family room for for a new plug outlet. There is an outlet in the garage for easy outlet fix.
  • Larry Symms Mar 28, 2014
    AC power outlet? most building codes require a firewall so breaching that without following building code will be in violation.
  • 6 Answers
SOURCE: Frigidaire side-by-side refrigerator keeps tripping GFI outlet.
We had same problem with different fridge. Is the fridge cooling things? When ours did that we needed to replace the relay overload start capacitor it's called a three in one. It acts like a giant battery to give your compressor a n extra boost to get started runs about 25 bucks relatively easy fix only has three wires to connect
Posted on Jan 24, 2009
  • 55 Answers
SOURCE: I bought a GE Portable Room Air Conditioner (Model: APE08AK)
Sounds like u have a defective unit
Posted on Aug 05, 2009
  • 52 Answers
SOURCE: My easy flo built in system wont turn on when the
If there is a switch on your hose, it may be broken.
Your system powers on from the inlets via two low voltage wires that run from the inlets to the switch/relay at the power unit. Each inlet has 2 spring loaded pins attached to the low voltage wires. In the photo below you should see these pins at the bottom of the opening, just above the door hinge. The receptacle at the top of the inlet in this photo supplies 110 volts to power your power nozzle. Not all inlets have this option, but if yours does, exercise extreme caution. Your hose must have a completely metal end or if it is a plastic end, it must have a metal band in order to short the 2 low voltage wires together to trigger the switch.
You can manually short the two low voltage pins together by using a metal pipe or needle nose pliers, just touch both pins at the same time. CAUTION: stay away from the 110 volt receptacle if present.
If your system powers on with this manual method then it would seem that the problem is in your hose.
If your system does not power on; your low voltage wires may be disconnected from the power unit or disconnected somewhere else . It's also possible that you have a bad circuit/controller board in the power unit.
Posted on May 22, 2010
  • 52 Answers
SOURCE: Miele Red Star, small spark at outlet, no power to vacuum
The vacuum has a standard tube internal fuse. If you are lucky that is all it is. See the site http://www.sannerud.com/house/miele.html for instructions on how to open it up.
hope that helps
Posted on Aug 11, 2010
SOURCE: How do I fix the electrical outlets in our family room? The room has 5 outlets, one of which works. The other four have no electricity. I replaced one outlet but that did not correct the problem
Check for any tripped breakers. Make sure a wall switch is not controlling any of them or that they are not on a GFCI circuit. If all OK, turn power off to outlet that works. Remove the covers from each outlet, and pull the outlets out of each box as far as you can, but leave the wires attached to the plug, making sure none of the wires contact any part of the box if its metal. Look at the wires attached at each outlet if they are not attached to the side screw terminals, but rather pushed into the back instead, note the way each is attached, then either cut them off as close to the plug as you can or pull them out of the back. Now reattach them in the correct place but put them on the screw terminals instead. Make sure all wires are secure. Turn on the power and carefully test each outlet for power. If they all work, turn off power, replace everything and your good. If still no power at any of them determine which outlet(s) have only one cable entering the box. The boxes with one cable will either be on its own circuit, or the last one in the run. The boxes with 2 at least 2 cables will be the middle of the run and one of those will be the one with the power supply for all of the others. If you don't have a signal tracer try locating tracing the wires from the 2 wired boxes in the basement, one of those wires is the feed and could be disconnected at a junction box or at the service panel.
Posted on Mar 21, 2015
How to wire in an on-off switch for ceiling light from power source going to living room.
Pretty easy if you can get the wires from the existing wall outlet. Just run a wire from existing outlet to the where you want the new light. Install inside an approved ceiling electrical outlet box and then run another wire to where you want the switch or switches. If you go to home depot or the library you can look at the books with diagrams on how to wire it. You can skip the wall switch if you use a light with a pull chain.
Sep 20, 2014 | Electric Electrical Supplies
Problems with a GFCI outlet (no voltage). GFCI outlet was replaced and reset recently but that didn't fix the problem. One other GFCI breaker in the same room is working OK. Also, water is entering...
if your room is powered by one breaker you need only one gfci and it has to be hooked up correctly to protect the other outlets a new gfci will have a tape tag over the out side usually the top set of nuts the water in the panel is a major fire hazard i would fix this problem first your feed to the gfci may have shorted out in the wall between the breaker and the gfci if it is wired separate from the other gfci in that room one thing you can do to save calling an electrician is go to lows home depot or any electrical store and purchase a plug in tester they are inexpensive and easy to use it will tell you if wires are hooked up correctly backwards or if you have a short somewhere in the line this is the same little gadget that an electrical inspector uses to make sure new homes are wired correctly an outlet will still work even if some wires are incorrect in the circuit the outlet tester confirms all is good and safe
Jan 23, 2011 | GE Hammering
I have Craftsman 139.53753 (sears) garage door opener, I replaced the battery...it's new. Garage door will not open from outside or inside UNLESS I bring the transmitter (clicker) right next to the...
Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
The first step is replacing the battery in your remote. If the range on your remote does not improve, remove the wall control wires from the overhead unit. If the range does not improve you will likely need to replace the remote control.
To isolate potential sources of interference, turn the circuit breaker off to the garage and plug the garage door opener into an extension cord from another room. If the range improves, then the interference is coming from a device in the garage. If no improvement is seen follow the same procedure, this time turning off the circuit breakers to your home, with the exception of the garage and test the remote controls. If improvement is noted, turn the circuit breakers back on, one by one, until the range problem resurfaces. This will allow you to narrow down what room the problem device is in. You will have to go from there to isolate it further, by unplugging and re-plugging the items in that room.
If you are unable to determine any source of interference, then the receiver logic board in the overhead unit will need to be replaced.
Dec 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
My laptop screen is dark. I plug the laptop in a power strip in the family room and the screen works fine. I put it back in the other room, plug it into the power strip and the screen does not come on. The...
You have created a power drop with too much load on that circuit or you have a bad receptacle. Try plugging it in directly to the wall outlet in the other room. Let me know if this is helpful, we can go further if necessary.
Nov 08, 2010 | Computers & Internet
hope that helps
Jun 05, 2010 | Miele Red Star Bagged Canister Vacuum
Lifestrider 3325 will not turn on.
Keep unit unplug check your outlet if power is good then plug unit in make sure your safety is engaged if that does not work, open motor shroud and under that shroud their should be a paper with a wiring diagram and with a Ohm meter check where you have a open circuit.
May 05, 2010 | Exercise & Fitness
Kenmore Refridgerator freezer pops GFCI outlets
most gfci are 15 amp draws
its quite possible your refer needs 19 or more to start
i would reccommend getting the unit of gfci plug
Oct 12, 2009 | Refrigerators
GFI outlet is tripping because of refrigerator in the garage.
Hi: Yes, replace the GFI outlet. A refrigerator should not be plugged into one for what you are experiencing and food loss. This was an easy answer for me, but unfortunately not for you The owners manual covers this, but us men don't read them (Well I had to as I worked with them for 30 years). Good luck, Jeff
Jun 01, 2009 | Whirlpool ES5FHAXS Side by Side...
Jan 24, 2009 | Refrigerators
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
