Question about Saws
D27105 motor wont run turns a few time 0.1 sec. then shakes and stop, have disassembled it also dose this without the belt,
    Champion:
  • 304 Answers
Sounds like a bearing has gone on the armature.
Posted on May 03, 2014
I have a 14 yr old AEG 3200 dryer. The drum has stopped turning.Could this just need a simple belt replacement or wld you recommed a new dryer. Thanks
If you can hear the motor run when activated replace the belt. You should check or have checked the rollers that the drum is supported by. Check the belt tension-er replace if worn. While the unit is disassembled the rollers are easy to replace.
Vacuum all loose lint out from around the motor while disassembled.
These simple older machines are reliable and very durable and only have a few moving parts.
Hope this helps?
AEG LAVATHERM 60750225500 Tumble Dryer Section Spare Parts Diagram
Jun 21, 2017 | AEG Dryers
Watch stops after wearing for a few hours
Self winding watches need motion ( wrist twist) without they can stop. Sometimes just shake your wrist for a few seconds. I purchased a winder box for times I don't wear. ( Amazon)!
it is belt driven winder, rotates watch 5 minutes every hour.
Apr 21, 2015 | Rolex Submariner Oyster Watch for Men
Why does my motor stop.
The motor has an internal thermal ckt breaker. The load is too heavy. Suggest changing the belt pulley ratio to lighten load on motor.
Apr 25, 2014 | Dayton Century Type Sp 1/4 Single Phase...
Baby lock slows down to 0 after sewing a few inches
have you checked
1.to make sure it's plugged into the wall outlet good?
make sure the power & foot pedal are connected correctly to the machine?
2.does the motor smell in any way?
when was the last time it was serviced?
Feb 08, 2012 | Baby Lock Sewing Machines
Dryer starts, drum turns a few times then stops. On its own, repeats the attempt to start but has the same issue. For a while it would actually start and complete drying cycle after 3-5 attempts. Now it...
if you can still here the motor running it could be the belt slipping,, try running the dryer with a very light load in it ,,if it works ok,,its the belt slipping and it cant turn a full load anymore,,change the drive belt!
if no motor sounds its the programer,,,pricy part!!!
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
Motor/Drum doesn't turn/spin & belt appears to be OK
With the belt off can you spin the motor freely by hand? If no then the bearings are froze and the motor has to be replaced. If yes and the motor will not start when power is applied then the motor needs to be replaced. If it starts without the belt on but not with, then the drum is bound somewhere and has to be freed.
Eric
Jun 11, 2010 | Kenmore Dryers
Cd tray wont close, cds wont play
Sounds like you probably have a stretched belt on the load motor. Unplug the unit and remove the case which will expose the load motor. Plug in and turn on and press tray in button. You should hear the motor run and if you can see the belt you should see it slipping. Some belts are easy to change, and some are next to impossible. If you have to disassemble anything be sure that you note the position of everything as the timing of the tray, door, laser and most items in the unit is very critical. Let me know if you need more help.
hardrocko
Thanks for using FixYa
Feb 19, 2010 | Memorex Audio Players & Recorders
Hello i have a hotpoint wma40 the machine will go
Hi, i have a wma40s had it for 7 ears now same thing happended would start a cycle but then stop halfway through make the noise but the drum would not spin etc. i bought some carbon brushes of ebay for 7 quid and it works better than its worked in years bit nosiey for first few washes but after it settles it is as good as new.
Jul 06, 2009 | Hotpoint WMA40 Front Load Washer
Video stops and starts every video
sounds like your processor is overloaded.
open your task manager and turn off the un needed processes that are running and see how that dose.
Jun 02, 2009 | Gateway GT4024 PC Desktop
1998 toyota corolla shakes before 2 rpm, check engine lights up
Not sure what is causing it, but it sounds like you're running on 3 cyllinders. Check plugs, wires, timing . timing belt may have jumped, bad injector, low fuel pressure.
May 13, 2009 | 1998 Toyota Corolla
Saws Logo
54 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
