Question about Karcher 2500 PSI Pressure Washer
I have a craftsman pressure washer. it sat for a year but it did start and it ran fine. then my sister borrowed it and it started but while it was running she tipped it to move it to another location and it just stopped. i've checked all fluid levels, gas, etc. and are ok . i can't start it. is there a safety breaker/fuse that automatically shuts it down and has to be reset?
3 Suggested Answers
jmgldsmth
  • 2005 Answers
SOURCE: new Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Posted on Aug 31, 2009
19ken55
  • 426 Answers
SOURCE: My pressure washer sat for
I hate to tell you but the carb will need cleaning. Try draining the bowl to get the old gas out.
Good Luck it is not that hard to do.
Posted on Feb 12, 2011
Motor fires up fine runs slightly rough for about 10 seconds then smooths out for about 5 seconds and cuts off. Will start right back up after about 5 seconds and does the same thing. I have drained the...
Previous owner had way overfilled crankcase oil. Oil had gotten into carb and clogged air filter. Drained oil to correct level. Ran engine but kept cutting off-see above. Took off carb cover cleaned housing and ran without air filter-ran fine. Unsuccessfully tried to clean air filter with gas-did not work. Apparently, the engine could run just long enough to exhaust the air in the old filter and cut off which is why it would start back up after a few seconds. Bought new air filter-whole thing-about $15 at Carquest. Put in some carb cleaner and installed the new filter and it runs perfectly.
Jun 10, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Have 93 Lumina sat for a year now won't start and seems to have no fuel pressure. new battery turns over fine but doesn't seem to want to fire either. Ran great when i parked it. WTH??
older cars need to be run alternators sieze up fuel pump gets gummed up .the gas is probably bad so this will make it have no pressure
Oct 05, 2013 | 1999 Chevrolet Lumina
I cant start my power washer. the pull start is locked and wont release to start engine.
When the pull start gets locked, you have to release water pressure from the wand. I had the same problem last year.
Jun 16, 2013 | Craftsman 2700 PSI Briggs Stratton...
Sears pressure washer
sounds like the engine is over heating have you checked the oil?remove the top cover from the engine and look for a mouse nest
Jul 27, 2012 | Craftsman 3000 PSI 28 GPM Honda Powered...
1989 Bronco fullsize has sat for the past 6 years and wont start, will turn over, has new gas with fuel stabilizer, still no firing. Replacing spark plugs and the fuel pump are the next two steps. ...
Assuming she ran good before she sat, replacing the plugs, cap and rotor isn't a bad idea.Step 1: Make sure you have good spark. No need to worry about timing right now. Step 2: If you have spark, then we have to see if its getting gas. There are two fuel pumps on this Bronco. One in tank and one on the frame rail. Can you hear either one running? The in tank one should come on for a few minutes and shut off. The front one is harder to hear.If you hear it, borrow or rent a FUEL PRESSURE GAUGE and check your fuel pressure. There is a fitting similar to a tire valve on fuel rail. Pressure should remain constant.If either pump fails you will not get adequate fuel flow. The front pump is easy to get to for trouble-shooting. Don't buy anything unless your sure you will need it. Hope this helps.
Feb 07, 2011 | 1989 Ford Bronco II
My Honda 2600 psi power washer will not pull to start. It was running great then I allowed the neighbor to borrow it. He ran the washer till it was out of gas and proceeded to refuel and at this point it...
You should be fine to take the recoil off, there shouldn't be anything that shoots out at you. You might want to check the oil level on the engine, many of the Honda engines won't start unless there is enough oil in them. If your oil level is fine, check to make sure that your motor is getting spark.
Oct 04, 2010 | Honda Pressure Washer PSI 3000
Honda gas power pressure washer runs for awhile then cuts off.
did you pour all of the old gas out before you started to use it. Sometimes condensation builds up in gas tank when stored. You need to dump old gas an put in new gas.
Jul 27, 2009 | Honda Karcher G4000RH Pressure Washer
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
Pressure washer - no water flow
Is there a check valve on the hose inlet that is stuck, and won't let the water in???????
May 25, 2009 | Plumbing
Karcher 2500 PSI Pressure Washer Logo
183 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
