Question about Cnet (CSH-1600) (CSH1600)
How to reset the switch CNET CSH-1600
The light is blinking but all of the other are off, and don't work. the problem start after a electrict problem. any body know how to reset the switch CNET CSH-1600?
  • Cnet Master
  • 3,320 Answers
No manual. Maybe a pinhole reset switch?
Posted on Mar 29, 2014
5 Suggested Answers
AbhiRay
  • 124 Answers
SOURCE: How to use the small switches at the back of CNet
Hi
If you are running the Cnet CNHS-1600 power switch in default mode ( No Vlans created) then you do not need to configure anything. Connect any Cat5 or CAT6 LAN cable from any free port to the new small switch. The Cnet CNHS-1600 power switch is Auto MDI/Auto MDI-X enabled so no need to worry about the cross cable. Simply plugging in a cable between Cnet CNHS-1600 power switch and the new switch will extend your LAN.
Posted on Nov 01, 2010
AvioriX
  • 689 Answers
SOURCE: Switch CNET CSH-2402G PASSWORD RECOVERY
it should be 4 digit 1234 if still doesn't work you may try reset
Good Luck
Posted on Jul 27, 2009
Geekman
  • 32281 Answers
SOURCE: Cnet CSH-800 8-Port Ethernet Switch
Check the power adapter with a multi-meter. The voltage on the plug that connects into the Ethernet switch, the voltage reading should be slightly higher than the voltage that is printed on the label on the bottom of the adapter.
If the voltage is zero or very low then the adapter is faulty and needs to be replaced.
If the voltage of the adapter is OK then the Ethernet switch is faulty and you need to buy a new one.
Posted on Dec 11, 2009
SOURCE: pleased i need to download
Don't know about a special program, but you can try to use Centrastage (www.centrastage.com)
It's a remote management software and it seems like it can be useful for you.
Posted on May 24, 2012
How do i configure the CNET 16ports switch to allow or not web access through?
Unless I'm missing something, you can't. This is a basic switch with no advanced application aware features.
May 02, 2015 | Cnet CSH-1600E 16-port 10/100Mbps Fast...
Pleased i need to download the remote management software (rmt) for cnet csh 2400 switch. where can i do this
Jun 29, 2011 | Cnet CSH-2400 (csh2400) 24x10/100 Mbps...
CSH-800 8-Port Ethernet Switch Problem When i switch the power on, only the POWER LED light up and nothing is happened, computers cant detect it
Switches arnt not detectable by the computer, a switch allows you to link multiple pcs togethers that sit on the same domain/workgroup , and also network subnet, the other lights will come one when you connect a RJ45 cable between the unit and a PC to show a port is in use.
May 10, 2011 | Cnet CSH-800 8-Port Ethernet Switch
How to use the small switches at the back of CNet CNHS-1600 Power switch
Hi
Oct 29, 2010 | Cnet CNSH-1600
Which type of cat-5 cable do i use to connect a cnet switch to a d-link switch
interConnecting two switches will need a crossover cable. Please use a crossover cable.
Oct 27, 2010 | Cnet CSH-800 8-Port Ethernet Switch
Cnet CSH-800 8-Port Ethernet Switch no power
Dec 11, 2009 | Cnet CSH-800 8-Port Ethernet Switch
Good Luck
Jun 16, 2009 | Cnet CSH-2402G
Don't have internet connection
This particular 8-port Ethernet switch/hub has auto-negotiation on both speed as well as MDI, MDI-X.  Therefore, the problem is not with your switch/hub, it's probably with the particular port that you're connecting it to on your Router.  Make sure that it's the LAN side, not the WAN side.
Mar 14, 2009 | Cnet CSH-800 8-Port Ethernet Switch
CNET CSH 2400 24 PORT SWITCH - LINKING TWO UNITS
You might be having problem in following area 1. Check the cable first. You can use the cabe tester. If cale tester is not available then chek the cable with multimeter. 2. Check the port wher you have inserted the patch cord. It should be in uplink port of first hub and normal port of second hub. Try this and revert back with results.
Feb 08, 2007 | Cnet CSH-2400 24-Port Ethernet Switch
Cnet (CSH-1600) (CSH1600) Logo
403 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
Marcin
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
