Question about LG LHD45EL Dehumidifier
No water collects in our LG LHD45ELY7 dehumidifier. Bucket is properly installed. I take off back plastic cover and notice the copper line out of pump compressor is only v. slightly cool (other line gets warm). Assume it is out of or low on Freon. Can it be recharged? Or, do I just throw it out an buy another brand. Disappointing as it is less than 1 year old. Thanks.
    Top Expert:
  • LG Master
  • 12,962 Answers
It can be recharged but you would first have to locate and fix the leak and then refill. Then add a schraeder valve and refill at the port till suction line is cold to touch and starts to sweat. That's it!
Posted on Sep 09, 2017
  • 883 Answers
SOURCE: No water collection
compressor may be starved for freon or blockage in freon line...tech must troubleshoot.
Posted on Jun 08, 2007
SOURCE: water bucket
If yours has a button/switch to turn on a pump, that will redirect the water to the drain. Sllee
Posted on Aug 01, 2008
66 chrgr
  • 1011 Answers
SOURCE: Kenmore dehumidifier runs good but does not collect water.
most likely the compressor is not producing pressures that are needed probably not low on freon .
Posted on May 31, 2009
  • 16 Answers
SOURCE: ice forms on the coils of a white westinghouse dehumidifier
if the filter is clean than it most likely is low on freon with the right tools you could add freon
Posted on Jul 07, 2009
  • 51 Answers
SOURCE: Kenmore 54501 Dehumidifier no water in bucket
may have lost ref charge check name plate for type of ref with 12 and 22 cost of gas cost proh. check tubing in rear should be ice cold to gather condensate if not probably lost gas
Posted on Aug 09, 2009
Overflow on floor
The problem you're having can be caused by a couple things.
1. The float valve in the top of the water collection bucket is broken or is stuck in the Down position.
Remove the bucket, and inspect the float valve for damage or sticking. If it's stuck in the DOWN
position, jiggle the arm of the float valve, to make it works freely.
2. The water collection bucket is not installed properly and water is leaking out the back of the
top of the bucket. When installing the bucket, be sure it's installed "squarely" into the bucket
holder from top to bottom and making firm contact with the bucket safety removal switch on the
rear wall of the bucket holder.
I hope this helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Sep 15, 2011 | LG DH30 GoldStar Dehumidifier
The De-humidifier thinks the bucket is full constantly
This occurs when either the float valve in the top of the water collection bucket is stuck in the UP position or the bucket was not installed properly, making contact with the bucket safety removal switch on the rear wall of the bucket holder.
Checking an correcting those 2 issue should solve the problem. Be sure to turn the unit OFF & unplug it before attempting corrective issues.
Hope this helps you & thanks for choosing FixYa.
Sep 09, 2011 | LG LHD65EBL Dehumidifier
My LG LHD45EL Dehumidifier can't collect water in bucket, which part is failure and how to repair it?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 08, 2011 | LG LHD45EL Dehumidifier
Starts then stops completely showing this type of line - - - - where humidity should be. Cannot turn on or off.
The ---- lines you see, indicates that water collection bucket is not installed properly, as well as the air intake filter may need to be removed and cleaned.
When installing the bucket, be sure that it fit's "squarely" into the holder from top to bottom, so that it makes good contact with the bucket safety removal switch. When installed properly the bottom of the bucket will not tilt down at all.
To clean the filter. turn the unit OFF & unplug it. Remove the bucket and then pull the filter straight down and out. The filter can be vacuumed or if it's really dirty, wash with warm water and mild dish washing detergent. Rinse thoroughly, shake off any excess water and thoroughly dry, before reinstalling. Never operate the unit without the filter in place.
Hope this helps you and thanks for choosing FixYa.
Sep 06, 2011 | LG LHD45EL Dehumidifier
Dehumidifer will not run, it has power and bucket in propery installed
heatman101
Does not shut off and overflows
In most cases this problem is caused by the water collection bucket not being installed properly. It may not have been pushed in far enough to allow the full switch to activate when needed. Be sure that each time you remove the bucket to empty it and then reinstall it, that the lift handle of the bucket is all the way in down position and that the bucket is fitting squarely into the holder from top to bottom.
Note: Your specific model has been discontinued by LG. However, some parts are still available if needed.
If you run your dehumidifier constantly and don't want to make a repair to it. You may want to consider using a drain hose, rather than the water collection bucket. This would require a floor drain close to the unit, though.
Hope this helped you to troubleshoot and solve the problem.
Jun 16, 2011 | LG LHD45EL Dehumidifier
Does not collect water (also 2 years old).
the evaporater coils rot out and the freon leaks out. thats about all the longer these newer ones last now.
Jul 09, 2009 | LG LHD45EL Dehumidifier
LG45EL dehumidifier no longer collects water.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 01, 2009 | LG DH404E Dehumidifier
Dehumidifier runs without collecting water
1- check if the water collecting bucket is properly installed (the light will show is ON but if the bucket is not propely installed -pushed in the proper position ) -make sure the slots on the bottom of the dehumidifier are posisioned correctly.
Sep 13, 2008 | LG LHD45EL Dehumidifier
LG Dehumidfier
When you install the drain tube, be sure that it is placed into the drain hole in the dehumidifier. You then will be able to "latch" the tube at the hose end by lowering onto the outer hole opening. This maintains a tight connection and the water will drain properly.
Jun 17, 2008 | LG LD65EL Dehumidifier
LG LHD45EL Dehumidifier Logo
591 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
