Question about Bosch "1677M 1677M, 7-1/4"" Worm Drive Construction Saw With Rear Handle"
How to change oil
Saw is getting hot
  • Bosch Master
  • 1,774 Answers
The is no oil insite to change only grease a special bosch lubrication or and the ballbearings insite have grease but you can also lubricate the transmission with Paragon Renolith from Dewalt easier to find in you country , simple ball bearing grease can also, but when its getting hot look at your electric field and also the armature if that color is correct nice brass colored thread windings instead of brown black colored and the commutator (collectors) on the armature is nice the place where the carbon brushes are on the armature are nice colored .because the tool can be on its end .if its noisy and if its worth to repair be aware before repair. how old is the tool or have it second hand bought its maybe a problem.
Posted on Dec 29, 2015
My Husqvarna 351 starts then stops after 1-2 seconds
Once the saw cools down will it restart and run fine? There are a couple other solutions that are not directly due to carburation. The first two solutions above are definitely your first options.
1. Ignition Coil: Highly unlikely, but possible. I seen some where they get hot and run fine while cutting, you shut it down for a few minutes for whatever reason and it won't restart or starts and stalls.
2. Crankcase Air Leak: We started to see more and more of these issues. There are a couple of quick ways to test this if you do not want to pay a shop to do an actual test. You want to do a cold test and a hot test. With a half tank of fuel, start the saw up for the first time of the day. While the saw is idling, turn the saw sideways from right to left, do this slowly, listen to the saw idle, if the speed changes by increasing or almost stalling, you have a crankcase air leak. Most bad air leaks won't be noticeable until the saw has gotten hot and the aluminum crankcase starts to expand a bit. Do the same thing once the saw has gotten hot. If this happens when it's hot, chances are that it won't start or starts and stalls until it cools down and everything retracts.
Test Results:
Sporadic idling when cold: Most likely just the oil seals, fairly inexpensive repair.
Sporadic idling when hot: Most likely crankcase itself is leaking, requires a complete crankcase gasket replacement. Can be fairly expensive to repair.
Apr 13, 2014 | Garden
Leaking bar oil when hot
As the oil gets hotter it becomes more viscous, so if there is a leak it will get worse, remove the bar and chain, drain the oil from the oil tank and re fill with fuel, this will leak out very quickly and should show you where it is coming from, you can then address the problem.
May 05, 2012 | Husqvarna Garden
I have a Homelite UT 10520. It is a refurbished chainsaw. It has ru about 30min. It is running hot. My mixtture is 50:1 and my gas is 90 oct. I think it is running lean. It will not get to the max...
lI thinkthe oil to gas is too rich with Gasoline. My book says 40 to 1. Not enough oil will cause it to run hot and burn or stick. Also some of the later models take the synthetic oil andif you use the outboard or other oil it will run hot and ruin the saw.
Jul 07, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
Chain saw ran for a few minutes became hot with little smoke and now will not start again.
It could get hot and not start if the saw was quite dirty because it relies on air for cooling and if the fins can't get enough air around them it would heat up and not start. Another thing is if some one did not use the correct gas oil mixture it would get hot and score the cylinder lowering the compression causing it to not start.
Mar 17, 2011 | Homelite ZR10580 FactoryReconditioned 42cc...
The saw is a 385xp. We have changed bars and chains numerous times. When sawing the bar gets hot enough to fry an egg and the chain stretches out. Onlynable to saw a minute or teo at the time. bar gets...
Overheating the chain/bar is usually caused by insufficient oil getting to the chain, but can be caused by the chain being too tight to begin with (you should be able to turn the chain by hand), grit in the chain groove, or a poorly sharpened chain. The saw has an oil volume adjustment screw on the lower part of the case near the chain return area. Turning it CCW should increase oil flow. Oil volume can be judged by running the saw tip at speed near some cardboard for a moment--it should throw off a thin line of oil. Chain sharpening condition can be judged by the sawdust residue coming from the cut--if a powder-like material, the teeth are not sharp or are improperly filed. You should not have to bear down excessively on the saw to make it cut quickly. Hope some of this helps!
Jan 09, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have only used my saw a handful of times and it has always done this since i bought it new at lowes. It wont lube the chain with oil and gets vry hot at the clutch it will go through a tank of gas to a...
I have the exact same saw. I bought it new 6 months ago also from lowes. It has the exact Same problems you are describing. It does not appear to be oiling the chain enough, the Chain is visibly dry,very hot , and dulls quickly. It uses a half tank of oil to a tank of gas. I am Also in search of an answer.
Oct 20, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Can't seem to get my oiler to work properly. oil emerges when i run the saw with the bar removed, but chain is dry and hot when run put together.
Some saw manufactures design their oilers to only work with their bars. Are you running the mfg suggested or stock bar? Chain? Stihl Chain is designed to use 30% less oil because of oil groves cut into each drive link directed to the rivets. So if your running an aftermarket bar/chain, the oiling ports may not line up. Especially if it oils with no bar & chain
Oct 09, 2010 | Husqvarna Chain Saw 20" Bar
I have a husqvarna 257 with a 20inch bar and having oiling problems, is getting hardly any to no oil and have the oil adjuster screw the whole ways out, is the oil plunger bad?
If you take the bar off, and then run the saw, does oil come out of the saw? If it does, then the oil pump is likely working O.K.
If the oil comes out of the saw and does not make it onto the chain, it is possible that the oil exit slot on the saw, and the hole on the bar are not lining up properly. This happened on my Husqvarna 141 saw. The oil was coming out of the saw fine, but it never made it to the bar and chain. As a consequence the chain was always dry and very, very hot.
The other saws we use, always have plenty of oil on the chain. I think Husqvarna may have made a design flaw on some of their saws, and the exit point of the saw and the entry to the bar are not properly aligned. I wonder how many saws this affects.
Sep 14, 2010 | Husqvarna Chain Saw 20" Bar
My saw runs a few minutes then gets hot and wont start
What is the ratio of the oil/gas mix?
Sounds like it is not getting sufficient lubrication.
Add 1/2 oz (about 1/2 shot glass) of 2-cycle oil to the gas tank and try again......
Check to be sure that you have LOTS of chain oil in the chain oil tank!!
\Keep us informed, please! -Jim
Oct 22, 2009 | Homelite ZR10926 16 Chain Saw
Bar sprocket smokes, gets hot spot
Sounds like you're not getting enough oil to the chain. Basically you've got an oil pump, pickup and filter involved in getting oil from the resovior to the chain/bar. If you cleaned the obvious area and the chain is not coated with oil, you may have a clog further up (inside) the oil delivery mechanisms. Also, drain the oil from the tank, and see if you can "blow" air through there. With the saw running & pointed down, you should be able to see oil on the ground being slung off the chain, if not, you are not getting enough oil to the chain.
Nov 29, 2008 | Poulan Pro Chain Saw 46cc 20"
Bosch "1677M 1677M, 7-1/4"" Worm Drive Construction Saw With Rear Handle" Logo
218 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
River bottom
Are you a Bosch Saw Expert? Answer questions, earn points and help others
