Fostex e16 rewind autostop not working
Spool brake doesn't come on at the tape end in ff or rw
    Scholar:
  • 63 Answers
Either the autostop sensor is gummed (Sometimes easy to fix, sometimes needs to be replaced) or the IC tape controller is not listening to the sensor. In either case, you'll need to be very comfortable with working on tiny connections with a rock-steady soldering hand. Those are the two locations that you will want to check, and hope that it's just a gummed sensor and not a bad IC.
Posted on Mar 28, 2014
5 Suggested Answers
night71
  • 328 Answers
SOURCE: vcr eating and/or ejects tape
Tape heads should be cleaned first and gears lubricated. This job can be done at home if you purchase lithium grease and are very careful not to get it on the heads or spools. Greasing should only be done if you are confident in opening it up. Otherwise, seek a cheap professional.
Posted on Oct 26, 2007
57 varieties
  • 1653 Answers
SOURCE: when I put a tape in, it loads, then stops.
It sounds like the machine needs a thoro cleaning especially around the guide pins and tape head. Also make sure that the tape is not being excessively tensioned in the cassette housing. If it happens on more than 1 tape then thoro cleaning of the transport mechanism in the machine is required. You may need to run a cleaning cycle more than once or get it to a repair shop to do it for you. If it happens on all tapes then it is possible that one of the guides has become worn or bent, or the drive mechanism is at fault or the drive belt has become stretched and will need replacing.
Posted on Jul 15, 2010
Testimonial: "Thank you so much! "
Demonic-2011
  • 467 Answers
SOURCE: after watching a pre programe tape ...while rewind
I love these kinds of problems. Whenever a VCR eats tapes, it sounds like a combination of one or more things including;
mode switch;
worn/glazed/shiny pinch roller;
poor back tension on the reel tables;
stretched belts (if more than one belt is present in your machine).
Unless you have some technical knowledge of basic VCRs, I do not recommend that you undertake replacing any of the mechanical components yourself, as alignment/timing is involved. The replacement of those parts relating to the deck (if required) should be done by a professional service centre. They would have the necessary tools and facilities to do this.
I suggest that you take the unit to a workshop where they can examine it thoroughly - but get a quote first if you have any doubts about the likely cost(s). That way, you can decide afterwards if it is economical to repair the VCR or not. Up to you.
It could be something really simple, you should not need to replace the whole combo. Fingers crossed.
Posted on Mar 08, 2011
SD Tech
  • 14553 Answers
SOURCE: The DVD works fine but the VCR doesn't play, rewind or forward tape.
l would have a look inside to see if when a tape is inserted it loads and will ff and rew, if the transport that moves the tape has failed it will account for what is happening.
Posted on Aug 28, 2012
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
FF problem on Teac Reel to Reel
You need new brake pads installed as the ones in there now are dried up and may have fallen off. This is very common with older decks or 30-40 years old.
I am still working on these decks at Skywave Tape Deck Repair in the Chicago area.
Jul 15, 2013 | Teac Audio Players & Recorders
Aug 27, 2012 | Zenith XBV442 DVD Player/VCR
JVC VRC MACHINE HR-S7965 Rewind/fastforward cog slip noise
maybe a broken break band on reel supply (left one) in the vcr !!!
Apr 22, 2010 | JVC HR-J461MS VHS VCR
My EWC1394 records programs, but when I rewind th tape, it shuts off. This happens several times before it starts to rewind the tape.
this is caused by the tape winding too tightly so when it rewinds it gets tension and thinks it is at the end of tape ,so stops.
It pays to FF and REW several times on new or other peoples tapes to have the tape acclimatised to the tension on your machine. It may also need to be serviced if it is doing it to tapes you have previously FF to the end and rewound. Older tapes stretch a little more than new tapes so are more forgiving.
{Plese rate our help ++++Thanks for using FIXYA
Sep 26, 2009 | Emerson EWC1304 13 in. TV/VCR Combo
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
Camcorder has problems
I've had mine for about 3 years and just last year it started giving me playback problems....the screen would have blue stripes across it and sound won't play. I could usually fix it by rewinding and playing again...but it's not correcting itself right now... I hope I didn't waste 60000 yen on this c_c;
Oct 07, 2007 | Video Cameras
VR8707 VCR. No Rewind or Fast Forward
I thing that you are having problems with your gear assembly on the carriage. FF and RW use a series of gears to move the tape from one reel to the other. If possible could you take some pictures of the gear assembly. More then likely the gears are not making contact or the drive belt has slipped. Granted this is just conjecture until I can see those pictures of the assembly. electronagetec@aim.com
Sep 10, 2007 | Samsung VR8707 VHS VCR
Eats tapes
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through. The pincher wheel & capstan are not used during a fast forward or fast rewind, so if your tape is getting caught during the FF or RW and not Play, it's probably not related to capstan & pincher wheel.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
3. You didn't say if the unit played ok. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
So when when you hit eject, the excess tape that should have been wound up tight in the cassette before the eject sequence, is getting caught inside the player.
Let me know if I can be of further assistance to you.
- Jim
Feb 20, 2007 | Symphonic WF803 DVD Player/VCR
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
